Utente del giorno: Q.dino con ben 3 Thanks ricevuti nelle ultime 24 ore
Visualizzazione dei risultati da 11 a 20 su 27
[Kernel] Z7 Max Kernel - NGIA - F2FS Data and Cache
  1. #11
    Dec 2014
    Ringraziato 6 volte in 3 Posts
    Honestly didn't tried to convert /system because usually there are some problems, and no gains will come from that except maybe boot time. /system partition after boot is a Read-Only partition. However i could try to convert later.
    Installing any rom without modification will probably format /data and /cache to EXT4. You can install and then you have to format again to F2FS (without -rm option).
    This Kernel will (probably) work only on stock roms, it was tested only with 1.64 version.
    I will release a new version right away. I have some improvements implemented, including OC/UC and new IO Schedulers.
    Sep 2014
    OK ! so I will not change the system for f2fs now. let me know about the new kernel! everything is working good now. thanks!
  4. #13
    Dec 2014
    Its on the first post the new release. Many improvements.
    To change system to f2fs ramdisk must be changed. Do not try because it will fail.
  5. #14
    Sep 2014
    you are amazing man. what app do you recommend me to fine tune the CPU?
    Ultima modifica di nesquix; 30-05-15 alle 02:15
  6. #15
    Dec 2014
    I use trikster mod
  7. #16
    Sep 2014
    Quote Originariamente inviato da nuno169 Visualizza il messaggio
    I use trikster mod
    i hope you uploaded the right kernel now :-P, because when i set the GPU to the max frequency for exemple,with TricksterMOD, he always stuck at 100mhz. and i can't see 100mhz on the CPU mini freq, but only 300.
    i don"t like this application for modding the kernel so much, you should try a free alternative with a better UI, more updated and with more free features. go on the play store and install "Kernel Audiutor"
    something strange is too is that Antutu always crash with OC
    what setting do you recommand?
    mine are :
    CPU / min 300 max 2726mhz
    governor interactive
    gpu governor msm_adreno
    gpu max frequency 6
    mp decision off
    the GPU max frequency is s et to -1053mhz by default on the app, WTF ? lol, so i set it to 640mhz.
    the gpu governor, i let msm-adreno-tz
    E/S setting,i set the scheduler on "sio"
    i set the buffer to 4096ko (for internal storage and external, with "sio" too)
    with that antutu crash again :P
  8. #17
    Androidiano VIP L'avatar di manuelb
    Honor 6 Plus/Opo/Asus tf300t
    Ringraziato 670 volte in 497 Posts
    Grande nuno bravo!!!!
    Sai percado se ci sono in giro i sorgenti della lollipop stock nubia ?? Li ho cercati ma senza risultati molto probabilmente nubia non ha rilasciato nulla ancora.
    Ultima modifica di manuelb; 30-05-15 alle 10:25
  9. #18
    Dec 2014
    Quote Originariamente inviato da nesquix Visualizza il messaggio
    mine are :
    gpu max frequency 6
    mp decision off
    Yes its the right file this time
    You should set on your OC frequencies voltage +25 and it should not crash. Mine dont needed but it varies from phone to phone.
    CPU has just OC not UC. 100mhz is on GPU.
  10. #19
    Dec 2014
    Quote Originariamente inviato da manuelb Visualizza il messaggio
    Hi manuelb! I didnt find lollipop sources too. I think it has not been released
  11. #20
    Dec 2014
    New release on first post.
    @nesquix all your bugs fixed.
  12. I seguenti 2 Utenti hanno ringraziato nuno169 per il post:
    manuelb (02-06-15),migel121 (03-06-15)
