Problema fotocamera
Ho un problema con la fotocamera, stavo fotografando un'auto e al momento di scattarla si è bloccato tutto. Non riuscivo a uscire dall'applicazione percio ho riavviato il telefono, dopo questo la mia fotocamera ha smesso di funzionate!
Ho provato a resintallare cyangen, installare il radio , installare un'altra rom ( htc sense ), wipe e altro.. ma continua a non funzionare!
Quando apro l'applicazione resta tutto nero e dopo un po esce "force close", dai log vedo questo:
01-03 16:34:38.381: ERROR/QualcommCameraHardware(1408): startCamera X: /dev/msm_camera/control0 open failed: No such file or directory!
01-03 16:34:38.381: ERROR/QualcommCameraHardware(1408): createInstance: startCamera failed!
01-06 19:30:08.938: WARN/HTCCamera(3124): onCreate()
01-06 19:30:09.018: WARN/IntentManager(3124): from class: com.android.camera.CameraEntry
01-06 19:30:09.018: WARN/IntentManager(3124): mRequestMode = RequestMode.Main, from Camera
01-06 19:30:09.018: WARN/IntentManager(3124): request name = null - RequestName.Unknown_General
01-06 19:30:09.018: WARN/IntentManager(3124): extras == null
01-06 19:30:09.068: WARN/HTCCamera(3124): onStart() - start
01-06 19:30:09.068: WARN/HTCCamera(3124): onStart() - end
01-06 19:30:09.068: WARN/HTCCamera(3124): onResume() - start
01-06 19:30:09.208: WARN/HTCCamera(3124): !!!! @@@@ broadcastStopVoiceRecording() - start
01-06 19:30:09.208: WARN/HTCCamera(3124): !!!! @@@@ broadcastStopVoiceRecording() - end
01-06 19:30:09.228: WARN/HTCCamera(3124): OnResume - reset UI, immediately set mMainLayout invisible
01-06 19:30:09.248: WARN/########## HtcSettingsReceiver ##########(3124): 2011-01-06 07:30:09 249(ms) onReceive-start
01-06 19:30:09.258: WARN/HTCCamera(3124): Block Capture UI - onResume(), and unblock after start preview
01-06 19:30:09.258: WARN/HTCCamera(3124): onResume() - mFocusingState = NO_FOCUSING
01-06 19:30:09.258: WARN/HTCCamera(3124): keyguard is not shown !!!!!
01-06 19:30:09.258: WARN/HTCCamera(3124): OnResume - set mWaitResetSettings to true
01-06 19:30:09.258: WARN/HTCCamera(3124): onResume() - end
01-06 19:30:09.368: WARN/HTCCamera(3124): $$$$$$$$$$$$$$$$$$$$$$$$$$$$$ surfaceCreated $$$$$$$$$$$$$$$$$$$$$$$$$$$android.view.SurfaceVie w$3@47a5f418
01-06 19:30:09.368: WARN/HTCCamera(3124): $$$$$$$$$$$$$$$$$$$$$$$$$$$$$ surfaceCreated $$$$$$$$$$$$$$$$$$$$$$$$$$$ start preview
01-06 19:30:09.368: WARN/HTCCamera(3124): $$$$$$$$$$$$$$$$$$$$$$$$$$$$$ surfaceChanged $$$$$$$$$$$$$$$$$$$$$$$$$$$ w=480 h=800
01-06 19:30:09.368: WARN/CameraThread(3124): CameraHandler Message - START_PREVIEW start mode0
01-06 19:30:09.368: ERROR/CameraThread(3124): open the Camera in start_camera_preview
01-06 19:30:09.368: WARN/CameraSwitch(3124): open main camera
01-06 19:30:09.368: WARN/CameraSwitch(3124): no file - can't switch camera
01-06 19:30:16.130: WARN/HTCCamera(3124): Unknown orientation !!!
Cosa devo fare? Sembra che si sono cancellati i driver ma non so se è quello il problema!
e' passato un po' di tempo quindi mi chiedevo se avevi trovato qualche soluzione, ho lo stesso problema :(
kermit136
Inviato in riparazone e hanno cambiato la scheda madre
ah, che tra le righe vuol dire che lo posso anche buttare?
