Pagina 2 di 2 primaprima 12
Visualizzazione dei risultati da 11 a 19 su 19
App per SMS non "spiona"
  1. #11
    Androidiani Power User
    Sep 2014
    Ringraziato 5,328 volte in 4,413 Posts
    Quote Originariamente inviato da Cesco67 Visualizza il messaggio
    Grazie per la risposta, però cerco un'app per gli SMS "tradizionali"
    Sullo store c'è l'imbarazzo della scelta.
    EDIT
    @Cesco67
    Di seguito i permessi che richiede Signal
    Questa app ha accesso a:
    Identità
    • find accounts on the device
    • read your own contact card
    • modify your own contact card
    Calendario
    • read calendar events plus confidential information
    • add or modify calendar events and send email to guests without owners' knowledge
    Contatti
    • read your contacts
    • modify your contacts
    Luogo
    • approximate location (network-based)
    • precise location (GPS and network-based)
    SMS
    • read your text messages (SMS or MMS)
    • receive text messages (MMS)
    • receive text messages (SMS)
    • send SMS messages
    • edit your text messages (SMS or MMS)
    Telefono
    • directly call phone numbers
    • read phone status and identity
    Foto/elementi multimediali/file
    • read the contents of your USB storage
    • modify or delete the contents of your USB storage
    Spazio di archiviazione
    Fotocamera
    • take pictures and videos
    Microfono
    • record audio
    Informazioni sulla connessione Wi-Fi
    • view Wi-Fi connections
    ID dispositivo e dati sulle chiamate
    Altro
    • send WAP-PUSH-received broadcast
    • receive data from Internet
    • view network connections
    • create accounts and set passwords
    • pair with Bluetooth devices
    • send sticky broadcast
    • change network connectivity
    • connect and disconnect from Wi-Fi
    • disable your screen lock
    • full network access
    • change your audio settings
    • read sync settings
    • run at startup
    • set wallpaper
    • use accounts on the device
    • control vibration
    • prevent device from sleeping
    • toggle sync on and off
    • install shortcuts
    Ultima modifica di complicazio; 16-05-19 alle 17:05
    Apr 2014
    Parma
    Ringraziato 128 volte in 94 Posts
    Quote Originariamente inviato da JuJu75 Visualizza il messaggio
    Signal è un'app per SMS tradizionali. Testata e funzionante senza nessun tipo di connessone, nè tantomeno ho riscontrato costi di invio da parte dell'operatotr (ho anche una promozione per gli SMS quindi non avrei dovuto pagare).
    Sotto spoiler il test.
    Prova invio SMS senza nessuna connessione ad Internet:
    Questo non lo sapevo, anche perché nella descrizione del play store non fanno menzione che possa inviare anche SMS tradizionali ma puntano sul fatto che i messaggi sono crittografati, cosa che non funzionerebbe con gli SMS
    Grazie della prova
    Edit
    EDIT
    @Cesco67
    Identità
    Calendario
    Contatti
    Luogo
    SMS
    • send SMS messages
    Telefono
    Fotocamera
    Microfono
    • record audio
    Altro
    • run at startup
    • set wallpaper
    • control vibration
    • install shortcuts
    Grazie delle info
    La maggior parte di quei permessi, per quello che mi riguarda, saranno da bloccare; per me è sufficiente la gestione degli SMS
    Riguardo il play store ci avevo dato un'occhiata ma non sono riuscito a capire quali app salvaguardano la privacy; per questo ho chiesto qui se qualcuno ne conosce
    Ultima modifica di Cesco67; 16-05-19 alle 19:31
    Smartphone personali: Nokia 6630, Nokia 5800, Huawei P6, Wiko Fever, Asus ZenFone Max Plus M1, Motorola Moto G6 Plus, Motorola Moto G32
    Smartphone aziendali: Blackberry Curve, Blackberry 9862, iPhone6, iPhone7
  4. #13
    Sep 2014
    Grazie della prova
    Edit
    Grazie delle info
    Bisogna vedere se bloccandoli l'app funziona.
  5. #14
    JuJu75
    E' l'app stessa che al primo avvio ti chiede se vuoi utilizzarla come app predefinita al posto di Messaggi
    Riguardo le autorizzazioni, tutte le app ne hanno bisogno per il loro funzionamento a 360°, anche se alcune potrebbero ritenersi inutili. E comunque, tutti gli sviluppatori di applicazioni che trovano spazio nel Play Store sono obbligati a inviare a Google un modulo di dichiarazione delle autorizzazioni in cui devono spiegare perché la propria app deve chiedere e utilizzare le autorizzazioni.
    Se Google ritiene che l'utilizzo di tali autorizzazioni non sia essenziale per l'app, il modulo viene respinto costringendo lo sviluppatore dell'app a modificarne e allo stesso tempo rimuovere quelle funzionalità dal proprio servizio per poter rimanere sul Play Store.
  6. Il seguente Utente ha ringraziato JuJu75 per il post:
    Cesco67 (16-05-19)
  7. #15
    Sep 2014
    Se il supervisore è Google siamo in una botte di ferro.
  8. Il seguente Utente ha ringraziato complicazio per il post:
    Cesco67 (16-05-19)
  9. #16
    Apr 2014
    Parma
    Ti ringrazio per le info
    Però alcune autorizzazioni chieste da signal non le capisco:
    - read calendar events plus confidential information
    - add or modify calendar events and send email to guests without owners' knowledge
    - approximate location (network-based)
    - precise location (GPS and network-based)
    - view Wi-Fi connections
    - connect and disconnect from Wi-Fi
    - disable your screen lock
    - toggle sync on and off
    Quando rientro in Italia lo proverò, ovviamente disattivando le autorizzazioni che ritengo inutili
  10. #17
    JuJu75
    Credo che le altre autorizzazioni servano in quanto l'app non si ferma solo ad inviare semplici messaggi di testo SMS, ma ha un ampio raggio di utilizzo (opinione personale). Comunque disattivando alcune delle autorizzazioni, al massimo non dovresti poter usufruire di quelle funzioni, che per il semplice SMS non dovrebbe influire (per esempio il Wi-Fi o il microfono ecc ecc)
  11. Il seguente Utente ha ringraziato JuJu75 per il post:
    Cesco67 (16-05-19)
  12. #18
    Sep 2014
    Come per tutte le applicazioni una volta installate puoi andare ad agire sulle autorizzazioni ma di solito ce ne sono alcune che richiede al primo avvio tipo contatti-media-chiamate che se non concesse compromettono l'utilizzo normale della stessa.
  13. Il seguente Utente ha ringraziato complicazio per il post:
    Cesco67 (17-05-19)
  14. #19
    Apr 2014
    Parma
    Aggiornamento, anche se un po' in ritardo...
    Ho installato Signal ma l'ho disinstallata subito perché mi ha chiesto il numero di telefono che avrebbe inviato a chissà chi per avere un codice di attivazione che avrei ricevuto per SMS
    No, non fa per me...
    Rinnovo la richiesta: qualcuno conosce un'app per gestire SMS che si fa i c@221 suoi? E possibilmente che faccia solo quello; non mi interessano gli MMS, le faccine, i temi, ecc.
