Visualizzazione dei risultati da 1 a 10 su 30
[ROM] [Sense 2.3.3] [14 maggio] WildHero-1.0 (SFM 1,0 Based)
    Androidiano L'avatar di shot84
    Jan 2010
    Hero - Sensation - One X - M8
    Ringraziato 30 volte in 26 Posts
    [ROM] [Sense 2.3.3] [20 maggio] WildHeroWWE-1.1 (SFM 1,0 Based)
    Known issues:
    Hardare issues:
    - BT (did my best to get BT working but this ROM really hates the Heros BT )
    - jogball notifications light
    - hotspot
    Gfx library incompatibilities cause many games to crash (haven't retested in version 1.2 but I doubt I fixed this).
    Generally I feel this ROM is not 100% stable. It might be stable enough for some to use as a daily ROM.
    Downloads:
    WildHeroWWE-1.2.zip (Android RTK)
    WildHeroWWE-1.2.zip (Desean)
    WildHeroWWE-1.2.zip (Multiupload)
    Imporant: Full wipe is necessary always! Even when coming from version 1.0. If coming from version 1.1 you can try without a wipe, but I highly recommend you do a full wipe anyway - this ROM is buggy enough as it is and not doing a full wipe can cause many additional problems.
    Optional updates:
    HTC Salsa lock screen and Reboot menu - New lock screen from HTC Salsa leak, and a menu to allow direct reboot to recovery and boot loader. If you have something personal against the reboot menu, use the lock screen update from the SFM. Personally, I prefer not to use the new lock screen as it seems to have a great lag when receiving calls.
    WildHero-1.0-RebootMenu.zip (works also on 1.2 but NOT on HTC Salsa lock screen) - Adds a reboot menu to boot into recovery and bootloader. I suggest flashing before first boot (in any case the first boot after flashing this will be longer than usual).
    Changelog:
    version 1.2
    * Fix google maps crash
    * Fix installation of apps to SD card
    * Possibly a bit more stable
    version 1.1
    Complete rebuild of the port, this time based on the WWE release.
    version 1.0
    Original build from the SFM 1.0 release.
    * FlyKernel 12a (camera is not 100% stable on LV)
    * Some hardware fixes: Wifi, Sensors, Lights (but not jogball), 5M in Camera
    * USB fix for 2.6.29 kernels (added in version 1.0)
    * Full app2SD
    * Superuser and busybox (fixed in version 1.0)
    * RTL fixes for hebrew (sorry the new version which supports Arabic is not ready yet for GB)
    * Teeter (how else can you know the G-sensor works )
    * HTC Hub (added and fixed in version 1.0)
    * Optional reboot menu
    Immagini allegate
    Ultima modifica di shot84; 25-05-11 alle 10:46
    Device: HTC U11
    Status: S-OFF Temp/S-ON with Cid 034
    Firmware: 2.33.401.19
    Recovery: T.W.R.P 3.2.1-0
    Rom: ViperU 2.3.0 STABLE
    Kernel: Stock
  2. Il seguente Utente ha ringraziato shot84 per il post:
    DocZ (14-07-11)
    Treviso
    Htc Hero (GSM)
    Ringraziato 62 volte in 56 Posts
    ottima segnalazione.... se riesco flasho gia' oggi... intanto e' tutto gia' downloadato. Kernel, rebootmenu e rom.
    Take Care...
    Buzz.
    AutomaticaTreBi
    Device: HTC Hero
    ROM:CronosGingerX 2.4.0
    Kernel: 2.6.29 EVO-Cronos
    Recovery: ClockworkMod 2.5.0.7
    Radio: 63.18.55.06SU_6.35.17.03
    Launcher: Zeam3.1.6
    ADOBE FLASH per HTC HERO compatibilità ROM
    ROOT+FLASH guida per il PRINCIPIANTE!
    Autor di GeosocialRadar.com
  5. #3
    Treviso
    Htc Hero (GSM)
    Davvero troppo acerba. Questo il primo giudizio, ma la terro' lo stesso qualche giorno.
