comincio con la scheda tecnica:
SIM Card Configuration Dual SIM
Phone Standard GSM, WCDMA
Network Support GSM 850/900/1800/1900 MHz, WCDMA 850/2100 MHz
Messaging SMS, MMS and group messages
Language Indonesian,Malay,Dutch,Chinese,Arabic,Vietnamese,I Danish,Greek,Turkish,Italian,
German,French,Romanian,Korean,Spanish,Russian,Poli sh,Slovak,Czech,Portuguese,
Japanese,English
Bluetooth V4.0
Supported Audio Formats MP3, MIDI, AMR, AAC, WAV
Supported Video Formats MP4, 3GP, WMV, AVI
Operating System Android 4.4.2
CPU MTK6592W Octa core 1.7GHz (728MHz - 1.66MHz)
GPUMali-450MP
Camera Front camera: 2mega pixels, rear camera: 13mega pixels,Flash light
Java Supported NO
TV NO
FM Radio Supported Yes
Wi-Fi 802.11b/g/n
GPS Supported Yes (map is not included)
OTG Yes
OTA NO
NFC NO
Built-in Games NO
Data Interface micro 5pin
Earphone Interface 3.5 mm
Tools Calculator, Email, schedule, memo
Talk Time Up To 4 hours
Standby Time Up To 180 hours
Others Facebook, Office function
Proxy-sensor Support
Light-sensor Support
G-sensor Support
Acceleration Sensor NO
Direction Sensor NO
Gyroscope Sensor NO
Compass Sensor Support
Temperature Sensor NO
Humidity Sensor NO
Barometer Sensor NO
Gesture Sensor NO
Built-in Memory RAM: 2GB (c.a 1gb disponibile) ,ROM: 16GB (c.a 11gb disponibile)
Card Slot External T-flash card up to 64GB
Card Included N/A
Touch Screen Capacitive touch OGS
Size of Display 5.0", 320dpi
Type of Display HD
Resolution 1280 × 720 Pixels
Battery & Power
Battery 2200 mAh battery
Charger 100-240V
Size 143.8*72.7*8.4mm(with the battery )
Weight 164g
Package Includes
In the box1 x 2200mAh battery
1 x Adapter
1 x Micro USB Cable
1 x Earphone
1x Screen Protection
1 x User Manual(English)
1 x TF Card Adapter
comincio descrivendolo con una parola: è cinese.
l'estetica la trovo accattivante e moderna davanti, dietro invece è plasticaccia. cover batteria troppo leggera e fine, dà l'impressione di rompersi ogni volta che si stacca. la telecamera davanti è troppo esterna verso l'angolo il che aumenta le probabilita di rottura quando cade. le cuffie fanno a dir poco schifo, la cover è "utilizzabile" anche se non chiude bene non essendo magnetizzata, e visto che appena si allontana di poco la chiusura dal telefono si accende, la rende poco utile (non so se mi sono spiegato benissimo). la batteria dura ben poco se utilizzato, 2 ore e mezza di utilizzo assiduo con wifi ma senza sim lo scarica del tutto. non c'è la possibilità di limitare la connessione al 2g(se trovate la soluzione senza root ditemelo). non si capisce se non c'è la pellicola già applicata, e se c'è è finissima. comunque ce n'è un altra. launcher di base orribile, touch decisamente meno sensibile rispetto al mio vecchio lg l5. recovery mod con power + vol -, troppo facile da entrarci, e soprattutto, è in cinese
direi che con le critiche ho finito! passiamo agli apprezzamenti
antutu lo valuta a volte sui 30'000 a volte sui 23'000, ma finita la prova 3D si blocca, quindi non è verificato.
8 core belli tosti a mio dire, gira perfettamente asphalt 8 con musica, download e altre applicazioni in background senza lag. veloce, ho riscontrato qualche lag con il browser di base. fotocamere ottime, quella davanti un po meno buona a ricercare la luce giusta.
so che rispetto alle critiche gli apprezzamenti sono pochi, ma devo dire che per 140€ è un affare. gli accessori si possono comprare nuovi, il problema batteria si risolve con un battery bank...
io gli darei un bell'8 tutto sommato :)
fatemi sapere! ciao
https://www.androidiani.com/extra/im...mage_E2I0b.jpg
https://www.androidiani.com/extra/im...mage_58UTo.jpghttps://www.androidiani.com/extra/im...mage_ibnxa.jpghttps://www.androidiani.com/extra/im...mage_JNUWu.jpghttps://www.androidiani.com/extra/im...mage_noMtt.jpghttps://www.androidiani.com/extra/im...mage_G5kh2.jpghttps://www.androidiani.com/extra/im...mage_2IlmI.jpg
risicata come rece... mi è appena arrivato, preso a 127€ da antelife spedito dalla germania, senza altre spese..
è per mio cognato.. già fatto il root, creata la recovery twrp 2.8.10, messo nova launcher, xposed+ gravity box, allargato la partizione app da 2,95Gb a 8Gb..
a breve recenzione e video, oltre che upload della rom formato flashtool, se qualcuno la volesse provare (già rootata e con memoria ampliata).
ciao
megthebest
ciao
Grazie mille... Hai avuto problemi in qualche passaggio o è andato tutto liscio?
Inviato dal mio Crown usando Androidiani App
Andreboh
no, tutto liscio.. trovi info:
https://www.androidiani.com/forum/mo...iew-crown.html
per il touch, senza pellicola applicata va molto meglio...
la batteria dura però 1gg, sicuramente non è da 2200mAh
Si infatti, cpu-z la da da 1000mhz... Ti ringrazio comunque,se ho dubbi spero di poter chiedere a te 😉
