[Rom] Azusa By CoBurn
    Senior Droid L'avatar di ser1993
    Dec 2009
    Colli del Tronto (AP)
    Ringraziato 18 volte in 11 Posts
    Ecco la Rom di Coburn,con la chicca di un super speed quando necessario attivando uno swap della memoria.Per fare ciò basta seguire una semplice guida e poi eseguire dei comandi con terminal emulator direttamente dal telefono. Ecco il ChangeLog:
    codice:
     Removed some sounds, ringtones, etc
    Tested it with swap file, bullet speed!
    Uses CoburnROM v1.6 core with boot from miki's ROM
    New Boot Screen (Azusa in Maid outfit from K-ON anime)
    Dream Theme (from HTC Dream/G1) default ringtone
    Flash-proof (no bricks on flash!)
    Sense UI enabled by default (may be removed in future releases)
    Per il download QUI
    Ecco la guida per il super speed (IN INGLESE):
    codice:
    Since Busybox has been installed in /system/xbin, you should be able to issue "busybox sh" to get a busybox prompt.
    How do I enable swap? Easy. AzusaROM comes with one loopback device, perfect for swap file. Here's the commands.
    Download and Install Terminal Emulator from the market.
    Once installed, do this:
    Code:
    $ su <enter>
    NOTE: Don't enter the <enter> part, that's actually a key press.
    You should get something like:
    Code:
    $ su
    su: access granted blah blah blah
    Now, we need to get busybox up and running. Enter this:
    Code:
    # /system/xbin/busybox sh <enter>
    ..busybox loads..
    When you see "/ #", that means you're in busybox's shell. Do the following:
    Code:
    / # dd if=/dev/zero of=/data/swap.swp count=32168
    ..wait until you get like 32168+0 records in, etc..
    / # losetup /dev/block/loop0 /data/swap.swp
    ..wait until done..
    / # mkswap /dev/block/loop0
    ..you should get something like setting up swapspace..
    / # swapon /dev/block/loop0
    Now, this will make AzusaROM swap out RAM that doesn't need to be accessed all the time. The swap can quickly fill, I filled up my 16MB Swap File in just a few minutes browsing the net. However, you'll get a boost of speed - Sense UI scrolling is smoother, and AzusaROM really feels fast.
    However, you will need to do in Terminal Emulator...
    Code:
    $ su
    ...when you want a speed boost, as the swap will be disabled at reboot.
    Necessario il wipe...Buon Lavoro!
    Dec 2009
    Ragazzi è appena uscita una nuova versione di questa rom...appena ho 2 secondi ve la posto!
    Mar 2010
    Ringraziato 94 volte in 76 Posts
    il super speed? cos'è?
    Mar 2010
    Iconia Tab A500 16Gb
    Quote Originariamente inviato da ser1993 Visualizza il messaggio
    Ciao .. sei riuscito a provare la nuova versione che menzionavi? com'é?