    Giudizio scala 1-10
    Velocita': 4 (avvio applicazioni, apertura/chiusura dock, ritorno a Home cosi' lenti da farti perdere la pazienza)
    Grafica: 6/7 (il ritorno a sense, la brillantezza dei colori, rendono l'interfaccia davvero gradevole)
    Stabilita': 4 (troppo spesso ti compare la simpatica finestrella "attendi - termina" su QUALUNQUE applicazione provi ad avviare)
    Compatibilita': 2 (terrificante notare che, dopo il ripristino del backup anche dei soli SMS presi dalla Cyano basata su Andro2.3.4, poco dopo l'inserimento del PIN il terminale si riavviava automaticamente e COSTANTEMENTE! Ho dovuto wippare di nuovo e riflashare il tutto).
    Insomma..... sono stati decisamente troppo frettolosi. Ora ho installato CPU boost e settato la velocita' massima a 691, rispetto alla standard (che era attorno al 600), gia' qualcosina e' migliorato ma.... troppo poco. Il primo giudizio comunque resta abbondantemente insufficente.
    Take Care...
    Buzz.
    AutomaticaTreBi
    Device: HTC Hero
    Launcher: Zeam3.1.6
  6. #4
    Androidiano L'avatar di TheTarcior
    Mar 2011
    Ringraziato 63 volte in 30 Posts
    Ragazzi se si vogliono provare rom nuove è un conto, ma se si vuole cercare una rom da lasciare montata per godersi il device credo che non ne avremo mai una gingerbread... Gli sviluppi sono praticamente fermi, vuoi per la difficoltà a rendere tutto compatibile con un device un po datato come il nostro hero, vuoi proprio perché il nostro eroe oramai è troppo datato e i vari sviluppatori si interessano di roba più nuova. Ormai credo che conviene buttarsi -e rimanere- sulle varie froyo, io ad esempio ormai tengo stabilmente da moltissimo la cm 6 stabile, ho settato dei valori di cpu esagerati (Max 710, min 480) lasciando il kernel che monta "di serie" e và velocissima, è stabile e ho una sorta di sense grazie a: adwLauncher ex, senses theme, sense clock widget (si chiama così ma non è quello ufficiale, anche se praticamente è lo stesso) e altri widget che richiamano quelli made in htc come i contatti o i messaggi (consiglio a tutti di provare colorize widget).
    P.S.- lasciando la cpu min più alta del solito ho notato una maggiore reattività generale e la durata della batteria mi è addirittura aumentata! Credo che sia perché lasciandola troppo più bassa rispetto alla massima (tipo 120) il device la gira praticamente solo a schermo spento, poi va sempre "al massimo" (in effetti a 120 mhz non gira neanche i processi base come orologio o chiamate).
    ...mi sa che sono UN PELINO ot.....
    P.P.S. - Altro difetto delle froyo - ginger è l'orologio: mancano funzioni basilari come il cronometro e il conto alla rovescia (per me importantissimi per lo sport) e dover scaricare un cronometro a parte -fin'ora non ne ho trovato uno decente!- è una piccola ma fastidiosa rogna... Ho aperto un thread in proposito: se sapete qualcosa ditemi!
    Sorry for the big OT...
    Ultima modifica di TheTarcior; 16-05-11 alle 09:48
    very smart SONY XPERIA U white
    Sony Xperia™ Jelly Bean 4.1.2
  7. #5
    Jan 2010
    Che non sia stabile al 100%...lo vedo pure io!!!
    Ma posso confermarti che a differenza della cronos o della CM mi si "impalla" molto di meno.
    Il problema della finestrella Attendi o termina ogni tanto mi compare anche a me ma solamente con l'applicazione Maps Google.
    Per quanto riguarda le altre applicazioni....fino ad ora non mi hanno dato problemi!!!
    Cmq....avete notato che spettacolo il fastboot??
    Device: HTC U11
    Kernel: Stock
  8. Il seguente Utente ha ringraziato shot84 per il post:
    DocZ (14-07-11)
  9. #6
    Treviso
    Htc Hero (GSM)
    uhmmm.... piccolo ma DOVEROSO aggiornamento sul test personale.
