Pagina 6 di 8 primaprima ... 45678 ultimoultimo
Visualizzazione dei risultati da 51 a 60 su 76
Agg Ufficiale HTC vodafone 24/02
  1. #51
    May 2009
    stavo seguendo la guida di http://www.batista70phone.com/2009/0...terminali-htc/ ma l' actyvesync prp non si collega col cell e quindi QMAT non mi inserisce il seriale della sd... ma se inserisco la sd direttamente nel lettore sd del pc???
    Jan 2010
    Non seguire quella guida!
    USA QUESTA!
    01. Download PSAS here
    It’s a demo version.
    02. Format your SD card to FAT32. Please keep in mind some brands of SD cards do not work.
    03. Use adb to run this command: adb shell cat /sys/class/mmc_host/mmc1/mmc1: */cid (in questo comando togli lo spazio prima dell' asterisco!)
    04. Copy the SD card cid code displayed after the adb command.
    05. Start PSAS and Click on Cyptoanalysis Tools > Crypto Toolbox.
    06. Look at the bottom, there is a text box (beside the “Reverse String” button) enter the SD card cid code you got earlier.
    Click on the “Reverse String” button, the result is reversed…
    Example: 532600bd227d9c0347329407514d5402
    07. Copy the reversed SD card cid code.
    08. Go to PSAS goldcard site here to generate your goldcard (yes it says for G1 but works for our Hero too).
    09. Enter your email. For the correct SD card cid code, you need to replace the first 2 characters to 00.
    Example: From “532600bd227d9c0347329407514d5402” to “002600bd227d9c0347329407514d5402”(in questo passaggio togli i primi 2 caratteri della stringa convertita e mettici 00)
    10. Click Continue and you will receive the goldcard.img in .zip format in your email.
    11. Go to your email, download the zip file and save it to a directory and unzip it to goldcard.img
    12. Download HxD Hex Editor from here
    13. Install and launch HxD Hex Editor program. (make sure you use "Run as Administrator" under Vista and win 7)
    14. Go to Extra tab > Open Disk. Under Physical disk, select Removable Disk (Must be your SD card), uncheck “Open as Readonly), click OK.
    15. Go to Extra again, Open Disk Image, open up goldcard.img which you’ve saved/unzipped earlier.
    Now, you should have two tabs, one is your removable disk, the other is goldcard.img. Press OK when prompted for “Sector Size” 512 (Hard disks/Floppy disks), click OK.
    16. Click on goldcard.img tab. Go to Edit tab > Select All, edit tab again > copy.
    17. Click on the “removable disk” tab. Select offset 00000000 till offset 00000170 (including the 00000170 line), click on Edit tab and then Paste Write.
    18. Click on File > Save. now you can exit the program.
    Se nn capisci qualcosa posta qui!
    Ultima modifica di canemotto; 05-03-10 alle 18:35
  4. #53
    Androidiani Power User
    Dec 2009
    Rimini
    domanda La SD una volta creata la godlcard puo' essere usata normalmente
    o per essere usata deve essere formattata
    è sufficiente la formattazione normale o serve altro per farla tornare alla normalita'?
  5. #54
    Senior Droid L'avatar di vlade
    Jan 2010
    gt-i9300, htc desire hd
    Ringraziato 38 volte in 32 Posts
    Quote Originariamente inviato da pol18 Visualizza il messaggio
    A dir la verità PER ORA non ne ho bisogno...ne avrò bisogno fra 15 giorni quando tornerà il mio magic 32b dall'assistenza xD
    Per fortuna si può rootare donut+perfect
    siete forti raga!!!
    attendo la wiki (anche su come creare la goldcard eh :P )
    sottoscrivo in pieno!! sono nella sua stessa condizione.. GRAZIE MILLE!!!!!!
    Convertiti ad Android: ho perso il conto!! il predicatore continua! ;-)
  6. #55
    Jan 2010
    Nella wiki ho inserito la GUIDA su come creare la GOLDCARD...se c'è qualche imprecisione ditemelo xkè l'ho creata velocemente da lavoro!!! Spero possa risolvere i vostri dubbi/problemi!
    X Linux33it: nn so se la Sd la puoi tenere così com'è o la devi formattare dopo che hai creato la Goldcard visto che io dopo aver rimesso tt a posto l'ho partizionata e quindi formattata.
  7. #56
    May 2009
    ho eseguito tt alla regola... ma arrivato al passo 4 della guida wiki mi dice (dopo aver caricato il sapping.img)... CID failed... perchè??? sarà problema di sd???
  8. #57
    Jan 2010
    Postami il tuo cid, il reverse cid, e il cid che metti x creare la goldcard.
  9. #58
    May 2009
    Finalmente tt riuscito... ho rifatto tt cn un'altra sdcard... adesso però si blocca alla guida introduttiva di android... mi chiede nome password ma nn si collega al server... quindi non mi fa andare avanti...
  10. #59
    May 2009
    Tutto risolto... ho installato un'altra rom... sono sl 5 min che posso cambiare qst rom e già ne ho cambiate na cifra... quale mi potete consigliare??? inoltre qua chiedono il wipe ma qnd vado nella sezione wipe della recovery mi escono 5 o 6 opzioni... quale devo premere???
  11. #60
    Baby Droid L'avatar di ster86
    Jan 2010
    lo so che questa ROM ufficiale ha il perfect SPL e poi è un casino tornare indietro, ma anche se è bello provare nuove ROM sperimentali, mi sono un pò scocciato di avere un infarto ogni volta che il cell decide di riavviarsi da solo, e ogni volta non so quello che può succedere, wipe spontanei, perdita solo dei dati ma app installate, perdita solo dei dati delle app... con le ROM non ufficiali si può davvero dire che è l'android che decide... e ora vorrei riprendermi il controllo
    prblemino: per usare questa RUU c'è bisogno dell' HTC Sync. Ho provato su 4 PC diversi, provato a scambiare i driver in tutti i modi tra quelli dell'HTC e dell'SDK, ma niente, non c'è alcun verso di far vedere il mio magic al Sync (ho su l'ultima Cyanogen, e dal pc riesco a fare tutto tranquillamente con adb e fastboot!)
    Qualche aiuto? suggerimento? informazione? sono 2 settimane che ho provato tutte le guide che ho trovato ma nulla... altrimenti l'ultima speranza che mi rimane è che ci sia qualche Androidiano di Roma che mi può far flashare dal suo PC
