[RECOVERY] RMD Recovery v1.0.1 -Basata su AmonRA 2.2.1-
    Androidiano VIP L'avatar di shakland
    Torino
    Samsung Galaxy S III
    Ringraziato 648 volte in 534 Posts
    Girovagando su XDA ho trovato questa recovery, dalle caratteristiche sembra interessante e per chi volesse provarla qui trovate tutte le info possibili e immaginabili
    LINK AL THREAD UFFICIALE DI XDA: ---> http://forum.xda-developers.com/showthread.php?p=15014920#post15014920
    Hi, this is recovery menu compiled from modifyed by my AmonRA v2.2.1 source.
    So differences:
    1. Ability to control recovery by volume buttons+power button or by track-pad
    2. Fixed OTA Support some SD-cards(Package not found error)
    3. Show's ROM that you use
    4. Show's Ext partition file system
    5. Full support of btrfs
    6. You can convert your fs to btrfs from menu
    7. All fs conversions without data loss
    8. Allow you to flash old zips
    9. Adds ROM name to backup name in nandroid backup
    10. Toggle signature verification as checkbox
    11. Customizable backup as checkboxes
    12. Extended reboot menu
    13. Fixed all wipes menus, and partition mounts
    14. Compiled by my kernel with btrfs support, and without unneeded modules and drivers
    Menu contents:
    Reboot Phone now
    USB-MS toggle
    Backup/Restore
    • Backup system
    • Restore system
    • Backup Google proprietary files
    • Restore Google proprietary files
    Flash zip from file
    • Choose zip from sdcard
    • [ ]Signature verification
    Wipe
    • Wipe ALL data/factory reset
    • Wipe /data
    • Wipe /cache
    • Wipe /sdcard/.android_secure
    • Wipe /sd-ext
    • Wipe Dalvik-cache
    • Wipe battery stats
    • Wipe rotate settings
    Partition sdcard
    • Partition sd card
    • Repair SD-EXT
    • Convert SD-EXT to ext2
    • Convert SD-EXT to ext3
    • Convert SD-EXT to ext4
    • Convert SD-EXT to btrfs
    Mounts
    • (Un)Mount /system
    • (Un)Mount /cache
    • (Un)Mount /data
    • (Un)Mount /sd-ext
    • (Un)Mount /sdcard
    Other
    • Fix apk uid mismatches
    • Move recovery.log to SD
    Power menu
    • Reboot Phone
    • Reboot Recovery
    • Reboot into bootloader
    • Power Off
    Changelog v1.0.1
    -Fixed "jump up" then you use checkboxes
    -Added support for rom that use ro.build.display.id
    -Fixed some typos
    -Removed Logo from background by default
    Downloads
    Standart version
    Themed versions:
    Cyan version:
    Green version:
    Custom version(by KotDroid request):
    You want another color theme? you can write what theme you wont
    So you must:
    1. Attach image for background
    2. And colors that you want(in RGB format like 255,255,255), supported color for:
    • text in bottom
    • text in top
    • menu text
    • menu text selected
    • menu selector
    And I'll do it)
    Ultima modifica di shakland; 25-06-11 alle 17:26
    Androidiano VIP L'avatar di sirio87s
    Jan 2011
    Lucera (FG)
    nokia. poi è arrivato android!
    Ringraziato 132 volte in 115 Posts
    ma è una Amon-RA con colori diversi... -.-' poi scusate ma per desire l'ultima versione non è la 2.0.1?? perché lui ha preso una recovery del N1 in versione 2.2.1 e l'ha 'portata' sul desire...
    USA I TASTI CERCA E THANKS!
    Torino
    Beh in alcune cose è diversa dalla amon, basta leggere le caratteristiche..puoi usare i tasti volume per spostarti nei menù, ti mostra la versione esatta della rom installata, pieno supporto al file system btrfs, menù di riavvio esteso...insomma la base è la amon ma le differenze ci sono!!
    Jan 2011
    Lucera (FG)
    bisogna vedere se funzionano tutte quelle funzioni nuove...
    Androidiano VIP L'avatar di scotch
    Nov 2010
    Ringraziato 29 volte in 28 Posts
    suppongo sia stato fixato anche il bug del restore che causa l'usb brick vero?
    Galaxy NOTE 4
    Il Thanks se qulcuno fa la gentilezza di rispondermi non lo dimentico mai
    Senior Droid L'avatar di nicks87
    Apr 2011
    Padova
    Samsung Galaxy S2 (HTC Desire)
    Ringraziato 48 volte in 35 Posts
    Quote Originariamente inviato da scotch Visualizza il messaggio
    eheheh qst sarebbe il fix più importante.......ma non mi pare ci sia tra le caratteristiche!!!
