[GUIDA] ROOT Archos 80g9/101 g9
Non mi sembra di aver trovato nessuna guida sul root del nostro archos, quindi la scriverò io... :)
L'ARCHOS ha da poco messo a disposizione un firmware chiamato SDE che permette di installare rom e kernel custom con una procedura abbastanza semplice.
Di seguito il comunicato ufficiale:
Important notices to be acknowledged before downloading and installing the SDE firmware:
-Once the SDE firmware is installed on a device, this device will be watermarked and ARCHOS will be able to detect that this firmware has been installed once.
-After SDE firmware installation, you will not be able to play DRM protected content anymore.
-Installing the SDE firmware is considered by ARCHOS as a voiding of the warranty and ARCHOS declines all liability and responsibility for any issues resulting from the installation of this SDE firmware.
This firmware is provided "as is" and is not supported by ARCHOS.
The firmware must be installed on a unit with a firmware version above 4.0.1 (Ice Cream Sandwich). Once the SDE firmware is installed, powering on the device while pressing the 'volume down' button will now trigger a "Boot Menu". This menu allows to select which operating system is to be launched (Android, the newly installed Developer Edition or the Recovery System). If the device is powered on while pressing jointly the 'volume down' and the 'volume up' buttons, the Developer Edition will be launched. If the device is powered on without any other button pressed, Android will be launched.
Installing a new ARCHOS (Android) firmware WILL NOT remove the SDE firmware. In order to uninstall the SDE, boot into the recovery using the Boot Menu, select "Developer Edition Menu", then "Uninstall Developer Edition".
In poche parole se effettuiamo questa procedura ovviamente perderemo la garanzia e non potremo più visionare contenuti protetti da DRM;
Però come specificato è una procedura totalmente reversibile, quindi bando alle ciance e al lavoro!!!
Step 1:
Installiamo l'SDE:
ATTENZIONE: bisogna avere un firmware ICS 4.0.1 o superiore!!!
1-Scarichiamo l'SDE
2-Andiamo in recovery spegnendo il tablet(non sospensione) e premendo il tasto volume su e power in contemporanea;
3-Selezionare "Update Firmware" utilizzando il tasto power per confermare e i tasti volume per navigare;
4-Colleghiamo il tablet al PC e copiamo il file che abbiamo scaricato: "firmware_archos_it4.aos" nel tablet (l'unità si dovrebbe chiamare "A80_REC";
5-Premere il tasto power sul tablet e lasciando il cavo collegato fate terminare la procedura al tablet;
Fatto! Ora possiamo installare firmware e kernel modificati che ci permetteranno di avere il ROOT!
Step 2:
Ora possiamo installare un custom firmware, io illustrerò la procedura per installare una ROM stock rootata e ottimizzata, per il resto è uguale al fw originale;
1-scaricare questi 2 pacchetti:
https://hotfile.com/dl/156241977/239...pdate.zip.html
kernel_update.zip download - 2shared
2-copiare il primo file(estratto) nel sd interna del tablet(non in sottocartelle)
3-Avviamo in recovery e selezioniamo Recovery Option(credo si chiami così) cmq l'ultimo menù in basso
4-Dovrebbe esserci (se avete seguito il passo 1 correttamente) un menù dedicato alla developer edition,entrarci;
5-Selezioniamo "Remove android kernel"(se disponibile)
6-Successivamente selezioniamo "Flash Kernel and Initramfs";
7-colleghiamo il cavo USB e copiamo i 2 file che sono contenuti nello zip "kernel_update.zip";
8-appena la procedura sarà completata e premendo il tasto power il tablet si riavvierà e si avvierà lentamente;
Una volta avviato il sistema avrete finalmente il root!!!
Ho semplicemente tradotto la guida presente su XDA al seguente link(se masticate bene l'inglese ve la consiglio) :
[TUT] How to Install Official SDE menu and rooted firmware (updated 15 June 2012) - xda-developers
NON MI ASSUMO NESSUNA RESPONSABILITA' in caso di brick o altro, la procedura è a vostro rischio e pericolo!!!
