Ciao a tutti,
ho cominciato a programmare con Eclipse ma avrei bisogno di qualcuno che mi seguisse passo passo, per farmi capire dove sbaglio, per esempio adesso continua a darmi errori che non capisco! Di conseguenza non posso testare l'app nel virtual device.
NOTE: This project contains Java compilation errors, which can cause rendering failures for custom views. Fix compilation problems first.
Exception raised during rendering: com.android.layoutlib.bridge.MockView cannot be cast to android.view.ViewGroup
Exception details are logged in Window > Show View > Error Log
The following classes could not be found:
- resources (Fix Build Path, Edit XML)
[2013-02-23 14:49:50 - Test] res\layout\Copy of activity_main.xml: Invalid file name: must contain only [a-z0-9_.]
[2013-02-23 14:49:52 - ShellFinder] Project has no project.properties file! Edit the project properties to set one.
[2013-02-23 15:18:50 - ShellFinder] Error in an XML file: aborting build.
LinkBack URL
About LinkBacks
Ultima modifica di micheleitcg; 23-02-13 alle
Rispondi quotando
