Pagina 2 di 2 primaprima 12
Visualizzazione dei risultati da 11 a 11 su 11
Arresto anomalo applicazione
  1. #11
    Mar 2015
    Pubblico un po' di codice che forse può essere utile.
    DbHelper.java
    codice:
    import android.content.Context;
    import android.database.sqlite.SQLiteDatabase;
    import android.database.sqlite.SQLiteOpenHelper;
    public class DbHelper extends SQLiteOpenHelper {
        //Dati generali
        public static final String DATABASE_NAME = "db_rubrica.db";
        public static final int DATABASE_VERSION = 13;
        public static final String DATABASE_TABLE = "rubrica";
        //Dati relativi al database+
        // public static final String COLUMN_ID = "_ID";
        public static final String NOME = "NOME";
        public static final String COGNOME = "COGNOME";
        public static final String TELEFONO = "TELEFONO";
        // public static final String COLUMN_MAIL = "MAIL";
        //Stringa finale creata
        public static final String DATABASE_CREATE = "CREATE TABLE " + DATABASE_TABLE + " (" +
                COGNOME + "STRING PRIMARY KEY, " +
                NOME + "STRING,"+
                TELEFONO +  "STRING );";
        public DbHelper(Context context){
            super(context, DATABASE_NAME, null, DATABASE_VERSION);
        @Override
        public void onCreate(SQLiteDatabase db) {
            db.execSQL(DATABASE_CREATE);
        @Override
        public void onUpgrade(SQLiteDatabase db, int oldVersion, int newVersion) {
    PersonaManager.java
    codice:
    import android.database.Cursor;
     * Created by GianpaoloF on 14/10/2015.
    public class PersonaManager {
        private Context context;
        private DbHelper helper;
        private SQLiteDatabase db;
        public PersonaManager(android.content.Context context){
            this.context = context;
            helper = new DbHelper(context);
        //Open
        public void open(){
            db = helper.getWritableDatabase();
        //Close
        public void close(){
            db.close();
    Persona.java
    codice:
    public class Persona {
        private String cognome, nome, numero, mail;
        public Persona(String cognome, String nome, String numero, String mail) {
            this.cognome = cognome;
            this.nome = nome;
            this.numero = numero;
            //this.mail = mail;
        public String getCognome(){ return cognome; }
        public String getNome() {
            return nome;
        public String getNumero() {
            return numero;
        //  public String getMail() { return mail; }
        public String toString(){
            return cognome + " " + nome + " " + numero /*+ " " + mail + "."*/;
    MainActivity.java
    codice:
    import android.app.ListActivity;
    import android.os.Bundle;
    import android.widget.ArrayAdapter;
    import android.widget.TextView;
    import java.util.ArrayList;
    import java.util.List;
    public class MainActivity extends ListActivity {
        PersonaManager manager;
        List<Persona> lista = new ArrayList<>();
        TextView visualizza;
        @Override
        protected void onCreate(Bundle savedInstanceState) {
            super.onCreate(savedInstanceState);
            setContentView(R.layout.activity_main);
            manager = new PersonaManager(this);
            manager.open();
            faiCose();
            stampaCose();
            manager.close();
            final ArrayAdapter<Persona> adapter = new ArrayAdapter<>(this, android.R.layout.simple_selectable_list_item, lista.toArray(new Persona[0]));
            setListAdapter(adapter);
        private void stampaCose() {
            StringBuilder sb = new StringBuilder();
            for(Persona attuale : lista){
                sb.append(attuale.toString());
                sb.append("\n");
        private void faiCose(){
            Cursor cursor = manager.getPersoneSalvate();
            lista.clear();
            cursor.moveToFirst();
            while(!cursor.isAfterLast()){
                String cognome= cursor.getString(cursor.getColumnIndex(DbHelper.COGNOME));
                String nome = cursor.getString(cursor.getColumnIndex(DbHelper.NOME));
                String numero = cursor.getString(cursor.getColumnIndex(DbHelper.TELEFONO));
           lista.add(new Persona(cognome, nome, numero, null) {
                cursor.moveToNext();
