Pagina 8 di 17 primaprima ... 678910 ... ultimoultimo
Visualizzazione dei risultati da 71 a 80 su 168
[ROM][5.1.1_R26][OFFICIAL] Resurrection Remix 5.5.9 Final Build [2015/11/06]
  1. #71
    Moderatore L'avatar di matteo0026
    Sep 2014
    Treviso
    Galaxy S2 Plus LG G2 Lenovo P2
    Ringraziato 590 volte in 507 Posts
    Nel nuovo aggiornamento versione 5.5.4 c'è un grande changelog che ve lo copio di seguito
    - Proximity Speaker
    - Add three-fingers-swipe to screenshot
    - Restore default rr wallpaper
    - Themes: don't recreateDefaults on typeface when locale changes
    - Revert "Barrier only messages shouldn't prevent the idle handlers from running
    - base: don't refresh visualizer tile once the tile is destroyed
    - SignalStrength: Allow for custom signal buckets in LTE
    - Disable PIN entry after successful quick unlock
    - Fix forcing media stream control on tablet
    - Removed Anti-Piracy Support
    - systemui: Provide empty view for empty lists published in QSTile
    - audio: Playback over USB DAC connected before boot
    - [ActivityManager] Bring up Service if not schedule to restart
    - PBD: Apply the same emmc discard logic as ext4_utils
    - SystemUI: fix empty notification space in shade_locked
    - Keyguard: Don't show keyguard if CryptKeeper enabled
    - SystemUI: add missed super window calls
    - Buttons: Allow setting default long-press app switch behavior
    - Lockdown AM.getRunningAppProcesses API with permission.REAL_GET_TASKS
    - Fix telephony property access for CDMA rewrite rules in PhoneNumberUtils
    - National roaming info for new Tuenti MNC in Spain
    - Fix intent resolution of default preferred apps
    - PhoneWinowManager: resolve home car intent
    - Themes: Theme power off and reboot dialog
    - Expose color values for battery saver icons
    - Fix DT2S on navbar after SlimDim
    - Battery saver enhancements (update)
    - Keyguard: Stop fingerprint auth when not showing
    - Fix StrictMode violation during getDefaultApn()
    - AppOps: fix delete ops wrongly matched issue
    - frameworks/base: synchronize surface control object access.
    - frameworks/base: Fix ContentService JNI leaks
    - Fix memory leak in AAPT
    - Make MANAGE_DOCUMENTS permission signature|system
    - LockPatternUtils: add a static way to retreive pattern from string
    - Keyguard: Fix scramblepin logic
    - Revert "AdBlock
    - Fix NPE with WeatherStatus on KeyguardStatusView
    - SystemUI: update to use new Profiles LockSettings obj
    - systemui: Support remote expanded style.
    - SystemUI: Add support for external bitmap icons.
    - CaptivePortal : Ensure uri is not null
    - TorchService: add sysfs handling
    - autobrightness: Fix the brightness dialog is not work when first enabled
    - policy: Remove references of Profiles in android.policy
    - Settings: Disable Headsup floating by default
    - Settings: add a way to not localize zone selections
    - settings: add IMEI information to msim device status page
    - Device info: Remove IMEI info from SIM status
    - Use correct icons for sound settings
    - Show "Lock screen & fingerprint" when supported
    - Expose values for themes.
    - Cleanup SoundSettings*
    - cmsdk: Dual SIM support on CM SDK
    - vendor/cm: Provide means of uploading an artifact to maven.
    - vendor/cm: Always use gpg sign-and-deploy for deployments.
    - APN: Update configurations for Philippine networks
    - Add new Tuenti MNC SPN override name
    - vendor/cm: Expose internal revision for platform.
    - apns: zero-length items are evil and break auto-selection
    - sepolicy: Allow recovery to set system properties
    - Add SettingsManagerService from cmsdk as a system service.
    - sf: Restrict GPU tile render feature to MAX_LAYER_COUNT
    - SF: Enable context priority
    - stagefright: Add libhwc to exynos include paths
    - stagefright: Add support for Exynos hardware audio decoding
    - stagefright: Don't crash on invalid / null AVCC atoms in MKV
    - MPEG4Extractor.cpp: handle chunk_size > SIZE_MAX
    - video: Disable resync markers
    - Includes All updates And Performance Updates From Cyanogenmod
    - For More Details Track Github Activity
    NUOVO REGOLAMENTOF.A.Q. DEL FORUMBBCODES
    Device:
    - Galaxy S II Plus - nel cassetto
    - LG G2 D802 16 GB - touch rotto
    - Lenovo P2 - nel cassetto
    - BQ Aquaris X Pro
    Se sono stato d'aiuto, premete Grazie!
    Baby Droid L'avatar di VincyCapa98
    Andria
    Samsung Galaxy S2 Plus
    Scusate la domanda, continuerà anche lo sviluppo per Android Marshmallow? Comunque ROM ben fatta, ogni tanto c'è qualche piccolo lag qua e là, ma la uso da circa sei mesi senza particolari problematiche
    Ultima modifica di VincyCapa98; 08-09-15 alle 18:13
  4. #73
    Androidiano di Riferimento L'avatar di Rz95
    Puglia, Prov. LE
    Samsung GALAXY SII plus
    Ringraziato 176 volte in 125 Posts
    Quote Originariamente inviato da VincyCapa98 Visualizza il messaggio
    Domanda da caffè Point comunque android m o 6.0 é già in sviluppo anche per il nostro telefono più in là l avremo sicuramente
  5. #74
    Puglia, Prov. LE
    Buone notizie ragazzi si passa alla versione 5.5.5 e si passa ad official!!!
  6. #75
    Sep 2014
    Treviso
    Quote Originariamente inviato da Rz95 Visualizza il messaggio
    Come hanno fatto a questo punto a farla diventare official? Assurdo... Almeno per essere degna devono correggere quei fastidiosi bug
    Device:
    - BQ Aquaris X Pro
  7. #76
    Puglia, Prov. LE
    Quote Originariamente inviato da matteo0026 Visualizza il messaggio
    Se non sbaglio official vuol dire che il team ufficiale resurrection remix ci lavora direttamente, potrei aver detto una fesseria più tardi mi informo. Per chi interessa qui il changelog: https://gist.github.com/westcripp/8874051
  8. #77
    Sep 2014
    Treviso
    Official vuol dire principalmente anche che ci sono gli aggiornamenti ota
    Device:
    - BQ Aquaris X Pro
  9. #78
    Puglia, Prov. LE
    Sì mi correggo dalla v5.5.4 si potrà aggiornare via ota, cioè dalle impostazioni comodo!
    Ultima modifica di Rz95; 10-09-15 alle 14:25
  10. #79
    Sep 2014
    Treviso
    Sì mo correggo dalla v5.5.4 si potrà aggiornare via ota, cioè dalle impostazioni comodo!
    Dicono che non è affidabile... Mi chiedo che differenza ci possa essere...
    Device:
    - BQ Aquaris X Pro
  11. #80
    Zêna - Pianeta Genoa
    Mate 20 Pro
    Ecco....
    cerchiamo di informar"ci" presto.....
    ...per non dare indicazioni errate e titoli di Thread non conformi al vero
    ___________________
