The boot is the stock!
I added only a service to for fixing netd, witouth this service the tablet will not boot.
I don't know how can i also do.
Fixato il bluetooth ora funziona!
show me your logcat when you try to start wifi
this is mine
18:04:19.880 Warning WifiHW 140 open(/sys/class/rfkill/rfkill2/type) failed: No such file or directory (2)
18:04:19.880 Debug SettingsAppWidgetProvider 544 Widget is from a previous version... Let's update
18:04:19.880 Debug SettingsAppWidgetProvider 544 No instances yet... Wait for at least one instance to exist before adding global settings
18:04:19.880 Debug WifiService 140 ACTION_BATTERY_CHANGED pluggedType: 2
18:04:19.880 Error WifiHW 140 Unable to open connection to supplicant on "wlan0": No such file or directory
18:04:19.880 Debug WifiStateTracker 140 Reset connections and stopping DHCP
18:04:19.880 Debug dalvikvm 444 GC_EXTERNAL_ALLOC freed 136K, 52% free 2912K/5959K, external 49K/781K, paused 100ms
18:04:19.881 Error wpa_supplicant 703 ioctl[SIOCGIWRANGE]
18:04:19.881 Info ActivityManager 140 Starting: Intent { act=android.intent.action.MAIN cmp=com.android.settings/.wifi.WifiSettings } from pid 544
18:04:19.881 Error WifiStateTracker 140 Could not stop DHCP
18:04:19.881 Debug WifiStateTracker 140 Disabling interface
18:04:19.881 Error WifiHW 140 Unable to open connection to supplicant on "wlan0": No such file or directory
18:04:19.881 Info ActivityManager 140 Displayed com.android.settings/.wifi.WifiSettings: +640ms
18:04:19.881 Info dun_service 79 The value returned from dun_getusbmodemstate_fromsys is 2
18:04:19.881 Debug WifiService 140 ACTION_BATTERY_CHANGED pluggedType: 2
18:04:19.882 Error wpa_supplicant 703 ioctl[SIOCGIWRANGE]
18:04:19.882 Debug dalvikvm 444 GC_EXTERNAL_ALLOC freed 126K, 52% free 2918K/5959K, external 49K/781K, paused 150ms
18:04:19.882 Error WifiHW 140 Unable to open connection to supplicant on "wlan0": No such file or directory
18:04:19.882 Debug dalvikvm 544 GC_EXTERNAL_ALLOC freed 316K, 48% free 3190K/6023K, external 501K/514K, paused 91ms
18:04:19.882 Warning KeyCharacterMap 544 Can't open keycharmap file
18:04:19.882 Warning KeyCharacterMap 544 Error loading keycharmap file '/system/usr/keychars/SSD2533tp.kcm.bin'. hw.keyboards.65538.devname='SSD2533tp'
18:04:19.882 Warning KeyCharacterMap 544 Using default keymap: /system/usr/keychars/qwerty.kcm.bin
18:04:19.883 Debug dalvikvm 544 GC_EXTERNAL_ALLOC freed 95K, 49% free 3097K/6023K, external 981K/1001K, paused 132ms
18:04:19.883 Debug dalvikvm 140 GC_CONCURRENT freed 623K, 43% free 4534K/7943K, external 1521K/2118K, paused 5ms+20ms
18:04:19.883 Error wpa_supplicant 703 ioctl[SIOCGIWRANGE]
18:04:19.883 Debug dalvikvm 544 GC_EXTERNAL_ALLOC freed <1K, 49% free 3098K/6023K, external 1341K/1373K, paused 85ms
18:04:19.883 Info dun_service 79 The value returned from dun_getusbmodemstate_fromsys is 2
18:04:19.883 Debug WifiService 140 ACTION_BATTERY_CHANGED pluggedType: 2
18:04:19.883 Error WifiHW 140 Unable to open connection to supplicant on "wlan0": No such file or directory
18:04:19.883 Verbose WifiStateTracker 140 Supplicant died unexpectedly
18:04:19.883 Debug WifiStateTracker 140 Reset connections and stopping DHCP
18:04:19.884 Debug dalvikvm 444 GC_EXTERNAL_ALLOC freed 132K, 51% free 2924K/5959K, external 49K/781K, paused 149ms
18:04:19.884 Error wpa_supplicant 703 ioctl[SIOCGIWRANGE]
18:04:19.884 Info ActivityManager 140 Starting: Intent { act=android.intent.action.MAIN cmp=com.android.settings/.deviceinfo.Memory } from pid 544
18:04:19.884 Info ActivityManager 140 Displayed com.android.settings/.deviceinfo.Memory: +743ms
18:04:19.884 Error WifiStateTracker 140 Could not stop DHCP
18:04:19.884 Debug WifiStateTracker 140 Disabling interface
18:04:19.884 Debug SettingsAppWidgetProvider 544 Widget is from a previous version... Let's update
