CWMR – PSFreedom Mod r0.1 – HTC Desire Recovery Mod
La notizia riguarda la modifica Ps3
Riporto cosi come è scritta (sperando di poterlo fare):
My original problem with PSFreedom on the HTC Desire, was the rom that your were supposed to install, i didn’t like it, this method by Klutsh, means that you can run any rom that you wish and all you have to do is flash a modified recovery image, based on ClockworkMod v2.5.0.9, so easy to do
A quote from the source:
A custom recovery image for use with the PSFreedom PS3 exploit.
PSFreedom was written by KaKaRoTo to implement the original PS Jailbreak exploit, based in part on reverse engineering efforts by the PSGroove project.
Engineered to work with the MSM72K USB driver by DrMon.
Your PS3 must be running firmware 3.41 for this to work
Features:
Default Android features :
All features of ClockworkMod v2.5.0.9 recovery including ABD and Mass storage toggle.
PSFreedom:
A new menu-item called “PSFreedom settings” can be found in the main menu.
The menu-item will load a submenu allowing you to choose different payloads.
* Homebrew only: This is the standard payload without Blu-Ray emulation support. It does not allow you to play backups.
* Blu-Ray emulation: This is the standard payload with Blu-Ray emulation support, which allows you to play backups.
* Homebrew only with peek/poke: This is the same as “Homebrew only”, with additional peek and poke system calls. It is based on the PSGroove 1.1 payload.
* Blu-Ray emulation with peek/poke: This is the same as “Blu-Ray emulation”, with additional peek and poke system calls. It is based on the PSGroove 1.1 payload.
Usage on PS3:
* First shut your PlayStation 3 down and then flip the power switch in the back to off (on Slim models, unplug the power cable). Disconnect all USB devices (controllers, USB hard drives, etc.) from the PlayStation 3.
* Boot your phone into recovery mode, select “PSFreedom settings” and choose a payload.
* Now, plug your Desire into the front left USB port and flip the PS3′s power switch back to the on position (or plug it back in). Do not turn the PS3 on with the power button yet.
* For the next step, timing is important. You will need to push the power button and then almost immediately after press the eject button, as if drumming your fingers across the two buttons. When you are successful, the PS3 will take a bit longer to start up.
* When XMB loads, under the “Game” menu there will be two new options, ★ /app_home/PS3_GAME and ★ Install Package Files. Congratulations, you’ve jailbroken your PS3. You’re ready to install homebrew applications.
Installation on phone:
Flash recovery image using unrEVOked.
fonte: CWMR – PSFreedom Mod r0.1 – HTC Desire Recovery Mod | PS3Hax Network
io nn ho capito se per usare questa image recovery (che poi nn capisco cosa è ) devo installare una rom particolare o posso lasciare la froyo originale che ho....chi mi da delucidazioni?
Re: CWMR PSFreedom Mod r0.1 HTC Desire Recovery Mod
In poche parole trasforma il desire in una psp? O c'è bisogno della psp?
Sent from my HTC Desire using Tapatalk
[RISOLTO] Problemi flash recovery
Dargor
1)Per flashare la recovery o utilizzi l'unrevoked 3.21(più semplice),oppure tramite fastboot(in questo caso però dovresti prima sostituire l'hboot con uno S-OFF)
2)Si
3)Non ci sono problemi di compatibilità con le altre rom.
Grazie ancora. Un ultima cosa poi spero di aver finito di rompere le balle.
Sono appena andato ad informarmi sul costo di un hard disk della Western Digital solo che mi hanno detto che è formattato in NTSF. Ciò non mi va affatto bene. C'è modo di convertire questo file system in Fat32? Se si, mi potete reindirizzare a qualche "guida" o a qualche programma?
Grezie in anticipo
EDIT:
Mi sono informato sul File System Fat32. Ho visto che Windows riesce a formattarlo solo fino a 32GB mentre con linux si riesce a formattarlo anche con dimensioni maggiori. Se utilizzo questa seconda possibilità vado tranquillo? Ho installato Puppy linux su un vecchio computer che montava windows 98 SE; dite che con questo riesco a formattare tutti i 500GB? Se si, come? (Mi sa che sto andando Off Topic)
EDIT2:
Unrevoked3 si blocca al passaggio "waiting for root" e di conseguenza non mi flasha la recovery. I driver sono "unrEVOked modified USB driver" e ho l'hboot 0.80.
Ho provato a flashare anche dall'SDK tramite il comando "fastboot flash recovery recovery.img" ma si ferma dicendo "FAILED (remote:signature verify fail)"
EDIT:3
[RISOLTO] Bisognava cambiare hboot e mettere quello s-OFF. Dopo innumerevoli minuti di panico, ce l'ho fatto (GRAZIE XDA!)
Spero che la mia esperienza sia d'aiuto per il futuro
