[ROM][Gingerbread 2.3.3][sense 2.5+3.0]RCMix_Oz
    Androidiani Power User L'avatar di moss20
    Mar 2011
    LG Optimus 4x HD || HTC Desire
    Ringraziato 368 volte in 267 Posts
    RCMix_Oz
    Non si risponde dei danni che può provocare la rom al telefono o ai supporti: ognuno la installa a suo rischio e pericolo.
    RCMix_Oz is a mod of the Robocik RCMix ROM by Ozjubb
    A big thank-you to Robocik for letting me mod and re-distribute his work.
    RCMix_Oz contributors
    Capychimp, Seo, Snq, rmk, Ownhere, Muxeu, HomerSP, Coolexe, Baadnwz, Imilka, Neo, MrInsane, Ozjubb
    What’s in RCMix_Oz
    codice:
        Gingerbread Base – Ace S 2.36.405.8 WWE Release
        Kernel – snq is still no 1  v05 with all modules loaded
        Compass is working  thanks snq for that
        Camera and camcorder now is working, thanks snq for that !!!
        EXT2/3/4 support, Thanks to snq for that
        WIFI and BT works
        FM Radio works
        WIFI Tether works properly, unlike ALL AOSP based ROMS
        Virtuous autoinstall script by rmk, modded for our needs
        Streaming SD/HD works
        720p video playback works
        DivX playback works
        Even more settings in “Quick settings” tab.
        Enhanced power menu option
        Touchpad to unlock
        Touchpad to wake
        Sense 3.0 Kingdom Lockscreen with buttons
        New lockscreen wallpapers
        Busybox
        Sense 3.0 SMS/MMS application
        Sense 3.0 USB Menu
        Sensation Live wallpaper (preview not working, apply directly)
        Sense 3.0 Task manager (even in quick settings)
        Quick Office replaced by far better Polaris Office
        Chinese hand writing added should be fixed now
        Speed tweaks from baadnwz rom  thanks man.
        CM-style screen on/off animations
        Option to enable stock android lockscreen
        Desire S keyboard
        Livewallpapers from Nexus S
        Telstra UA String and APN support
        Beautiful ROMS-Au boot animation
    Ozjubb has a support pages on Whirlpool for InsertCoin_Oz and RCMix_Oz
    Robocik has a support site on XDA
    There are two versions of each rom, the A2SD+ version (requires the stock Desire Hboot layout) and the CM7 version (which requires you to have S-OFF on your phone and the CM7 Hboot/partition layout)
    For best performance I recommend using Ext4 for your Ext partition. If you are on Ext3 already you can just flash the following zip and it will re-format and align your Ext partition to Ext4 with no journaling. Please read the warning here before flashing the ext4 patch.
    It has been suggested that if you are coming from another Ext format (Ext2, Ext3) using this script that once you have flashed the ext_alignment script that you should reboot recovery before trying to flash a rom, I have never had to but people who have been having issues using the script may want to give it a try.
    Ext4-Alignment.zip
    Important Notes
    codice:
        Ext Partition MUST be 1Gb minimum for this ROM
        Phone will reboot it self 3 times the first time you boot, it is a process of installing the Darktremors A2SD script
        To save some battery change the wifi power settings.
        To make the battery last longer, turn off pocket mode in settings/sounds
    Downloads
    RCMix_Oz A2SD v2.0
    RCMix_Oz CM7 v2.0
    Ultima modifica di moss20; 04-03-12 alle 20:52
    HTC Desire | LG Optimus 4x | Samsung Galaxy Note 3 neo | Honor 9
    Mediacom Smartpad 810c | Qilive 97r
    MINIX neo X8
    Mar 2011
    riservato1
    MINIX neo X8
    Mar 2011
    riservato2
    MINIX neo X8
    Androidiano L'avatar di Sbarabau
    Aug 2010
    Mantova
    Nexus 5, HTC Desire
    Ringraziato 31 volte in 29 Posts
    E' stabile? E' da un po' che speravo in un aggiornamento della RCMixS a una versione più recente di Android, ma ormai Robocik ha abbondano il Desire (anche se nega ciò)
    Device: HTC Desire
    Rom: AceSMod v42 CM7 (modificata da me)
    Kernel: snq's kernel v06 2.6.35.10-g3f43272
    Bootloader: Alpharev 1.8 CM7
    Recovery: 4EXT Recovery Touch v1.0.0.3 Beta 8
    Radio: 32.56.00.32U_5.17.05.23
    RIL: HTC-RIL 2.2.0131HM
    Micro SD: Sandisk Mobile Ultra Micro SDHC 16GB (classe 6)
    Mar 2011
    ho ipotizzato io fosse android 2.3.5...
    comunque non l'ho testata,so che quelli di roms au fanno buone rom quindi l'ho postata...
    HTC Desire
    ROM miui 2.3.7c stable (by me)
    MINIX neo X8
    Aug 2010
    Mantova
    Nexus 5, HTC Desire
    Ah!! Io pensavo fosse ufficialmente Android 2.3.5... Allora mi sa che la rom sia rimasta ancora alla versione che aveva (e che ancora) la RCMixS, ossia la versione 2.3.3
    Ultima modifica di Sbarabau; 31-05-12 alle 16:41
    Device: HTC Desire
    Mar 2011
    ah ok..allora sarà ancora 2.3.3 visto che non viene menzionato un upgrade di android...correggo il titolo...
    MINIX neo X8
