non sono molto pratico, anzi per nulla sono praticoe quindi ti lascio la spiegazione in inglese
OK, here's the booster. You need to use the kernel I uploaded on the OC/UV thread. Run it, it installs an event filter, plug in your headset, it will boost it (and show a message when it does.) Also boosts on removal, just to keep everything boosted. It will start on boot. Very tiny and doesn't do anything at all until you plug in your headset - then it just does its thing and goes back to sleep.
I've also attached the modified driver (as a .txt file...) so if any kernel people want to include this mod, they can. It's a pretty trivial patch which just finishing implementing the sysfs interface that LGE started.
Source for the app is included, naturally.
LinkBack URL
About LinkBacks
Rispondi quotando
Ultima modifica di snakkuzzo; 03-07-11 alle
