Utente del giorno: absinth con ben 1 Thanks ricevuti nelle ultime 24 ore
Pagina 1 di 31 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
    original discussion (in italian):
    https://www.androidiani.com/forum/zt...nofficial.html
    ONLY FOR MERGED PARTITION
    Hi all, after a long time I came back with a new rom
    it is a (multilanguage) CM12.1 Lollipop 5.1.1 entirely compiled by me, still it as some problems but is already usable
    what's working:
    camera
    flash led/torch
    gps
    wifi
    dual sim
    sensors
    nfc (maybe)
    Bluetooth
    led notification/charger
    FM Radio
    Infrared​​
    what's not working:
    let me know
    Download: CM12.1 (latest version: Release V23)
    changelog:
    • 11/11/2016 Release V23 (MD5: 61ceb2bd18918a549f04d8e01e2789b6)
      • Security patch November 2016
      • proprietary blobs updated from latest stock firmware 3.89 (with new camera driver)
      • sync cyanogen source code (11/11/2016)
      13/04/2016 Release V22 (MD5: 4dece2c33c639e64ba0ae60be362bb2d)
      • Security patch April 2016
      • proprietary blobs updated from latest stock firmware 3.84
      • sync cyanogen source code (13/04/2016)
    • 11/02/2016 Release V21 (MD5: 8879801ec683e3ca7a788c18e78a3835)
      • Security patch February 2016
      • proprietary blobs updated from latest stock firmware 3.77
      • sync cyanogen source code (11/02/2016)
    • 23/01/2016 Release V20 (MD5: 73d1d880fd85320868ca031f7d35dd75)
      • Security patch January 2016
      • proprietary blobs updated from latest stock firmware 3.73
      • sync cyanogen source code (23/01/2016)
    • 16/12/2015 Release V19 (MD5:5afe185865b962b5500f0280b5ccb04e)
      • added support for the smart cover
        to manage the cover I used an app created for the HTC dotcase (thanks to the author), adapting it to our device
        the cover is disabled by default and for the moment there is no option to enable/disable it. if you want to enable just flash the file (without any wipe) CM_EnableCover.zip (if you have it enabled and want to disable just flash the file CM_DisableCover.zip)
      • kernel: added support for dotcase
      • Security patch December 2015
      • proprietary blobs updated from latest stock firmware 3.68
      • sync cyanogen source code (16/12/2015)
    • 16/11/2015 Release V18
      • Including the latest Google security fixes of November
      • updated proprietary file (blobs) from latest stock firmware 3.65
      • sync cyanogen source code (16/11/2015)
    • 26/10/2015 Release V17
      • sync cyanogen source code (26/10/2015)
    • 08/10/2015 Release V16
      • source code updated to Build ID LMY48W (5.1.1_r24) (from LVY48F 5.1.1_r18)
      • Including the latest Google security fixes of October 5
      • updated proprietary file (blobs) from last stock firmware 3.61
      • updated baseband ver 3.61 (it can be downloaded here, flash without wipe)
      • sync cyanogen source code (08/10/2015)
    • 26/09/2015 Release V15
      • kernel: fix phone reboot when using usb or bluetooth mouse/keyboard
      • updated proprietary file (blobs) from last stock firmware 3.60
      • updated baseband ver 3.60 (it can be downloaded here, flash without wipe)
      • some optimizations
      • sync cyanogen source code (26/09/2015)
    • 21/09/2015 Release V14
      • Fix bug deleting photo in the gallery
      • updated proprietary file (blobs) from last stock firmware 3.59
      • updated baseband ver 3.59 (it can be downloaded here, flash without wipe)
      • sync cyanogen source code (21/09/2015)
    • 18/09/2015 Release V13
      • Fix V12 bootloop bug
      • kernel: updated with the latest codeaurora patches
      • fix for some selinux policy
      • sync cyanogen source code (18/09/2015)
    • 15/09/2015 Release V12
      • do not use, bootloop bug
      • updated app Nubia IRControl vers. 3.0.1.1011
      • kernel: added some patch to wifi driver prima/pronto
      • updated proprietary file (blobs) from last stock firmware 3.57
      • updated baseband ver 3.57 (it can be downloaded here, flash without wipe)
      • sync cyanogen source code (15/09/2015)
    • 06/09/2015 Release V11
      • updated proprietary file (blobs) from last stock firmware 3.56
      • updated baseband ver 3.56 (it can be downloaded here, flash without wipe)
      • sync cyanogen source code (06/09/2015)
