Problemi installazione nuova recovery
Ciao a tutti, ho rispolverato il mio tattoo e volevo installarci una rom con gingerbread, il problema sorge quando vado ad installare la nuova recovery (quella di rom manager) 3.0.5, segui la guida segnalata su xda a questa pagina ma quando do il comando "flash_image recovery /sdcard/recovery.img"
dopo una schermata di errori di I/O ricevo il messaggio: error writing recovery: no space left on device
Ho già provato a dare adb remount ma l'errore rimane.
Dove sbaglio? Grazie per le risposte.
Aggiungo il prompt:
codice:
# flash_image recovery /sdcard/recovery.img
mtd: erase failure at 0x00000000 (I/O error)
mtd: skipping write block at 0x00000000
mtd: erase failure at 0x00020000 (I/O error)
mtd: skipping write block at 0x00020000
mtd: erase failure at 0x00040000 (I/O error)
mtd: skipping write block at 0x00040000
mtd: erase failure at 0x00060000 (I/O error)
mtd: skipping write block at 0x00060000
mtd: erase failure at 0x00080000 (I/O error)
mtd: skipping write block at 0x00080000
mtd: erase failure at 0x000a0000 (I/O error)
mtd: skipping write block at 0x000a0000
mtd: erase failure at 0x000c0000 (I/O error)
mtd: skipping write block at 0x000c0000
mtd: erase failure at 0x000e0000 (I/O error)
mtd: skipping write block at 0x000e0000
mtd: erase failure at 0x00100000 (I/O error)
mtd: skipping write block at 0x00100000
mtd: erase failure at 0x00120000 (I/O error)
mtd: skipping write block at 0x00120000
mtd: erase failure at 0x00140000 (I/O error)
mtd: skipping write block at 0x00140000
mtd: erase failure at 0x00160000 (I/O error)
mtd: skipping write block at 0x00160000
mtd: erase failure at 0x00180000 (I/O error)
mtd: skipping write block at 0x00180000
mtd: erase failure at 0x001a0000 (I/O error)
mtd: skipping write block at 0x001a0000
mtd: erase failure at 0x001c0000 (I/O error)
mtd: skipping write block at 0x001c0000
mtd: erase failure at 0x001e0000 (I/O error)
mtd: skipping write block at 0x001e0000
mtd: erase failure at 0x00200000 (I/O error)
mtd: skipping write block at 0x00200000
mtd: erase failure at 0x00220000 (I/O error)
mtd: skipping write block at 0x00220000
mtd: erase failure at 0x00240000 (I/O error)
mtd: skipping write block at 0x00240000
mtd: erase failure at 0x00260000 (I/O error)
mtd: skipping write block at 0x00260000
mtd: erase failure at 0x00280000 (I/O error)
mtd: skipping write block at 0x00280000
mtd: erase failure at 0x002a0000 (I/O error)
mtd: skipping write block at 0x002a0000
mtd: erase failure at 0x002c0000 (I/O error)
mtd: skipping write block at 0x002c0000
mtd: erase failure at 0x002e0000 (I/O error)
mtd: skipping write block at 0x002e0000
mtd: erase failure at 0x00300000 (I/O error)
mtd: skipping write block at 0x00300000
mtd: erase failure at 0x00320000 (I/O error)
mtd: skipping write block at 0x00320000
mtd: erase failure at 0x00340000 (I/O error)
mtd: skipping write block at 0x00340000
mtd: erase failure at 0x00360000 (I/O error)
mtd: skipping write block at 0x00360000
mtd: erase failure at 0x00380000 (I/O error)
mtd: skipping write block at 0x00380000
mtd: erase failure at 0x003a0000 (I/O error)
mtd: skipping write block at 0x003a0000
mtd: erase failure at 0x003c0000 (I/O error)
mtd: skipping write block at 0x003c0000
mtd: erase failure at 0x003e0000 (I/O error)
mtd: skipping write block at 0x003e0000
mtd: erase failure at 0x00400000 (I/O error)
mtd: skipping write block at 0x00400000
mtd: erase failure at 0x00420000 (I/O error)
mtd: skipping write block at 0x00420000
mtd: erase failure at 0x00440000 (I/O error)
mtd: skipping write block at 0x00440000
mtd: erase failure at 0x00460000 (I/O error)
mtd: skipping write block at 0x00460000
mtd: erase failure at 0x00480000 (I/O error)
mtd: skipping write block at 0x00480000
mtd: erase failure at 0x004a0000 (I/O error)
mtd: skipping write block at 0x004a0000
mtd: erase failure at 0x004c0000 (I/O error)
mtd: skipping write block at 0x004c0000
mtd: erase failure at 0x004e0000 (I/O error)
mtd: skipping write block at 0x004e0000
error writing recovery: No space left on device
