Utente del giorno: cladroid con ben 1 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: bluemask con ben 18 Thanks ricevuti negli ultimi sette giorni
Utente del mese: bluemask con ben 36 Thanks ricevuti nell'ultimo mese
Pagina 1 di 2 12 ultimoultimo
[ROM] [Z5S] [Android 6.0] CM 13.0 unofficial
    Androidiano L'avatar di Maegorn
    Mar 2016
    Lecce
    Nubia z5s
    Ringraziato 39 volte in 32 Posts
    [CENTER]Rom cm-13.0 for NX503A (Nubia Z5S)
    ONLY FOR MERGED PARTITION!
    If you dont know how to merge the partitions or if you don't know what i'm talkin' about, let's go and see THIS (post #2) guide written by Hackever!
    Rom in full development.
    What’s Working:
    • Camera (video in 4k, 120 fps, 240 fps and slow motion)
    • Flash led/torch
    • Gps
    • Geolocalization
    • Wifi
    • Audio
    • Mobile Data
    • Sensors
    • Bluetooth
    • Led Notification/Charger
    • Infrared
    • Display Color Calibration
    • Softkey
    • Double Tap To Wake
    • Otg
    What’s not working:
    • FM Radio (probably this feature will never be implemented)
    In order to enable File transfers:
    1 - Scroll down the status bar
    2 - Tap “USB for charging”
    3 - Select “File transfers”
    In order to enable contacts sync: (if it doesn't work)
    1 - Open settings->Apps->Menu button->Show system->Search google contact sync->Permission and enable the contact permission
    2 - Reboot the phone
    3 - Settings->Account->Google->Contact sync-> Disable and re-enable to force the sync
    In orden to enable Root permissions:
    1 - Settings -> About phone -> Tap 7 times on “Build number" in order to enable developer setting
    2 - Settings -> Developer Settings -> Tap on “Root Access” and select “Apps and ADB”
    Changelog:
    • 22/09/2016 Rel6:
      • Security Patch September 2016
      • Uptaded com.qualcomm.location
      • Fix offline charging animation
      • Improved wifi background scanning
      • Switchato back to 3.4.0 from 3.4.112 (more stability, more power saving, fix the bug "after a random call the screen doesn't turn on while you try to unlock the device")
      • Kernel: many patches
      • Sync cyanogen source code (22/09/2016)
    • 17/08/2016 Rel5:
      • Security Patch August 2016
      • Optimized battery management (standby mostly)
      • Changed charger animation
      • Add blur effect in lockscreen options
      • Improved led management
      • Kernel:some patches
      • Sync cyanogen source code (17/08/2016)
    • 20/07/2016 Rel4:
      • Security Patch July 2016
      • Improved IR Blaster service
      • Little patch for cpu & gpu
      • Sync cyanogen source code (20/07/2016)
    • 03/07/2016 Rel3:
      • Improved GPS signal quality (it's x20 times faster)
      • Fixed OTG
      • Patch for chinese mobile data
      • Add some i/o scheduler
        • sio
        • fiops
        • zen
        • tripndroid
      • Add cpu governor: ondemandplus
      • Little patch for memory allocation
      • Sync cyanogen source code (03/07/2016)
    • 26/06/2016 Rel2:
      • Fix a huge bug about mobile data
      • Improved audio quality
      • Added some governors
        • PegasusQ
        • SmartassV2
        • SmartMax
        • SmartMax_EPS
      • Sync cyanogen source code (26/06/2016)
    • 22/06/2016 Rel1: (From now on i will only support merged partition version)
      • adaptation to merged partition
      • Update filesystem algoritm for f2fs e ext4
      • Sync cyanogen source code (al 22/06/2016)
    • 13/06/2016 Beta1_2:
      • Stability kernel patch
      • Fixed some libs errors
      • Add CNE (improved wifi and moble data switch)
      • Sync cyanogen source code (13/06/2016)
