Visualizza i risultati del sondaggio: Quale rom state usando?
Chi ha votato
46. Non puoi votare questo sondaggio
  • Io ho la rom di BB72&Cuoco92 vers. 1-3
    2 4.35%
  • Io ho la rom di BB72&Cuoco92 vers.4 installata tramite recoverry
    16 34.78%
  • Io ho la rom di BB72&Cuoco92 vers.4 installata tramite OTA
    15 32.61%
  • Io ho la rom LEWA multilingua
    4 8.70%
  • Io ho un'altra rom
    9 19.57%
Pagina 444 di 489 primaprima ... 344394434442443444445446454 ... ultimoultimo
Visualizzazione dei risultati da 4,431 a 4,440 su 4883
[Alcatel/TCL IdolX+/S960] Guide Root- Recovery- Rom Custom
  1. #4431
    Quote Originariamente inviato da Dadatt Visualizza il messaggio
    Hi Cuoco,
    I hope it is ok to write in English.
    I have a problem with my VW handsfree in my car. With my old Lewa and/or Anzhi Rom it was no problem to make a call in my car.
    With Cuoco's Rom conncecting is no problem, but when it builds up a call, a few seconds later the BT crashes. Receiving calls dosen't even work anymore.
    Does anyone have an hint?
    Regards Daniel
    I have the same problem... I'm also waiting for a solution from Cuoco... Let's hope...
    Inviato dal mio 6043D usando Androidiani App
    Oct 2014
    Quote Originariamente inviato da lupetz Visualizza il messaggio
    Hi,
    Ok, it's really bad.
    Is Cuoco working on this? Because I need my handsfree for business ...
  4. #4433
    [quote name="lupetz" post=6236323]I have the same problem... I'm also waiting for a solution from Cuoco... Let's hope...
    Hi,
    Is Cuoco working on this? Because I need my handsfree for business ... [/QUOTE]
    Yes it's quite frustrating... Couse this ROM it's really fantastic and I wouldn't change it Couse it is working very well.....
    I also use alot my handsfree for business and I can't keep this issue for long time....
    About Cuoco, I hope that he's working on it... But I don't have any news from him...
  5. #4434
    thl w8
    Ringraziato 39 volte in 31 Posts
    ciao palasix ho provato a scaricare le baseband sia dalla 19 alla 27 che la 27 jellybeam non me le fa scaricare
    ho la rom 8 e mi si sconnette sovente sia in wifi che in 3g,passa sempre da H+ a 3G
  6. #4435
    Redmi Note 3 Pro, Honor 6
    Ringraziato 803 volte in 570 Posts
    riprova..io ci sono riuscito, sarà qualche problema momentaneo di google.
  7. Il seguente Utente ha ringraziato palasix per il post:
    androsimo (28-10-14)
  8. #4436
    Oct 2014
    Hi,
    I went to ROM version 7.xx. Now the Bluetooth works in my car! Great.
    But my signal strength with vodafone dropped from 5bars to 2 bars!
    Which baseband should I use with ROM 7.14, Vodafone Germany?
    Which Baseband is included in the ROM 7.xx download?
    Many Thanks for your support.
    Ultima modifica di Dadatt; 27-10-14 alle 17:43
  9. #4437
    Hi,
    Very good!
    Listen, did you lost your settings and data with the downgrade to V7?
  10. #4438
    Oct 2014
    I lost my Apps and settings. No private data.
    My signal is really poor with 7.14.
    I tried several basebands - no change.
  11. #4439
    So I guess it's better to keep the V8.5. I prefer pure bluetooth than pure signal.
    Hope that Cuoco will fix the Bluetooth issue as soon as possible.
    It's the only "Big Issue" I've found till now..
  12. #4440
    thl w8
    si era un problema di google,ora l ho scaricato ti ringrazio