    Ultilizzando Titanum Backup ho ripristinato:
    -Download 2.3.3
    -Gestore dei download 2.3.3
    -I miei caricamenti 1.5.13
    -GMaps
    (tutti backup fatti sotto cyano full 68)
    Improvvisamente e' diventato fluido, non impressionantemente veloce ma.... fluido. Insomma, voto velocita' attuale: 6 e mezzo/7
    Per la stabilita', idem come sopra, improvvisamente ha fatto un salto di qualita'... e senza reboot. Bah, non capisco a cosa sia dovuto, dato che il restore non era di niente di chissa' quanto importante, eppure....
    Sta rom, forse, e' meno cesso di quel che pensavo inizialmente e, anzi, potrebbe cominciare a piacermi.
    Per quanto riguarda la parentesi "stabilita' ginger" devo dire che cyano sta' lavorando molto bene e che non ho mai riscontrato grossi problemi con le sue releases nightly. In ultima ho testato la 68 e andava a meraviglia. Ho cambiato solo per la curiosita' di vedere di nuovo Sense dopo 6 mesi. Poi, si sa', ogni Hero reagisce un po' a modo suo alle ROM e non sempre tutti riscontrano gli stessi pregi o difetti.
    Take Care...
    Buzz.
    AutomaticaTreBi
    Device: HTC Hero
    Launcher: Zeam3.1.6
  10. #7
    Treviso
    Htc Hero (GSM)
    DANNAZIONE! In costante crush android.process.media (ovvero "Gestore dei download"). Succede solo a me? Se si allora ho capito una cosa, non dovevo ripristinare il backup di questo file preso dalla Cyano).
    Ogni tanto comunque e' lento come la peste.
    Take Care...
    Buzz.
    AutomaticaTreBi
    Device: HTC Hero
    Launcher: Zeam3.1.6
  11. #8
    Jan 2010
    Una volta flashata questa ROM...l'Ho lasciata originale così senza beckup di vari messaggi e impostazioni varie...e posso confermarti...ovviamente sempre parere personale...che l'unico processo che ogni tanto mi da problemi è quello di gmaps...
    Inviato dal mio HTC Hero usando Androidiani App
    Ultima modifica di shot84; 18-05-11 alle 14:30
    Device: HTC U11
    Kernel: Stock
  12. Il seguente Utente ha ringraziato shot84 per il post:
    DocZ (14-07-11)
  13. #9
    Jan 2010
    Risolto il problema del processo di Google Maps.....
    Basta non aggiornarlo e lasciare la versione che si trova nella Rom!!
    Aggiorno il Topic!!!!
    Device: HTC U11
    Kernel: Stock
  14. Il seguente Utente ha ringraziato shot84 per il post:
    DocZ (14-07-11)
  15. #10
    Treviso
    Htc Hero (GSM)
    Quote Originariamente inviato da shot84 Visualizza il messaggio
    Mi sa' che wippo e riflasho... troppi conflitti tra 2.3.3 e 2.3.4
    Magari riprovo un essenziale backup con mybackup, che e' meno puntiglioso e meticoloso di Titanum. Il "problema", se di problema si puo' parlare, e' che, senza ripristino di backup, si vanno a perdere tutti i salvataggi delle app installate e scaricate, con conseguente perdita di "save games" ad esempio, il che scoccia parecchio. Per questo avevo ripristinato il backup dei download e market.
    Dopo il wipe ed il nuovo flash risponde bene.... per ora.
    Ah, piccola chicca. A differenza di quanto letto anche su XDA, a me, HTC SYNC, FUNZIONA! Si connette al pc, viene rilevato e funziona alla grande. Cosa che, alla prima flashata con tutti i miei mille casini (generati al 90% anche da me), non accadeva. Molti utenti lamentano la mancata connessione fra pc e hero. IO NO!
    Ultima modifica di TheBuzz; 18-05-11 alle 23:24
    Take Care...
    Buzz.
    AutomaticaTreBi
    Device: HTC Hero
    Launcher: Zeam3.1.6
