Non riesco a cambiare tmea
    Apr 2011
    Galaxy S3
    Ringraziato 116 volte in 31 Posts
    Salve a tutti è da due giorni che sbatto la testa per cambiare tema alla mia app! questo è il risultato adesso:
    Imagebin - A place to slap up your images.
    Volevo mettere il tema nero di ICS non so come si chiama ... ma non riesco
    values > styles.xml
    codice:
    <resources>
            Base application theme, dependent on API level. This theme is replaced
            by AppBaseTheme from res/values-vXX/styles.xml on newer devices.
        <style name="AppBaseTheme" parent="android:Theme.Black">
                Theme customizations available in newer API levels can go in
                res/values-vXX/styles.xml, while customizations related to
                backward-compatibility can go here.
        </style>
        <!-- Application theme. -->
        <style name="AppTheme" parent="AppBaseTheme">
            <!-- All customizations that are NOT specific to a particular API-level can go here. -->
        </style>
    </resources>
    Manifest.xml
    codice:
    <?xml version="1.0" encoding="utf-8"?>
    <manifest xmlns:android="http://schemas.android.com/apk/res/android"
        package="com.gianni.arduino"
        android:versionCode="1"
        android:versionName="1.0" >
        <uses-sdk
            android:minSdkVersion="11"
            android:targetSdkVersion="17" />
        <application
            android:allowBackup="true"
            android:icon="@drawable/ic_launcher"
            android:label="@string/app_name"
            android:theme="@style/AppTheme" >
            <activity
                android:name="com.gianni.arduino.Arduino"
                android:label="@string/app_name" >
                <intent-filter>
                    <action android:name="android.intent.action.MAIN" />
                    <category android:name="android.intent.category.LAUNCHER" />
                </intent-filter>
            </activity>
        </application>
    </mani
    res/values-v11/styles.xml
    codice:
    <resources>
            Base application theme for API 11+. This theme completely replaces
            AppBaseTheme from res/values/styles.xml on API 11+ devices.
        <style name="AppBaseTheme" parent="android:Theme.Holo">
            <!-- API 11 theme customizations can go here. -->
        </style>
    </resources>
    in values-v14/style.xml
    codice:
    <resources>
            Base application theme for API 14+. This theme completely replaces
            AppBaseTheme from BOTH res/values/styles.xml and
            res/values-v11/styles.xml on API 14+ devices.
        <style name="AppBaseTheme" parent="android:Theme.Holo.Light.DarkActionBar">
            <!-- API 14 theme customizations can go here. -->
        </style>
    </resources>
    Qualcuno puo spiegarmi passo passo come fare e dove modificare? non ci riesco proprio.
    Il tema che vorrei è questo http://technoleash.com/wp-content/up...g-Galaxy-W.jpg
    guardare l'immagine del centro!
    Grazie mille a tutti
    *** Non dimenticare il tasto Thanks ***
    [ROM][XXALF6] ●●● RoxRom ●●● [Online][SGS3] >>> HERE!
    Mio Sito Web: roxdragon.net
    Androidiano L'avatar di iClaude76
    Trento
    Galaxy S3, Nexus 7, G. Tab 2 7
    Nel file values-v14/style.xml, che viene richiamato quando l'app gira su dispositivi con api level 14+, basta modificare l'attributo
    con
  4. Il seguente Utente ha ringraziato iClaude76 per il post:
    roxdragon (24-03-13)
  5. #3
    Apr 2011
    Galaxy S3
    Miticoooooooooo! Sei un grande!
    Per quanto riguarda le tab?
    vorrei fare una cosa simile...
    https://encrypted-tbn0.gstatic.com/i...XkKNtR5vXQyhgQ
    CPU | CPU SCALING | ... ECC..ECC
    sapresti dirmi come fare??
    Ultima modifica di roxdragon; 25-03-13 alle 00:58
