Dice 7 - Hardest Dice Puzzle
    Aug 2013
    https://play.google.com/store/apps/d...cmstudio.dice7
    Dice 7 is an original mind bending puzzle game. Player have to imagine dice from given nets to solve puzzles.
    Here are a few interesting facts about dice. A standard die, of course, is a cube with each of its six faces showing a different number of "pips" from one to six. the opposite faces of the die will always add up to seven. There are 11 different arrangements (or "nets") of six-connected squares that could be "folded" into such a cube. Dice 7 is a simple puzzle game that pen-and-paper fans will find to be quite the bit of pair-o-dice.
    Dice 7 Using the mouse and following the above rules, click the white faces of the presented nets to fill in the correct numbers. Once all the numbers in a puzzle are correctly filled in, the next puzzle is unlocked. Puzzles will involve overlapping "nets", which are denoted by different colors. The concept behind Dice 7 is quite strong... at the very least, it could definitely stand to be explored further than the mere ten puzzles included in this collection. It has the basic framework of Sudoku, but with a spatial awareness twist that forces you to think in three dimensions. So give it a roll!
