Pagina 10 di 13 primaprima ... 89101112 ... ultimoultimo
Visualizzazione dei risultati da 91 a 100 su 123
[GUIDA] Installare qualsiasi firmware con KDZ Offline Fix
  1. #91
    S22 Ultra,Find X2 pro,Mi 10
    Proviamo così. Scarica LG flash tools 2014 e prova la modalità cse/cs_emergency. Metti il kdz nella stessa cartella del tools.
    Sto Guidando (cit. Dieguccio)
    Apr 2015
    Sciacca
    Lg optimus l5 ii
    devo cancellare la riga dell host ? poi quale file della cartella kdz devo mettere nella cartella del tools?
    Edit 1: ti elenco gli errori che mi da il kdz
    09:52:03 : [C:\LGMobileUpgrade] Try to delete folder
    09:52:03 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
    09:52:03 : Start Date : 2015-04-25 09:52:03
    09:52:03 : ---------- QM Testmode ---------
    09:52:03 : ***** Check Tool Version *****
    09:52:03 : Tool version : 1.5.4.8
    09:52:03 : UpgradeDLL version : 1.2.6.7
    09:52:03 : Current Dir : C:\ProgramData\LGMOBILEAX\B2C_Client
    09:52:03 : LGE USB Driver Version :
    09:52:03 : Android PDLV Version :
    09:52:03 : Android NDLV Version : 3.13.0.0
    09:52:03 : ******************************************
    09:52:03 : [C:\ProgramData\LGMOBILEAX\Phone\DLL] Try to delete folder
    09:52:04 : [C:\ProgramData\LGMOBILEAX\Phone\LOG] Try to delete folder
    09:52:04 : [C:\ProgramData\LGMOBILEAX\Phone] Try to delete folder
    09:52:04 : SetEmerModeAT()
    09:52:04 : _IsConnectedPhone Call
    09:53:39 : _IsConnectedPhone(1)
    09:53:39 : 0 - NotConnected.
    09:53:39 : 1 - Normal connect success
    09:53:39 : 2 - Emergency connect success
    09:55:30 : _IsConnectedPhone Call for SmartPhone
    09:55:41 : _IsConnectedPhone(0)
    09:55:41 : 0 - NotConnected.
    09:55:41 : 1 - Normal connect success
    09:55:41 : 2 - Emergency connect success
    09:55:41 : *****CheckOS Start********
    09:55:41 : Microsoft_Windows7_Home Edition_
    09:55:41 : *****CheckPCSyncPrograms Start*****
    09:55:41 : PCSyncPrograms Not Found - OK and ready to upgrade
    09:55:41 : Checking the connection with the cell phone...
    09:55:41 : dwWaitResetTime(40000 ms)
    09:55:42 : _IsConnectedPhone Call
    09:57:17 : _IsConnectedPhone(1)
    09:57:17 : 0 - NotConnected.
    09:57:17 : 1 - Normal connect success
    09:57:17 : 2 - Emergency connect success
    09:57:17 : Phone Mode(1)
    09:57:17 : *****GetPhoneType Start*****
    09:59:20 : [011,700,147,062,092]Updating is not possible any longer due to a fatal error.\n\n[009,400,102,102,102]Disconnect from and connect the cable into your phone again and remove \nand install the battery and press the [009,700,102,102,102]'Restart'[009,400,102,102,102] button. This will resume the \nupgrade.\n\n\n\n\n\n\n\n\n\n\n\n\nPress the [009,700,102,102,102]Quit[009,400,102,102,102] button to stop the update. (_CheckPhoneType() Error)
    09:59:20 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
    09:59:20 : Page_Error ºÎºÐÀÔ´Ï´Ù
    09:59:20 : ¿©±â´Â Retry ºÎºÐÀÔ´Ï´Ù
    09:59:20 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
    Ultima modifica di GiuseppeLino; 25-04-15 alle 11:05
  4. #93
    Ma stai usando il flash tools 2014?
  5. #94
    Caserta
    P20 / P10
    Penso stia usando il materiale qui presente quindi kdz. Io non ho più il terminale ma uso ancora questa guida con f6, se ci sono altre strade indicate all'utente perché il suo terminale si trova al momento fuori uso.
  6. #95
    Apr 2015
    Sciacca
    Lg optimus l5 ii
    si ho usato anche kdz ma niente il pc riconosce il telefono ma i programmi no e non accendendosi perche ripeto resta bloccato sul logo brand vodafone non riesco ad attivare il debug come potrei fare help me!!
  7. #96
    Apr 2015
    Sciacca
    Lg optimus l5 ii
    allora mi potete dire che devo fare???????
  8. #97
    Quote Originariamente inviato da GiuseppeLino Visualizza il messaggio
    Ciao Giuseppe. Scarica il Flash Tools 2014 (il kdz già lo hai) Connetti il telefono al pc e sul programma metti CS_Emergency e poi CSE Flash.
  9. #98
    Apr 2015
    Sciacca
    Lg optimus l5 ii
    Lo fatto e va in crash il flash tool mi spunta ha smesso di funzionare ho provato con windows 7 home premium 32bit windows 7 ultimate 32bit windows vista home basic 32bit e windows xp professional sp2 32bit e mi fa sempre lo stesso errore su tutti questi sistemi operativi sull' xp se provo kdz mi da l'errore cmd "NESSUNA APPLICAZIONE ASSOCIATA AL FILE SPECIFICATO PER QUESTA OPERAZIONE CODICE ERRORE 80070483" che altro posso fare sono disperato
  10. #99
    Strano che va in crash il flash tools.
  11. #100
    Apr 2015
    Sciacca
    Lg optimus l5 ii
    oggi ho provato anche con win 8 pro e va anche qui in crash che posso fare???
