Pagina 1 di 2 12 ultimoultimo
Attenti alle custodie in silicone Brando
    Aug 2009
    Bondeno, FE
    Ringraziato 70 volte in 67 Posts
    Angry
    Ciao a tutti.
    Ho comprato da Brando la custodia in silicone per il mio Magic. Mi ero già servito da loro per svariati screen protector senza mai un problema.
    All'arrivo della custodia l'ho subito messa su ma ho notato che c'era qualcosa che non andava. Dopo ho capito cos'era: lo stampo non è quello del Magic definitivo, ma è per quello di preproduzione! (questo)
    Ho scritto a Brando:
    "Dear all, I received the silicon case for the HTC Magic I ordered some time ago. I chose Brando because I bought various screen protectors in the past and I always have been satisfied with them; as of course you know, your brand is well known and suggested from customers over the internet for its quality.
    I then was quite suprised in receiving a case/sleeve which is not fitting perfectly my phone. Basically, the sleeve form replicates the one of the very first magic prototype (see this photo as a reference, for instance, Photos: Hands-on with the HTC Magic Android phone | Crave - CNET where the two couples of buttons under the screen are like a unique line, and there is only one more button on the left bottom) instead of fitting the final design (like this: http://i.zdnet.com/blogs/htc_magic.gif )
    Is this the result of an error or are all of the cases you are selling the same shape? I found "HTC Magic / HTC Sapphire" written on the box, so I guess that it is supposed to be the "right" one.
    Did you receive any other feedback or claim on this topic?
    Awaiting for your comments," bla bla bla
    La risposta non ha tardato ad arrivare: "Hi, We are sorry about that. Yes, it only fits for the model WITHOUT the button on the right hand side. Please advise if you would like a refund. Sorry for the inconvenience."
    Ma il Magic della prima foto esiste anche come produzione di serie!?
  2. Il seguente Utente ha ringraziato maxilogan per il post:
    Aug 2009
    Si e viene venduto negli USA.
  5. #3
    Aug 2009
    Bondeno, FE
    Ma porc.. non lo sapevo
  6. Il seguente Utente ha ringraziato maxilogan per il post:
  7. #4
    Androidiano VIP L'avatar di riccapo77
    Jul 2009
    Prato
    samsung galaxy s4
    un consiglio se posso permettermi...io le brando le vendo abitualmente ne ho vendute svariate anche qui nel forum,okkio che in giro ci sono anche dei falsi,attenti a dove le prendete perchè rischiate se non sono originali di rovinare il display del vostro cellulare.
    w Android!
  8. #5
    Aug 2009
    Bondeno, FE
    Sì, so specialmente dei proteggi schermo ed in particolare su ebay, se non sbaglio.. comunque io l'ho preso da loro..
  9. Il seguente Utente ha ringraziato maxilogan per il post:
  10. #6
    Androidiano VIP L'avatar di nk02
    Mar 2009
    Ringraziato 506 volte in 260 Posts
    Quote Originariamente inviato da riccapo77 Visualizza il messaggio
    infatti il posto giusto dove prenderle è... il sito ufficiale
    oppure direttamente da te, ora che so che le vendi (ma tanto per il magic non vedo la necessità di una pellicola, l'ho preso al day one e ha zero graffi grazie alla custodia che ti dan nella scatola..)
  11. #7
    Jul 2009
    Prato
    samsung galaxy s4
    si infatti diffidate dei venditori cinesi...prendetele direttamente dal sito della brando opppure da me! che tra parentesi le compro direttamente li!
    saluti.
    w Android!
  12. #8
    Androidiano VIP L'avatar di elegos
    Jul 2009
    Ringraziato 153 volte in 120 Posts
    Non credo che tu debba criticare la Brando... se loro sono americani e vendono negli stati uniti dove quel modello viene commercializzato non è totalmente colpa loro, ma ti vengono incontro: Please advise if you would like a refund... quindi se credi che quel difetto sia rilevante, basterà contattarli per vedere come mandare indietro il prodotto (se te lo chiedono indietro) e farti ridare i soldi
  13. #9
    Senior Droid L'avatar di Ciocca86
    Jul 2009
    Ceprano
    Ringraziato 27 volte in 24 Posts
    ragazzi mi date il link per comperare questi accessori brando?
  14. #10
    Jul 2009
    Prato
    samsung galaxy s4
    hai un pm ciocca!
    w Android!
Discussioni simili
  1. Custodie
    Da mikiko nel forum Acer Serie Liquid Z
    Risposte: 70
  2. Custodie-Protezioni Galaxy
    Da SRRGalaxy nel forum Samsung Galaxy (i7500)
    Risposte: 60
  3. Cover in Silicone
    Da Morpheus nel forum Samsung Galaxy Light (i5700 Spica)
    Risposte: 8
  4. Custodie
    Da ciufflegend nel forum HTC Magic
    Risposte: 5
  5. Custodie Galaxy
    Da hood nel forum Samsung Galaxy (i7500)
    Risposte: 0
