Utente del giorno: bluemask con ben 7 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: bluemask con ben 11 Thanks ricevuti negli ultimi sette giorni
[ROM][32a][32b][3.22][Froyo] CM6-Minimou-4 (CM6-RC3 08/20/2010) + Nightly builds
    Mar 2010
    Ringraziato 42 volte in 40 Posts
    [ROM][32a][32b][3.22][Froyo] CM6-Minimou-4 (CM6-RC3 08/20/2010) + Nightly builds - xda-developers
    Ho notato questa simpatica rom comprensiva di nightly nella sezione magic di xda. Non l'ho ancora provata perchè oggi ho già flashato 2 volte e non ho voglia ma magari la nightly di domani la provo. Allego il contenuto del post in inglese per evitare la miriade di domande
    Minimou is a fully-functional, bloatware-free Froyo ROM for HTC Sapphire (32A/B) based on CyanogenMod
    If you come from CM6-Minimou-2, please read the changelog for version 3 below before upgrading
    Disclaimer
    This software is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    By installing this software on your phone, you are voiding the manufacturer's warranty. You have been warned.
    Features / credits
    - Based on CyanogenMod 6 RC3
    - Kernel: 32A: GM's 32A port (08/12), 32B: stock CM kernel
    - No unremovable bloatware (ROM Manager, AdFree, ...). You can install all that from the market if you want to
    - Built-in non-system apps can be uninstalled from System / Applications / Manage: LauncherPro (make sure to install another home before, otherwise your phone will be useless), Music, Email, Talk, YouTube, SpeechRecorder, Maps (updates only, working on it...)
    - Linpack: around 4.0 with JIT and compcache
    - Great battery life
    Known issues
    - Trackball doesn't light up when receiving an e-mail or message
    - Fashing after uninstalling a built-in application (such as Music) re-installs it
    Changes in version 4
    - LauncherPro upgraded to 0.7.6
    - Updated 32A kernel
    - New gapps
    Changes in version 3
    - LauncherPro upgraded to 0.7.4 and moved to /data/app. You have to backup your configuration to the SD card and restore it, and then reconfigure your widgets. Sorry for the annoyance, but I couldn't find a way to fix this.
    - Moved Music, Email, Talk, YouTube, SpeechRecorder and Maps to /data/app
    - Removed black theme (colors in CM Settings, read instructions)
    Changes in version 2
    - ADWLauncher replaced by LauncherPro
    - New kernel
    - JIT enabled by default
    Instructions
    Requirement
    - Radio: 3.22 (32A) (should work with 6.35 with some issues) / 2.22 (32B)
    - SPL: 1.33.2010
    - Recovery: Amon_RA Recovery 1.7
    Installation
    - Change your radio, SPL and recovery if necessary [[32A][HOW-TO] Upgrade to 6.35 Radio and 1.76.2007 SPL (Downgrade/Revert too!) - xda-developers (downgrade section)]
    - Download from the link below (put on the sd-card root)
    - Download cmparts_ui.xml to the sd-card root if you want the black notifications bar
    - Reboot in recovery (power + hold home)
    - Do a nandroid backup
    - Wipe unless you currently run CM6. Upgrading from CM 5.0.8 seems to work but with some issues
    - Install cm6-minimou-4.zip from the sd-card
    - Reboot
    - For black notifs: go in Settings / CyanogenMod / User interface / Tweaks extras and import from cmparts_ui.xml. You can change some other cool colors (like notifications drop-down) into Notifications colors
    - You can enable/disable compcache and JIT from Settings / CyanogenMod / Performance
    Notes
    - If you have issues please try doing a wipe before reporting them
    - Please report issues here before cyanogenmod's threads or forums, they might not be present in the original rom
    Download
    Releases and nightly builds, along with QR-codes, can be found at
    Index of /pub/android
    Alternative kernels
    If you want to overclock, I recommend dumfuq's oc614 kernel. The 710 version is very unstable.
    Extra wallpapers
    The wallpaper selection in LauncherPro is fairly small (read: there are only 2). If you want more, I recommend Mabilo Wallpapers, downloadable on the market or via this QR:
    Androidiano L'avatar di cicciofiume
    Feb 2010
    palermo
    la provero presto!! voglio vedereu na rom froyo dal vivo
    Phone ---------> htc magic Tim Black 32A
    Recovery ----> RA-magic-v1.3.2H
    ROM----------- Padron Froyo 1.7
    Se la mia risposta è stata utile per risolvere il tuo problema, "thanks"..premilo..a te non costa nulla, a me rende felice