    • 10/06/2016 Beta1: (Attention!! To let SD Card works properly you need to do a full wipe)
      • Security Patch June 2016
      • Some patches to perform better on some filesystems
      • Fixed Double Tap to Wake
      • Fixed SD Card (now it's read as internal storage)
      • Sync cyanogen source code (10/06/2016)
    • 31/05/2016 Alpha4:
      • Now the buttons' touch panel deactivate itself automatically when softkeys are enabled
      • Add some patches for audio and VOIP
      • Update Timeservice blobs
      • Update mpdecision
      • Fixati side buttons leds
      • Fixed the IR Blaster (not workin' in alpha3)
      • Sync cyanogen source code (31/05/2016)
    • 25/05/2016 Alpha3:
      • Big Patch for kernel
        • Updated to 3.4.112 version (previously was 3.4.0)
        • Add config_uid_cputime
        • Add memory pressure
        • Patched wifi driver
        • Patched adreno & cpu driver
        • Patched HZ and set to 300
        • And many other stuffs patched
      • Fixed the torch tile
      • Patch to increase mobile data power and strength
      • Add Gello (the new cyanogenmod browser made for qualcomm cpus)
      • Sync cyanogen source code (25/05/2016)
    • 15/05/2016 Alpha2:
      • Update wifi configuration
      • New Sepolicies
      • Zip flash time decreased
      • Support patch for OTG
      • Little patch for video driver
      • Some kernel patches (f2fs and xz compression)
      • Add headset icon on status bar
      • Sync cyanogen source code (15/05/2016)
    • 06/05/2016 Alpha1:
      • First public release
      • Security patch Maggio 2016
      • Sync cyanogenmod source code (06/05/2016)
    Download Rom: Cm-13.0
    If you enjoy my work you can offer me a coffee :
    Screenshots (under spoiler):
    Needed files for flash:
    31/07/2016: Release new TWRP_nosdcard
    Installation procedure :
    • Do a TWRP backup (if you want)
    • Wipe (only “cache” and “system” if you come form a 13.0. If you come from another custom rom, just full wipe)
    • Flash the rom’s zip from recovery
    • Flash the gapp’s zip from recovery
    • Reboot the device
    I release here my "MaxxAudio porting", (One Plus One equalizer),for those who have troubles with CM equalizer:
    Source Codes (Branch mm-6.0) : https://github.com/Maegorn
    I don't take any responsibility for any damage made to your device.
    Note:
    I thank Hackever that was my personal beta tester and fot the merged partition guide.
    I thank Paolothlw8 that answered and guided me through the right direction.
    And I thank BambooIV the developer who made all this possible.
    Ultima modifica di Maegorn; 25-03-17 alle 16:10
  2. Il seguente Utente ha ringraziato Maegorn per il post:
    Beto1990 (02-07-16)
    Mar 2016
    Lecce
    Nubia z5s
    Reserved 1
  5. #3
    Mar 2016
    Lecce
    Nubia z5s
    Reserved 2
  6. #4
    May 2016
    Russia
    Nubia Z5S 32 gb
    A huge battery drain, 30-40% at night. Can you fix it in next updates?
  7. #5
    Mar 2016
    Lecce
    Nubia z5s
    Quote Originariamente inviato da SergMakarov Visualizza il messaggio
    i'm actually workin on battery saving
  8. #6
    Jul 2016
    Someone know if its possible unlock the 3G 900 band or the 4G bands in this phone?
  9. #7
    Mar 2016
    Lecce
    Nubia z5s
    Quote Originariamente inviato da Beto1990 Visualizza il messaggio
    No, it's not possible, modem is not compatible, me and other developers tried to set 4G, but lte doesnt work on this phone. it's an hardware problem
  10. #8
    Jul 2016
    So, the lte version have a different hardware?
  11. #9
    Mar 2016
    Lecce
    Nubia z5s
    Yes, and this rom is compatible with Z5SN version too
  12. #10
    Jul 2016
    It's possible install xposed in this rom?
