Pagina 35 di 50 primaprima ... 25333435363745 ... ultimoultimo
Visualizzazione dei risultati da 341 a 350 su 492
EMUI 3.0 b604 testata e funzionante su P7-L10
  1. #341
    No..., avevo la twrp ma ora non si apre piu neanche la twrp. Nella sd ho già messo tutto ( cartella dload con emui 3.0) ma ora ho il cell semi defunto
    Ho usato il vostro link nella prima pagina
  4. #343
    Oct 2013
    lg optimus g ,xperia x10 mini,
    Togli la sd e prova a metterci la b602
    il mio smartphone :
    lg optimus g : ROM stock 10h rooted
  5. #344
    Devo cercarla su google.....
  6. #345
    Oct 2013
    http://www.smartforum.cz/viewtopic.php?t=4199
    il mio smartphone :
  7. #346
    Quote Originariamente inviato da fili345 Visualizza il messaggio
    Grazie fili345, lo sto scaricando....ma dopo come faccio ad avviarla se non mi entra in nessuna recovery?
  8. #347
    Oct 2013
    In nessuna?
    il mio smartphone :
  9. #348
    E no nessuna.mi esce la schermata bianca del post precedente foto
  10. #349
    Oct 2013
    Download Huawei Extractor tool from*here,Open update.app with Huawei Extractor and extract next two images: RECOVERY and BOOT (you can do that by selecting those two images while holding CTRL button, then right click > Extract Selected),When extracted, rename those two images into "recovery.img" and "boot.img",Copy those two images into "platform-tools" folder of Android SDK,Run command prompt and go to "platform-tools" folder by using "cd" command,Start your phone into fastboot mode,Enter following command into command prompt: "fastboot devices" (without quotes), you should get your phone's serial number listed, if that's right, go to the next step,Enter: "fastboot oem get-bootinfo", it needs to say that your bootloader is unlocked. If it's not you need to enter the next command "fastboot oem unlock 1234567812345678", where "1234567812345678" should be replaced with unlock code that is unique for your device. Instructions which explain how to obtain unlock code for your device can be*found here,Flash your phone's recovery with "fastboot flash recovery recovery.img",Flash your phone's boot image with: "fastboot flash boot boot.img",After successful flashing of both images, turn your phone off by holding POWER button for a several seconds,Prepare*SD*card*on your PC by formatting*SD card*and copying "dload" folder of phone's firmware onto*SD card,After you insert*SD card*into phone, start your phone with "forced install" method by holding all three buttons on your phone.
    il mio smartphone :
  11. #350
    Oct 2013
    Ora ti do il link di kdz extractor
    il mio smartphone :
