[ROM][Gingerbread 2.3.5][AOSP]Villain_Au
Villain_Au
Non si risponde dei danni che può provocare la rom al telefono o ai supporti: ognuno la installa a suo rischio e pericolo.
A lot of you like the clean interface, the stability, the speed, the battery life and the fact that everything just works with Villain_Au, so we are continuing to update it.
Villain_Au 3.3U1 was released December 2011 and Villain_Au 3.2U2 was released 18 January 2012. Both DT and PC versions will work with CM7 rc2 Hboot, but DT version is best with alternate Hboot.
All props go to Richard Tripp and several other people over at XDA for this ROM. Richard has a support site on XDA
Talbess has added better APN’s for Australian Telco’s and made the changes required for the ROM to work with Telstra if you are in Australia (this doesn’t affect the use of VillainROM with other Telco’s). The default Launcher has been changed to LauncherPro. Talbess has a support site on Whirlpool
Credits and Thanks go to
- Richard Tripp
- Kali
- deovferreira
- Cyanogen
- ChainsDD
- IntersectRaven
- Jesus Freke
- tkirton
- PClaren
Villain_Au 3.2 Update 1 changelog Note: This update contains everything that is in GingerVillain 3.3 release.
codice:
Update voicesearch to 2.1.4
Battery green on 100%
Added more languages to keyboard
Fixed Google Voice Search fc
Fixed torch toggle in notificationbar
Update to cm 7.1
USB Speedfix
What’s in Villain_Au
codice:
GingerBread 2.3.5 AOSP, superb battery life
CM7 Launcher replaced by LauncherPro – we encourage users to purchase LauncherPro Plus unlocker – its well worth the small price asked!
Multilingual
Google Apps (including Market)
Apps2SD (DT-A2SD+ or PC-A2SD+ your choice)
Titanium Backup
Superuser
Telstra (Australia) User Agent strings and correct APN’s for Australian users
Moved ROMS-Au bootanimation to SD Card
Fully optimised CM7 Hboot version available (thanks to PClaren)
Installation Instructions (coming from non-Villain ROM)
- Use Titanium backup to backup all your apps in your current ROM
- Boot into recovery and do a nandroid backup of your current ROM
- Do a full wipe then Flash this ROM, then reboot
- Use Titanium (its included in the ROM) to restore your apps. The following apps have been tested to work fine if restored this way:
- Handcent (App + Data)
- Dialer One (App + Data)
- Beautiful Widgets and Animation add-on (App only)
- QuickBoot (App only)
- Loquendo TTS Susan (App only)
- MeContacts (App + Data)
- VoiceCallerId (App only)
- WirelessScheduler (App + Data)
- XMNotes (App + Data)
- Business Calendar Free (App only)
Installation Instructions (Coming from previous Villain_Au)
- Do a nandroid Backup to be safe
- Try Cache Wipe, Dalvik Wipe and flash Villain_Au, this seems to work
- IF you have problems (like apps FC’ing) will most likely have to do a full wipe and re-install as detailed above
Recommended Apps (get them from the Market)
codice:
Handcent SMS (Its just better)
Dialer One (Dialer with more features that integrates well)
QuickPic (Fast Gallery that can exclude folders)
A2SDGUI (for DT version ONLY – lets you alter A2SD settings like moving Dalvik to SD Card)
Google Maps
Notes
codice:
JuiceDefender and SetCPU are not required – performance and battery life are Fantastic.
With DT version Dalvik Cache will take up space on “Internal storage” by default. You can change this using A2SDGUI
With PC version there are no user adjustable A2SD features and A2SDGUI is not required and doesn’t work
Check if any apps are installed on the SD Card, if so move them back to the phone (this is how A2SD works)
Anyone with n1 table, please load rom, then move the dalvik to sd card before flashing anything else on top!!
If you want to play around with themes, use the Ultimate Online Themes kitchen
If you can’t get root access after first install (Titanium complains for example) just do a reboot.
