Pagina 2 di 2 primaprima 12
Visualizzazione dei risultati da 11 a 17 su 17
Minix Neo X7 Bloccato
  1. #11
    Nov 2015
    Dear NEO X7 users,
    The latest official 010 firmware is available now.
    Download link:
    http://www.minix.com.hk/Support/14050116305841.html
    MD5 checksum:
    37276c7280550c7b338035a9d59752bf NEO_X7_20140430_010_OTA.zip
    Forum Download Link:
    http://www.minixforum.com/downloads/...30_010_OTA.zip
    07/06/2014:
    Pure 1080P package:
    http://minix.com.hk/firmware/NEO-X7-010_1080.zip
    You may update to this firmware from any older FWs using the below method.
    Update instruction (same as pre-010 and pre-010b):
    1.) Download the above .zip package;
    2.) Upon successful download, then rename the file to "update.zip";
    3.) Put the file to the the hub's root directory (Also called "Internal Flash");
    4.) System will prompt asking for confirmation to update, choose Install;
    5.) System will reboot itself and complete the rests of the update process;
    6.) Upon successful update, system will boot into the Launcher selection screen;
    7.) Remove the update file when system prompt and ask you, or remove it manually afterwards;
    Change log (changes since 009):
    1.) ROM built based on user mode
    2.) Optimized HDMI parameters (NOTE: same as pre-010b)
    3.) Fixed automatic shut-down bug
    4.) Wifi is ON by default
    5.) Screen scale preset to 100% by default
    6.) System bar is hidden by default
    7.) Enhanced Ethernet performance
    8.) Fixed OTG bug
    9.) Raised VCCIO voltage to improve system stability
    10.) Updated media library, lots of video and audio enhancements
    11.) Fixed Wifi display app. bug (NOTE: this app. does not support SAMSUNG & SONY devices)
    12.) Fixed grey bar bug of stock video player (a RK bug on pre-010b)
    13.) AirPin software updated to V2.3.5 (supports Apple iOS screen mirroring, now the NEO completely replaces the Apple TV) - existing AirPin (PRO) users need to uninstall the old version and install the new apk manually.
    Download link: http://minix.com.hk/downfile/AirPin_PRO_MINIX_2.3.5.apk
    14.) New MINIX Metro launcher preloaded
    15.) Fixed XBMC MINIX Edition MP3 stuttering bug
    Note:
    Users using FW 008 or 009 shall receive the OTA push notice on the 2nd week of May,
    when office resuming from the National holidays here, thanks.
    Thanks and regards,
    Team MINIX.
    questo dovrebbe essere un file di aggiornamento, ma non ho capito bene che si deve fare
    Nov 2015
    Dear NEO X7 users,
    Download link:
    MD5 checksum:
    07/06/2014:
    Pure 1080P package:
    8.) Fixed OTG bug
    Note:
    Thanks and regards,
    Team MINIX.
  4. #13
    Dovrei avere la 4.2
    sei sicuro di avere il MiniX NEO X7 e non il mini questo fw 4.2 non l'ho mai sentito.
  5. #14
    Nov 2015
    Ho questo minix neo x7 4.2 é il sistema operativo la fw non so qual'è è bloccato
  6. #15
    Nov 2015
    questi sono i dati, dove trovo la fw?
  7. #16
    Quote Originariamente inviato da Thegig Visualizza il messaggio
    Android 4.2.2 Jelly Bean da quel che sono riuscito a leggere devi mettere i fw fino al 10 non il Kitkat, pero se se non riesce a partire non so come si possa fare, o torni al 7 oppure se conosci qualcuno che ha un pc con 7 ,ho provato anch'io con Windows 10 e nemmeno io riesco a collegarlo.
  8. #17
    Nov 2015
    Grazie veramente sei molto gentile
