11.1.102.59
Novità:
-Adobe Flash Player 11.1.102.59 includes performance improvements and bug fixes related to security and stability. The complete set of release notes can be found at: Flash Player 11.1 and AIR 3.1 User Release Notes.
Novità:
ehh ormai saranno gli ultimi aggiornamenti... per poi lasciare il posto all HTML5... finalmente :-)
11.1.111.15
Novità:
-Adobe Flash Player 11.1.111.5 includes performance improvements and bug fixes related to security and stability.
La versione dipende dal dispositivo.
Per Android 4 ( IceCreamSandwich ) 11.1.112.61.
Novità:
-This update to Adobe Flash Player 11 includes compatibility with Android 4 supported devices, performance improvements and bug fixes related to security and stability.
11.1.111.6 Per Android 4 ( IceCreamSandwich ): 11.1.115.6
( Adobe Systems )
https://market.android.com/details?i...=search_result
Note di rilascio:
Release notes | End user | Adobe® Flash Player® 11.1 and AIR® 3.1
11.1.111.7 Per Android 4 ( IceCreamSandwich ): 11.1.115.7
( Adobe Systems )
Note di rilascio:
Rilasciata la versione 11.1.111.8 Per Android 4 ( IceCreamSandwich ): 11.1.115.8
( di Adobe Systems )
https://play.google.com/store/apps/d...FzaHBsYXllciJd
Rilasciata la versione 11.1.111.9 Per Android 4 ( IceCreamSandwich ): 11.1.115.9
Play Store - Adobe Flash Player
Novità:
This update to Adobe Flash Player 11 includes compatibility with Android 4 supported devices, performance improvements and bug fixes related to security and stability. The complete set of release notes can be found at: Adobe - Flash Player : Release Notes
Rilasciata la versione 11.1.111.10 Per Android 4 ( IceCreamSandwich ): 11.1.115.10
Rilasciata la versione 11.1.111.16
Novità:
