Problema Maps
    Senior Droid L'avatar di Cecco
    May 2009
    Samsung Galaxy Nexus
    Ringraziato 77 volte in 43 Posts
    Problema Maps
    Salve ragazzi,
    ho provato la mia prima applicazione con le mappe di google maps, ma non riesco a visualizzare la mappa (quadratini grigi) nonostante abbia l'uses-permission di INTERNET e abbia la mia personale api-key.
    Posto il codice:
    public class GPS extends MapActivity
    private LocationManager lm;
    private LocationListener locationListener;
    private MapView mapView;
    private MapController mc;
    /** Called when the activity is first created. */
    @Override
    public void onCreate(Bundle savedInstanceState) {
    super.onCreate(savedInstanceState);
    setContentView(R.layout.map);
    mapView = (MapView) findViewById(R.id.mapView);
    mapView.setBuiltInZoomControls(true);
    //---use the LocationManager class to obtain GPS locations---
    lm = (LocationManager)
    getSystemService(Context.LOCATION_SERVICE);
    locationListener = new MyLocationListener();
    lm.requestLocationUpdates(LocationManager.GPS_PROV IDER, 0, 0, locationListener);
    mc = mapView.getController();
    @Override
    protected boolean isRouteDisplayed() {
    return false;
    private class MyLocationListener implements LocationListener
    @Override
    public void onLocationChanged(Location loc) {
    if (loc != null) {
    Toast.makeText(getBaseContext(), "Location changed : Lat: " + loc.getLatitude() + " Lng: " + loc.getLongitude(), Toast.LENGTH_SHORT).show();
    GeoPoint p = new GeoPoint((int) (loc.getLatitude() * 1E6), (int) (loc.getLongitude() * 1E6));
    mc.animateTo(p);
    mc.setZoom(16);
    mapView.invalidate();
    @Override
    public void onProviderDisabled(String provider) {
    // TODO Auto-generated method stub
    @Override
    public void onProviderEnabled(String provider) {
    @Override
    public void onStatusChanged(String provider, int status,
    Bundle extras) {
    Questo è l'xml:
    <?xml version="1.0" encoding="utf-8"?>
    <RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
    android:layout_width="fill_parent"
    android:layout_height="fill_parent">
    <com.google.android.maps.MapView
    android:id="@+id/mapView"
    android:enabled="true"
    android:clickable="true"
    android:apiKey="0uXHhhRqm2iW_YBAtU3-gL_nwXYgIZvf5RAB83w"
    <LinearLayout android:id="@+id/zoom"
    android:layout_width="wrap_content"
    android:layout_height="wrap_content"
    android:layout_alignParentBottom="true"
    android:layout_centerHorizontal="true"
    </RelativeLayout>
    Mentre il manifest:
    <manifest xmlns:android="http://schemas.android.com/apk/res/android"
    package="com.Childroid.UI" android:versionCode="1" android:versionName="1.0">
    <application android:icon="@drawable/icon" android:label="@string/app_name">
    <activity android:name=".Main" android:label="@string/app_name">
    <intent-filter>
    <action android:name="android.intent.action.MAIN" />
    <category android:name="android.intent.category.LAUNCHER" />
    </intent-filter>
    </activity>
    <uses-library android:name="com.google.android.maps"></uses-library>
    <activity android:name="com.prova.MAPS.GPS"></activity>
    </application>
    <uses-sdk android:minSdkVersion="7" />
    <uses-permission android:name="android.permission.INTERNET"></uses-permission>
    <uses-permission android:name="android.permission.ACCESS_FINE_LOCAT ION"></uses-permission>
    </manifest>
    Idee a riguardo?
    Ovviamente ho impostato i comandi nel eclipse.ini per la lingua in modo da non avere sempre 0,0 come coordinate.....
    Ultima modifica di Andrea; 28-02-10 alle 17:05
    GynLemon....m'hai fatto venì sete
    Senior Droid L'avatar di monossido
    Jul 2009
    Padova
    Ringraziato 17 volte in 14 Posts
    ora non ho sottomano le mie prove ma quella apikey mi pare strana...
    www.lorenzobraghetto.com <-blog
    monossido at lorenzobraghetto.com <- jabber/mail
    http://twitter.com/monossido <-twitter
    Administrator L'avatar di Andrea
    Nov 2008
    Nexus S, myTouch Slide 4g
    Ringraziato 880 volte in 323 Posts
    Anchio voto per la apikey
    Twitter @veke87