18:04:19.884 Debug SettingsAppWidgetProvider 544 No instances yet... Wait for at least one instance to exist before adding global settings
18:04:19.884 Debug WifiStateTracker 140 Reset connections and stopping DHCP
18:04:19.884 Warning KeyCharacterMap 544 Can't open keycharmap file
18:04:19.885 Warning KeyCharacterMap 544 Error loading keycharmap file '/system/usr/keychars/SSD2533tp.kcm.bin'. hw.keyboards.65538.devname='SSD2533tp'
18:04:19.885 Warning KeyCharacterMap 544 Using default keymap: /system/usr/keychars/qwerty.kcm.bin
18:04:19.885 Info ActivityManager 140 Starting: Intent { act=android.intent.action.MAIN cmp=com.android.settings/.WirelessSettings } from pid 544
18:04:19.885 Info ActivityManager 140 Displayed com.android.settings/.WirelessSettings: +422ms
18:04:19.885 Error WifiStateTracker 140 Could not stop DHCP
18:04:19.885 Debug WifiStateTracker 140 Disabling interface
18:04:19.885 Warning WifiHW 140 open(/sys/class/rfkill/rfkill2/type) failed: No such file or directory (2)
18:04:19.886 Error WifiService 140 Failed to unload Wi-Fi driver.
Also the admin from arctablet told me:
"If it's of any help, my hosting company gave me access to a small test server (Intel Atom D425 @ 1.8Ghz, 4GB ram, 2TB hdd) for a few weeks, I can make accounts for you if it makes it easier to download/compile source code."
If you need this i can speak with him to make you an account.
Ultima modifica di globula; 25-04-12 alle 21:32
last try for today
Results
21:49:03.631 Info ActivityManager 121 Starting: Intent { act=android.intent.action.MAIN cmp=com.android.settings/.WirelessSettings } from pid 458
21:49:03.631 Verbose NFC 458 this device does not have NFC support
21:49:04.069 Info ActivityManager 121 Displayed com.android.settings/.WirelessSettings: +443ms
21:49:15.211 Error WifiHW 121 Unable to open connection to supplicant on "wlan0": No such file or directory
21:49:15.211 Info wpa_supplicant 531 wapi_supplicant_init: Init WAPI packet wlan0
21:49:15.211 Info wpa_supplicant 531 wpa_driver_wext_set_wpa
21:49:15.212 Info wpa_supplicant 531 wpa_driver_wext_set_key: alg=0 key_idx=0 set_tx=0 seq_len=0 key_len=0
21:49:15.212 Info wpa_supplicant 531 wpa_driver_wext_set_key: alg=0 key_idx=1 set_tx=0 seq_len=0 key_len=0
21:49:15.212 Info wpa_supplicant 531 wpa_driver_wext_set_key: alg=0 key_idx=2 set_tx=0 seq_len=0 key_len=0
21:49:15.212 Info wpa_supplicant 531 wpa_driver_wext_set_key: alg=0 key_idx=3 set_tx=0 seq_len=0 key_len=0
21:49:15.212 Info wpa_supplicant 531 wpa_driver_wext_set_countermeasures
21:49:15.212 Info wpa_supplicant 531 wpa_driver_wext_set_drop_unencrypted
21:49:15.317 Info wpa_supplicant 531 sun_path = wpa_DIR=/data/misc/wifi/wpa_supplicant GROUP=wifi
21:49:15.317 Info wpa_supplicant 531 [wpa_supplicant_ctrl_iface_init] buf = DIR=/data/misc/wifi/wpa_supplicant GROUP=wifi
21:49:15.317 Info wpa_supplicant 531 preset :wpa_s->scan_interval 5
21:49:15.317 Info wpa_supplicant 531 new value :wpa_s->scan_interval 7
21:49:15.317 Info wpa_supplicant 531 Added interface wlan0
21:49:15.317 Info dun_service 79 process rmnet event
21:49:15.317 Info wpa_supplicant 531 CTRL-EVENT-STATE-CHANGE id=-1 state=2 BSSID=00:00:00:00:00:00
21:49:15.318 Info wpa_supplicant 531 CTRL-EVENT-SCAN-RESULTS
21:49:15.318 Info wpa_supplicant 531 FOXDA_rescan timeout= 0
21:49:16.956 Info wpa_supplicant 531 CTRL-EVENT-SCAN-RESULTS
21:49:16.956 Info wpa_supplicant 531 WPS-AP-AVAILABLE
21:49:16.956 Info wpa_supplicant 531 No network enabled Change state to WPA_INACTIVE
21:49:16.956 Info wpa_supplicant 531 CTRL-EVENT-STATE-CHANGE id=-1 state=1 BSSID=00:00:00:00:00:00
21:49:20.230 Error WifiHW 121 Unable to open connection to supplicant on "wlan0": No such file or directory
21:49:17.172 Debug WifiService 121 ACTION_BATTERY_CHANGED pluggedType: 2
21:49:25.143 Error WifiHW 121 Unable to open connection to supplicant on "wlan0": No such file or directory