    • changelog previous versions in the second post of the thread (here)
    flash instruction:
    first of all: backup all with twrp recovery
    download rom and gapps
    wipe:
    • upgrade from previous version
      • wipe cache and dalvik cache
    • new installation
      • full wipe (better do also format system)
    flash rom and gapps
    reboot
    The first boot takes a bit 'of time
    Root access can be enabled in developers options
    if you like my works you can offer me a coffe click
    screenshot (under spoiler):
    port Nubia camera stock 5.2.6 400dpi: NubiaCamera_5.2_V5.2.7_400dpi.apk
    port Nubia camera stock 5.2.7 440dpi: NubiaCamera_5.2_V5.2.7_440dpi.apk
    port Nubia camera stock 5.2.7 480dpi: NubiaCamera_5.2_V5.2.7_480dpi.apk
    port Nubia camera stock 6.0 400dpi: NubiaCamera_6.0_V6.0.0.85.2-CM12.1_400dpi.apk
    port Nubia camera stock 6.0 440dpi: NubiaCamera_6.0_V6.0.0.85.2-CM12.1_440dpi.apk
    port Nubia camera stock 6.0 480dpi: NubiaCamera_6.0_V6.0.0.85.2-CM12.1_480dpi.apk
    baseband repository (latest version 3.89):
    baseband_z7max
    Sources:
    device tree: https://github.com/PaoloW8/android_device_ZTE_NX505J
    vendor: https://github.com/PaoloW8/android_vendor_ZTE_NX505J
    kernel: https://github.com/PaoloW8/android_kernel_ZTE_NX505J
    Ultima modifica di PaoloW8; 26-11-16 alle 22:09
  2. I seguenti 7 Utenti hanno ringraziato PaoloW8 per il post:
    Andrea (25-07-15),Anna (24-07-15),BaSch83 (01-09-15),bubbl3 (23-07-15),leonbeson (26-07-15),LiveMoto (16-10-15),no1chan (03-08-15)
    Changelog:
    • 29/08/2015 Release V10
      • updated proprietary file (blobs) from last stock firmware 3.55
      • updated baseband ver 3.55 (it can be downloaded here, flash without wipe)
    • 25/08/2015 Release V9
      • fix camera bug (from release V8)
      • liblight: fix bug home led always on when the navigation bar is active and charging phone
      • Doubled the incall volume step (from 5 to 10)
      • updated proprietary file (blobs) from last stock firmware 3.54
      • updated baseband ver 3.54 (it can be downloaded here, flash without wipe)
      • optimization and various modifications
    • 21/08/2015 Release V8
      • bug: there is a little bug in setting preferred network type, after change all the options become gray and no longer be selected...simply go back and re-enter
      • Added screenshot tile in quicksetting
      • Doubled the volume step (from 7 to 14 for all volumes and 15 to 30 for the multimedia volume)
      • liblight: fixed the random Home led lit up brighter than normal
      • updated proprietary file (blobs) from last stock firmware 3.53
      • updated baseband ver 3.53 (it can be downloaded here, flash without wipe)
    • 18/08/2015 Release V7
      • Physical keys are now disabled/enabled when you enable/disable navigation bar (reboot required)
      • Added option for take screenshot with 3 fingers swipe from up to down (settings->display)
    • 12/08/2015 Release V6
      • Fix setting Preferred Network type (again)
      • Added option for show/hide headset icon in Settings->Status Bar
      • Added option for show/hide key navigation bar in Settings->Buttons (physical keys stay active)
      • kernel: set to default intelliactive governor (instead of interactive)
      • kernel: set to default westwood TCP congestion control (instead of cubic)
    • 07/08/2015 Release V5
      • fix touch bug synaptics touchscreen
      • fix recording call
      • kernel: update to 3.4.108 version
      • kernel: added several selinux patch
      • kernel: added and updated zram support (from kernel 3.10, disabled by default...can be enable with trickster mod or similar app)
      • kernel: added lz4 support
      • kernel: added exfat filesystem support (for external sdcard and usb key)
      • kernel: updated wifi driver
    • 02/08/2015 Release V4
      • Added option for adjusting intensity vibration in Settings->Sounds
      • Possible fix for LED Home button that occasionally lit up brighter than normal (to be tested better)
      • kernel: few optimizations
      • kernel: compiled with linaro toolchain 4.9 optimized for arm a15
    • 26/07/2015 Release V3
      • Fix wrong MAC Address
      • Added a option to show/hide the statusbar root icon (#) (in settings->Status Bar)
