Utente della settimana: carotix con ben 8 Thanks ricevuti negli ultimi sette giorni
ZTE Nubia Z7max, problem with mobile data on stock 3.77
    Feb 2016
    Hi
    Last weekend I've installed stock rom 3.77 on Z7max and the problem is: my modem doesn't work, and I have no mobile data connection,
    I see a few possible ways:
    a) update just baseband 3.77
    b) go directly to LightX 3.77 (or CM12.1)
    c) go 3.22 (via nubia updater), next LightX 3.77 (or CM12.1)
    c) go mokee 6.0.1
    any hints?
    [EDIT]
    No hints, but I had some time
    So, option a) didn't work.
    Next tried option c) - installed 3.22 and then 3.77 LightX, unfortunately I stuck in some SIM Settings app. I could not leave it, and it was crushing.
    So, finally option c) worked with CM12.1
    Its a little slower then 3.77 (antutu on CM is 49k and on 3.77 51k), but everything is working
    Ultima modifica di WywernPL; 18-02-16 alle 18:32