21:49:25.143 Error NetlinkListener 71 ignoring message with no sender credentials
21:49:25.252 Debug WifiService 121 ACTION_BATTERY_CHANGED pluggedType: 2
21:49:26.237 Info ActivityManager 121 Starting: Intent { act=android.intent.action.MAIN cmp=com.android.settings/.wifi.WifiSettings } from pid 458
21:49:26.567 Info ActivityManager 121 Displayed com.android.settings/.wifi.WifiSettings: +307ms
21:49:30.170 Error WifiHW 121 Unable to open connection to supplicant on "wlan0": No such file or directory
21:49:30.170 Verbose WifiStateTracker 121 Supplicant died unexpectedly
21:49:30.170 Debug WifiStateTracker 121 Reset connections and stopping DHCP
21:49:33.230 Debug WifiService 121 ACTION_BATTERY_CHANGED pluggedType: 2
21:49:33.230 Debug WifiStateTracker 121 Reset connections and stopping DHCP
21:49:35.191 Error WifiStateTracker 121 Could not stop DHCP
21:49:35.191 Debug WifiStateTracker 121 Disabling interface
21:49:35.191 Info dun_service 79 process rmnet event
21:49:33.230 Info dun_service 79 The value returned from dun_getusbmodemstate_fromsys is 2
21:49:33.230 Error NetlinkListener 71 ignoring message with no sender credentials
21:49:38.247 Error WifiStateTracker 121 Could not stop DHCP
21:49:38.247 Debug WifiStateTracker 121 Disabling interface
21:49:38.247 Info dun_service 79 process rmnet event
21:49:38.247 Warning ProcessStats 121 Skipping unknown process pid 624
21:49:38.247 Info wpa_supplicant 531 CTRL-EVENT-TERMINATING - signal 15 received
21:49:38.247 Info wpa_supplicant 531 CTRL-EVENT-TERMINATING - signal 0 received
21:49:38.248 Info wpa_supplicant 531 CTRL-EVENT-STATE-CHANGE id=-1 state=0 BSSID=00:00:00:00:00:00
21:49:38.248 Info wpa_supplicant 531 wpa_driver_wext_set_wpa
21:49:38.248 Info wpa_supplicant 531 wpa_driver_wext_set_drop_unencrypted
21:49:38.248 Info wpa_supplicant 531 wpa_driver_wext_set_countermeasures
21:49:38.358 Debug Tethering 121 MasterInitialState.processMessage what=3
21:49:38.471 Debug WifiStateTracker 121 Reset connections and stopping DHCP
21:49:38.471 Debug CMStats 317 CONNECTIVITY_ACTION: noConnectivity = true
21:49:38.358 Debug SettingsAppWidgetProvider 458 No instances yet... Wait for at least one instance to exist before adding global settings
21:49:38.358 Debug SettingsAppWidgetProvider 458 Widget is from a previous version... Let's update
21:49:43.381 Debug WifiStateTracker 121 Disabling interface
21:49:43.381 Error WifiStateTracker 121 Could not stop DHCP
AHH
SOUND IS BACK ON
AND ALSO THE 3d SIDE IS SOLVED
Scrolling is more smother now.
Ultima modifica di globula; 26-04-12 alle 00:01
Sound - Working
Bluetooth - Working
3D Acceleration - Working
Wifi - The driver is loading fine, but still some error, that involves liblegacy_hardware.
Daniel if you can port the libhardware_legacy.so from the stock rom, everything will work
I will research in the weekend about this
Ar maybe you can recompile the cm7 with the stock boot.img, from what i have seen on internet, the libhardware is created by using some things from boot.img
And i am 100 percent sure that if you can do this the wifi will work fine, because from what i`ve seen in the libhardware are exactly the things that should correct the errors from above
Ultima modifica di globula; 26-04-12 alle 14:05
Thanks for the test!
Pass me your last working rom please, send on email.
And also ask for account![]()
I left a message to the admin from arctablet and it should send you a private message today with the account.
I`m still working on the sensors, i will upload the build somewhere around 6-7pm.
I don`t know why the image from the camera is upside down, i mean it is working fine recording, you can make fotos but but everything is upside down![]()
Did you tested my rom ?
Glob_Be_One_V2Sense.zip
It is very fast
Instant google market syncmore apps available
