HTC Hero o SAMSUNG Galaxy?
Ragazzi che ne pensate? Cosa comprereste?
Per chi è più informato di me, può reperire le specifiche del Galaxy in modo da poter mettere a confronto i due cellulari? Grazie!
Passiamo alle caratteristiche tecniche HTC HERO:
Processor Qualcomm® MSM7200A™, 528 MHz
Operating System Android™
Memory ROM: 512 MB
RAM: 288 MB
Dimensions (LxWxT) 112 x 56.2 x 14.35 mm ( 4.41 x 2.21 x 0.57 inches)
Weight 135 grams ( 4.76 ounces) with battery
Display 3.2-inch TFT-LCD touch-sensitive screen with 320x480 HVGA resolution
Network HSPA/WCDMA:
900/2100 MHz
Up to 2 Mbps up-link and 7.2 Mbps down-link speeds
Quad-band GSM/GPRS/EDGE:
850/900/1800/1900 MHz
(Band frequency and data speed are operator dependent.)
Device Control Trackball with Enter button
GPS Internal GPS antenna
Connectivity Bluetooth® 2.0 with Enhanced Data Rate and A2DP for wireless stereo headsets
Wi-Fi®: IEEE 802.11 b/g
HTC ExtUSB™ (11-pin mini-USB 2.0 and audio jack in one)
3.5 mm audio jack
Camera 5.0 megapixel color camera with auto focus
Audio supported formats MP3, AAC(AAC, AAC+, AAC-LC), AMR-NB, WAV, MIDI and Windows Media® Audio 9
Video supported formats MPEG-4, H.263, H.264 and Windows Media® Video 9
Battery Rechargeable Lithium-ion battery
Capacity: 1350 mAh
Talk time:
Up to 420 minutes for WCDMA
Up to 470 minutes for GSM
Standby time:
Up to 750 hours for WCDMA
Up to 440 hours for GSM
(The above are subject to network and phone usage.)
Expansion Slot microSD™ memory card (SD 2.0 compatible)
AC Adapter Voltage range/frequency: 100 ~ 240V AC, 50/60 Hz
DC output: 5V and 1A
Special Features G-sensor
Digital Compass
