Pagina 22 di 112 primaprima ... 1220212223243272 ... ultimoultimo
Visualizzazione dei risultati da 211 a 220 su 1120
[GUIDA] Eseguire ROOT e UNROOT Samsung Galaxy W (GT-I8150)
  1. #211
    ho fatto vari tentativi ma non riesco a fare il root
    Easy rooting toolkit (v3.0)
    created by DooMLoRD
    using exploit zergRush (Revolutionary Team)
    Credits go to all those involved in making this possible!
    ---------------------------------------------------------------[*] This script will:
    (1) root ur device using latest zergRush exploit (16 Nov)
    (2) install Busybox (1.18.4)
    (3) install SU files (binary: 3.0.3 and apk: 3.0.6)[*] Before u begin:
    (1) make sure u have installed adb drivers for ur device
    (2) enable "USB DEBUGGING"
    from (Menu\Settings\Applications\Development)
    (3) enable "UNKNOWN SOURCES"
    from (Menu\Settings\Applications)
    (4) [OPTIONAL] increase screen timeout to 10 minutes
    (5) connect USB cable to PHONE and then connect to PC
    (6) skip "PC Companion Software" prompt on device
    CONFIRM ALL THE ABOVE THEN
    Premere un tasto per continuare . . .
    --- STARTING ----
    --- WAITING FOR DEVICE
    * daemon not running. starting it now *
    * daemon started successfully *
    --- cleaning
    rm failed for *, No such file or directory
    --- pushing zergRush"
    22 KB/s (23056 bytes in 1.000s)
    --- correcting permissions
    --- executing zergRush
    [**] Zerg rush - Android 2.2/2.3 local root
    [**] (C) 2011 Revolutionary. All rights reserved.
    [**] Parts of code from Gingerbreak, (C) 2010-2011 The Android Exploid Crew.
    [+] Found a GingerBread ! 0x00029118
    [+] Found a Samsung, running Samsung mode[*] Scooting ...[*] Sleeping a bit (~40s)...[*] Waking ![*] Sending 149 zerglings ...[*] Sleeping a bit (~40s)...[*] Waking ![*] Sending 189 zerglings ...
    [-] Hellions with BLUE flames !
    --- WAITING FOR DEVICE TO RECONNECT
    if it gets stuck over here for a long time then try:
    disconnect usb cable and reconnect it
    toggle "USB DEBUGGING" (first disable it then enable it)
    --- DEVICE FOUND
    --- pushing busybox
    2099 KB/s (1075144 bytes in 0.500s)
    --- remounting /system
    mount: permission denied (are you root?)
    --- copying busybox to /system/xbin/
    /system/xbin/busybox: cannot open for write: Read-only file system
    --- correcting ownership
    Unable to chmod /system/xbin/busybox: No such file or directory
    --- installing busybox
    /system/xbin/busybox: not found
    --- pushing SU binary
    failed to copy 'files\su' to '/system/bin/su': Read-only file system
    Unable to chmod /system/bin/su: No such file or directory
    --- correcting symlinks
    rm failed for /system/xbin/su, Read-only file system
    link failed Read-only file system
    --- pushing Superuser app
    failed to copy 'files\Superuser.apk' to '/system/app/./Superuser.apk': Read-only
    file system
    --- cleaning
    --- rebooting
    ALL DONE!!!
    Ringraziato 40 volte in 37 Posts
    Comunque in questo post c'è scritto come fare il root con la versione 2.3.6... se vai nelle prime pagine c'è un file da scaricare che si chiama update.zip lo devi copiare della memoria del cellulare, far partire in modalità recovery e far partire quel file. Se vai qualche pagina indietro l'ho spiegato facile facile. Facci sapere!
    Inviato dal mio GT-I8150
  4. #213
    Quote Originariamente inviato da tecninan Visualizza il messaggio
    ma il metodo che ho seguito io che si trova nel post in prima pagina non è compatibile con la 2.3.6??
  5. #214
    No. Funziona solo quello col file update.zip. A me faceva come te e mi faceva solo il riavvio alla fine, ma senza root.
  6. #215
    samsung galaxy W GT-I8150
    ok, ho rootato tramite script (android 2.3.5) ed è andato tutto a posto. Pochi giorni fa ho avuto la necessità di fare l'unroot (sempre con script) e devo dire che ha funzionato tutto bene. Purtroppo eseguendo nuovamente il root dallo script risulta che è impossibile rootare, qualcuno sa aiutarmi?
    ps: titanium backup mi ha fatto sostituire dei file (non ricordo) può dipendere da questo?
  7. #216
    Quote Originariamente inviato da OrangePixel Visualizza il messaggio
    Problema risolto con un ripristino e di nuovo root con script
  8. #217
    Baby Droid L'avatar di Raziel_86
    scusate la domanda banale ma per avere la recovery bisongna già avere il cell rootato e allora come è possibile fare un root da recovery tramite il file udate non l'ho capito... :\
    ho provato il root con il file script ma nn và...ho una versione 2.3.6 con kernel 2.6.35.7-perf-I8150XXLA2 qualcuno può aiutarmi???
    Ultima modifica di Raziel_86; 06-04-12 alle 17:36
    The Power of Mangekyou Sharingan!!!
  9. #218
    Senior Droid L'avatar di sparta20
    Samsung Galaxy S6 Edge
    Ringraziato 252 volte in 150 Posts
    Quote Originariamente inviato da Raziel_86 Visualizza il messaggio
    Lo script non funziona sui firmware recenti. Il root lo puoi fare tramite recovery: scarichi il file che trovi al primo post, ma lo metti nella sd interna, spegni il telefono e lo accendi in recovery (quella che il telefono possiede già di base) premendo tasto accensione volume su e tasto home una volta comparsa la scritta samsung devi lasciare solo il tasto accensione. Ti compare la recovery fai install. Zip cerchi il file che hai messo e lo flashi. Infine fai reboot e il telefono si riaccende solo, ma ora avrai il telefono rootato... Tutto è spiegato anche nel primo post... Spero di essere stato utile.
    Posted by Josh
  10. Il seguente Utente ha ringraziato sparta20 per il post:
    Raziel_86 (07-04-12)
  11. #219
    Baby Droid L'avatar di dis3nchant3d
    Io ho fatto il root al w di una mia amica tramite l'update zip per farle bloccare le app cn titanium. Qualora volesse aggiornare tramite ota (per i futuri aggiornamenti) deve prima fare l unroot o puó aggiornare tranquillamente? Ovviamente credo poi perderá i permessi...
    Sent from my GT-I9100 using Tapatalk 2 Beta-5
  12. #220
    Senior Droid L'avatar di ktuluworld
    Napoli
    Motorola Moto G5 Plus
    Ringraziato 233 volte in 201 Posts
    Se aggiornerai via Ota non c'è bisogno dell'unroot quindi vai pure tranquillo, inoltre via Ota i premessi non vengono persi!
    500 MB in più per te se ti registri su qui: Registrati
  13. Il seguente Utente ha ringraziato ktuluworld per il post:
    dis3nchant3d (08-04-12)
