Utente della settimana: 9mm con ben 3 Thanks ricevuti negli ultimi sette giorni
Utente del mese: megthebest con ben 19 Thanks ricevuti nell'ultimo mese
c'e` un modo per installare what's up su nexus 7?
    Inviato dal mio Nexus 7
    Senior Droid L'avatar di RealBearTears
    Apr 2011
    Localitā
    Vicenza
    Nexus 5
    Ringraziato 29 volte in 24 Posts
    Trovi una guida in rilievo in questa seziona, seguila e non dovresti avere problemi.
    Nexus 5 CyanogenMod 11
    Androidiano L'avatar di lesilent
    Feb 2010
    Io ho seguito questi passaggi (con una sim 'secondaria') e funziona da dio :
    Required apps -
    1. Whatsapp apk - WhatsApp for Android
    2. Appguard apk - SRT AppGuard | Backes SRT
    Using my Tablet
    Install whatsapp.apk
    Install appguard.apk
    Start up open/run appguard.
    Select "Secure a new app"
    Select "Whatsapp"
    Appguard will take you through 3-steps
    scan and secure application
    Uninstall existing application
    Install secured application
    Once the process is completed, within Appguard, you'll need to change Whatsapp Permissions by removing the setting for "Phone calls - read phone status and identity"
    Using my PC
    I downloaded/installed BlueStacks, it allows me to install and use Android Apps using my PC - Run Mobile Apps on Windows with BlueStacks :: Mobile Apps on PC :: Mobile App Player for Windows | BlueStacks
    I launched BlueStacks, looked for Whatsapp and installed the app from there (BlueStacks has its own "Android Play Store").
    At this point, Whatsapp is already installed in my PC (Using BlueStacks)
    Open Whatsapp, enter your phone number and verify.
    I was able to get the SMS with verification code and also able to receive the call with the code.
    Once we have the code, close Bluestacks (Do not enter the code there).
    Using my Tablet
    Open Whatsapp, at this point we are running the modified version ("Phone calls - read phone status and identity" removed)
    Enter same phone number (as the one we entered using Bluestacks).
    Try to verify, you will get error message "Failed to verify too many times..."
    If the verification code box is not there yet, click on menu (three-dots) and select to enter the Verification Code.
    Enter the code you got a few minutes ago via BlueStacks.
    You should be able to use whatsapp using your tablet at this point.
    Non ci riesco quando metto il numero di telefono dice che non va bene