      • Added a option to show/hide exclamation marks on signal strength icons when there is no Internet connection (settings->Status Bar, this change is not in real time...to force the icons upate just enable/disable wifi or enable/disable airplane mode or simply reboot your phone)
      • sync cyanogen source code (finally has been added the option for enable/disable the data connection in settings->SIM cards)
    • 22/07/2015 Release V2
      • Added network speed indicator in statusbar (can be enabled in settings->Status Bar)
      • Implemented 3 battery mode profiles (in settings->battery):
        • balanced: governor interactive, freq min 300Mhz – max 2.45Ghz, GPU max 578Mhz (the default profile)
        • power save: governor conservative, freq min 300Mhz – max 1.57Ghz, GPU max 389Mhz
        • performance: governor performance, freq min and max 2.45Ghz, GPU 578Mhz
      • some optimizations and changes
    • 19/07/2015 Release V1
      • optimized source code (liblight) led keys (now it is almost perfect)
      • kayhandler added to manage the double tap to wake (I hope in some way help to fix the SOD bug)
      • added app IR stock Nubia translated into Italian, Russian, English and Chinese
      • reinserted the option "prevent accidental wake-up" removed by mistake in the beta3
      • fix saving settings LTE/3G/2G
      • changes in various configurations and optimizations
    • 16/07/2015 beta 3
      • fix led lights on menù and back button (sometimes one button still light on…I'm working on it)
      • add native multiuser support
      • disabled USB Mass storage connection (useless with emulated sd)
      • fix USB charging option
      • probable fix for mic in google search (need more tests, needed the new gapps that I have uploaded on mega tk_gapps-modular-nano-5.1.1-20150705-signed.zip)
      • fix setting LTE/3G/2G (for the moment is only a partial fix, after a reboot the setting return back to default value)
      • updated proprietary file (blobs) with last firmware stock 3.22
    • 14/07/2015 beta 2
      • fix thermal engine: increased performance (antutu score 43000~)
      • status bar: fix show percentage next to the battery icon​
    • 11/07/2015 beta 1
      • added double tap to wake feature (can be enable in settings->display)
      • fix restart/shutdown crash
      • fixed an issue that sometimes the gps stopped working
      • enabled some compile flag for optimization
    • 08/07/2015 alpha3
      • kernel:​ some tweaks
      • kernel: added some governor cpu
      • kernel: added some scheduler
      • kernel: added cpu voltage table
      • kernel: added LCD color calibration
      • (all kernel settings are configurable via Trickster Mod or similar app)
      • fix FM Radio​​​​​
      • fix Infrared​
    • 06/07/2015 alpha2
      • first public release
    Ultima modifica di PaoloW8; 26-09-15 alle 23:09
  5. Il seguente Utente ha ringraziato PaoloW8 per il post:
    BaSch83 (01-09-15)
  6. #3
    reserved 2...
  7. Il seguente Utente ha ringraziato PaoloW8 per il post:
    BaSch83 (01-09-15)
  8. #4
    Jun 2015
    Yessss finally!!!
  9. I seguenti 2 Utenti hanno ringraziato luiseteyo per il post:
    BaSch83 (01-09-15),PaoloW8 (23-07-15)
  10. #5
    Jan 2015
    Dublin (Ireland)
    ZTE Nubia Z7 Max
    Nice Paolo, this will really help international users
  11. Il seguente Utente ha ringraziato bubbl3 per il post:
    PaoloW8 (23-07-15)
  12. #6
    Androidiano L'avatar di LiveMoto
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Ringraziato 22 volte in 14 Posts
    Paolo, there is a proposal to issue a separate patch for your cyanogen, consisting of applications Phone and MMS, which are taken from the firmware YiOS. There's a choice of sim implemented to call or send messages. It is very convenient. Please see that this can be done.
    4PDA community from Russia
  13. #7
    taken from YIOS you mean the apk or there are the source code ?
  14. #8
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    Ofcouse, apk and lib.
  15. #9
    Jan 2015
    Dublin (Ireland)
    ZTE Nubia Z7 Max
    Quote Originariamente inviato da LiveMoto Visualizza il messaggio
    Source code would be much better as Paolo could just implement the needed code changes.
  16. #10
    is not a good idea
    the cyanogen team working on sources codes constantly (every day adjust, add, remove things)
    a precompiled system apk may stop working at any time
  17. Il seguente Utente ha ringraziato PaoloW8 per il post:
    bubbl3 (23-07-15)
