Pagina 12 di 16 primaprima ... 21011121314 ... ultimoultimo
Visualizzazione dei risultati da 111 a 120 su 152
[INFO][ZE550ML] Aggiornamenti Ufficiali ZE550ML
  1. #111
    Nov 2013
    Parma
    Asus Zenfone 2 (Z550ML)
    Nuovo aggiornamento V2.20.40.130
    【Version】
    V2.20.40.130_20151104
    【Model Name】
    ZenFone2 (ZE550ML)
    【Release Date】
    2015/11/12
    【Release Note】
    1 Improve screen turn into black during phone call issue.
    2 Fix Miracast frame rate drop issue.
    3 Fix NFC connect issue.
    4 Fix network data warning notice don not come up issue
    5 FixWi-Fi conncet issue
    6 Fix 3G cannot camp to H plus in Laos and Paraguay issue.
    7 Fix the coming call issue when using bluetooth earphone.
    8 Fix Unlock Tool issue.
    9 Improve service stability of modem
    10 Fix the charging issue of roaming to LTE when data roaming option disabled
    11 Fix boost stability issue
    12 Fix the issue that user would still receive the notifications from Auto start denied Apps
    13 Fix ASUS Mobile Manager data usage restriction issue
    14 Fix ZenMotion Shake Shake screenshot issue
    15 Fix URL recognition issue in Messages
    16 Modify HK Chinese strings
    17 Fix IME issue when open Yahoo PC version webpage by ASUS Browser
    18 Fix countdown alarm issue after set in Snap View
    19 Fix string issue in Theme Apps
    20 Fix charge remained time display issue when quick charging
    21 Fix SIM PIN lock issue in Cover View
    22 Modify Quick charge notification UI layout
    23 Fix System UI stability issue
    24 Fix Power saver settings issue
    25 Fix JP FlipFont issue
    26 Fix Battery Simplified Chinese string issue
    27 Fix ASUS Mobile Manager data usage calculation issue
    28 Improve Auto Start Manager stability
    29 Remove BookLive from JP SKU
    30 Fix Documents UI stability issue
    31 Fix Snap View UI issue and improve its performance when install 3rd party apps
    32 Improve Hand Writing accuracy
    33 Fix flashlight turn-off issue when double tap power key
    34 Fix Power Saver Ultra saving mode notification settings issue
    # New Features
    1 Add phone number editing function in Dual SIM settings
    2 Add 128G SD card turn into Power Saver mode function.
    3 Add Latvian and Lithuanian languages
    Lo sto installando ora!
    Ringraziato 90 volte in 87 Posts
    Ma noi l'Nfc non lo abbiamo, quindi come lo fixa?
    Stai installando via OTA o hai scaricato l'intero firmware dal sito?
  4. #113
    Nov 2013
    Parma
    ahahah già!!
    via OTA, ho sempre aggiornato cosi.
  5. Il seguente Utente ha ringraziato samux per il post:
    redblack (12-11-15)
  6. #114
    Androidiano L'avatar di thescach
    Oct 2013
    Ringraziato 38 volte in 37 Posts
    Quote Originariamente inviato da redblack Visualizza il messaggio
    Copincollano il changelog del 551ml perché praticamente a parte due o tre cavolate montano lo stesso software.
    Using Tapatalk
  7. Il seguente Utente ha ringraziato thescach per il post:
    redblack (12-11-15)
  8. #115
    Sai mica se è già disponibile il firmware completo sul sito Asus? Io vado di adb
  9. #116
    Jan 2011
    Italia
    Xiaomi MI Max, Vernee MIX 2
    Ringraziato 36 volte in 33 Posts
    Il firmware viene sempre pubblicato sul sito di asus con qualche giorno di ritardo.
    Bisogna aspettare, anch'io aggiorno via ADB.
  10. Il seguente Utente ha ringraziato 27ylliw per il post:
    redblack (12-11-15)
  11. #117
    Asus ZenFone 2 (ZE550ML)
    Ringraziato 97 volte in 86 Posts
    Ricevuto ed installato oggi per adesso tutto ok, anche se credo sia arrivata l'ora che si decidessero a rilasciare il 5.1 o 6.0
  12. #118
    Asus Zenfone 2 550 ML
    Da quando ho installato l'ultimo update, ho un dismount d mount random della memory card. Avete x caso lo stesso problema?
    Inviato dal mio ASUS_Z008D usando Androidiani App
  13. #119
    Jan 2011
    Italia
    Quote Originariamente inviato da schumy Visualizza il messaggio
    Idem per me e mi sembra sia un problema diffuso.
  14. #120
    Ho fatto un wipe cache e sembra andare meglio
