[Recovery] [32A & 32B] [13-Dec-2009] RA-sapphire-v1.5.2
		É uscita la nuova recovery di Amon_Ra 1.5.2
Changelog:
			full ADB access in recovery mode
Busybox v1.15.2
HW-Key navigation (volume keys + CALL-ANSWER) option
Extended menu :
Reboot system now :: reboot your phone
USB-MS Toggle :: enable/disable USB mass storage (use when the phone is connected to your PC)
Backup/Restore (recovery partition not included!)
Nand backup :: Make a Nand backup
Nand + ext backup :: Make a Nand + ext backup
Nand restore :: Restore a Nand backup
BART backup :: Make a BART backup (Nand + ext)
BART restore :: Restore latest BART backup
Flash zip from sdcard :: Flash a zip update file from your sdcard
Wipe
Wipe data/factory reset :: Wipe /data and /cache
Wipe Dalvik-cache :: Wipe Dalvik-cache both on /data and ext
Wipe SD:ext partition : Wipe the ext partition on your sdcard
Wipe battery stats : Wipe the battery stats in /data
Wipe rotate settings : Wipe the sensor settings in /data
Partition sdcard
Partition SD :: Interactive SD partitioning
Repair SD:ext :: Repair the ext partition
SD:ext2 to ext3 :: Convert ext2 to ext3
SD:ext3 to ext4 :: Convert ext3 to ext4
Other
Fix apk uid mismatches :: Does extacly that
Move apps+dalv to SD :: Moves all apps and Dalvik-cache to sdcard (This will NOT enable apps2sd!)
Move recovery.log to SD :: Moves the recovery log file to your sdcard. (Use when you want more detailed recovery log information)
Scripts available via adb :
Nandroid v2.2.1 : enter "nandroid-mobile.sh" to start.
BART v1.0.1 (Backup and Restore Tool) : enter "utility" to start.
switchrom.sh V1.1 : enter "switchrom" or "u" to start.
sdparted v0.6 : enter "sdparted" to start.
Link Post XDA
ATTENZIONE!
Provando a flashare dalla MAlign ho rischiato di brikkare il telefono (read/write errors a centinaia flashando sia da ADB che da Fastboot che da Terminal)!
Per poterla installare io ho dovuto installare prima la RAV 1.6.2, poi flashare e poi con nandroid ripristinare la Malign.
Quindi occhio!
