Pagina 2 di 2 primaprima 12
Visualizzazione dei risultati da 11 a 14 su 14
Nuova versione Z Launcher
  1. #11
    Napoli
    Note 4 SM-N910F; Cubot Power
    Ringraziato 156 volte in 136 Posts
    Rilasciata la versione 1.1.26-Beta
    ( di Nokia Apps LLC )
    Google play - Z Launcher Beta
    Novità:
    - Fixed the issue around some apps not being searchable and disappearing
    - Minor bug fixes
    - Performance Improvements
    Galaxy Note 8 SM-N950F DS > 3 con Super3 e CeVGuA + Gente di 3 OA + Naviga 3 Costo0
    Cubot Power > Iliad con minuti ed SMS illimitati + 30 GB € 5,99
    Napoli
    Rilasciata la versione 1.2.0-Beta
    Novità:
    - Bug Fixes
    - Drag and Drop to reposition your widgets
    - Long press on widget and release to Resize or Remove
    - Long press on widget page to start adding widgets
    - SWIPE LEFT for Widgets - Simply swipe left from edge of the ranked list to access widgets page
    - SWIPE RIGHT for A to Z App List - Swipe right from edge of the ranked list to access A to Z apps list
    - WIDGETS - Now you can add widgets to Z Launcher, the most requested feature from you
  4. #13
    Napoli
    Rilasciata la versione 1.2.17-Beta
    Novità:
    - Badging support for pinned apps expanded to WhatsApp and Gmail
    - Bug Fixes
    - Performance improvements, especially in loading apps
  5. #14
    Napoli
    Rilasciata la versione 1.3.1-Beta
    Novità:
    - Bug fixes
    - Contacts with WhatsApp now appear in scribble results and launch into the WhatsApp conversation. The more you do this, the more Z Launcher learns to promote these too!
    - Synonyms! An experimental feature that shows similar installed apps for your scribbled searches ( for example, search “music” and you’ll see Spotify and Pandora if they are installed )
