Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 20
[Rom][CM7.2]ICS Taste 2.1
    Mirandola
    LG Optimus sol (E730)
    Ringraziato 143 volte in 123 Posts
    CyanogenMod 7.2 "ICS Taste 2.1
    La ROM è basata su CM7.2 e quindi su Android Gingerbread. Sono state cancellate alcune app non necessarie e sono state integrate le GAPPS basilari e infine è stato inserito un tema in stile ICS.
    Caratteristiche:
    -Based on the last nightly compiled by NemesisQ3A
    -New kernel "Poogie H2o Kernel - Ginger edition" (Thanks to poogie!).
    -smartassV2 governor by default Min Freq: 122MHz Max Freq: 1200MHz.
    -Some kernel tweaks (specifically on smartassV2 governor).
    -100% SuperCharged! (Thanks to zeppelinrox!).
    -Fast Prior Scrolling.
    -Launcher Die-Hard.
    -Kernel Rock Hard.
    -Tewaks & 3G Enhancements.
    -Fix Emissions (Fix Permissions on boot).
    -Wheel Alignment (ZipAlign on boot).
    -Detailing (Cleaning database on boot).
    -OOM Grouping Fixes.
    -SuperMinFree (Adjusted values to the RAM of our device).
    -BulletProof Apps (MMS.apk and Phone.apk are bulletproof ).
    -KickAssKernelized! (Thanks again to zeppelinrox!).
    -Build.prop tweaks.
    -New theme (Thanks to InfusionNSK!) (Much better in appearance than the previous theme, but have two little visual bugs on the browser menu and on alarms, hope to have time to fix them).
    -Holo Launcher.
    -HD video recording Improvements (Better quality on audio and video).
    -Bravia engine (Improve the quality of the pictures).
    -XLoud (Improve the quality of the audio playback).
    -Optimized Adreno 205 libs.
    -Boot animation of the Nexus 7 (Android 4.1).
    -Wallpapers of Jelly Bean.
    -Sounds of CM10.
    -Right Baseband build in.
    Screenshots:
    Link alla discussione sul forum Cyanogenmod:
    [Mod Rom] Cyanogenmod7.2 "ics Taste" - LG Optimus Sol General - CyanogenMod Forum
    Link al download:
    CM7-ICSTaste-2.1.zip
    Versioni precedenti:
    2.0: CM7-ICSTaste-2.0.zip
    1.0: CyanogenMod7.2_ICS_Taste.zip
    Fixbug:
    flashare in recovery il seguente file http://www.mediafire.com/?0j38wy2c6o1b2ee
    Extras (Tutti i segunti extras si flashano dalla recovery o da rom manager, non serve fare essun wipe prima; installateli solo se realmente vi servono):
    Gtalk, Voice Dialer, VPN service, TTS Service: Gtalk-VDialer-VPN-TTS.zip
    (Non presenti nel Play Store)
    Email.apk: Email.zip
    Live Walpapers: LiveWallpapers.zip
    Tips:
    *Per evere delle buone performance/durata batteria usate queste impostazioni della CPU:
    CPU governor: SMARTASSV2
    Freq. min: 122 MHz
    Freq. max: 1200 MHz
    Set on boot: on
    Si consiglia di non modificare nessuna delle opzioni della Performance perchè la nuova versione è già configurata per avere le migliori performance.
    * To get a better scroll on drawer:
    -Press menu soft key, launcher settings, drawer settings, scroll cache, select None
    Grazie a Dorian X del forum Cyanogenmod
    Ultima modifica di lorevo; 24-11-12 alle 13:14
    Se la mia risposta ti è stata utile premi sul thank's
    Poco X3 NFC
    Baby Droid L'avatar di Fenmack90
    Nexus 6P - Nvidia Shield k1
    Il GPS come va? Io per sistemarlo sulla ROM di Poogie ho dovuto fare diverse modifiche che mi scoccerebbe rifare da capo. Se mi dite che anche il GPS lavora bene mi metto questa ROM oggi stesso
    Mirandola
    Quote Originariamente inviato da Fenmack90 Visualizza il messaggio
    Ancora non l'ho provato, ho appena istallato la rom...
    Poco X3 NFC
    Facci sapere allora
    friuli
    lg e730 sol
    Ringraziato 52 volte in 43 Posts
    Io l'ho appena installata e non mi va un granchè magari ho sbagliato di settarla perchè la lookscreen non è quella di ics lo scroll ha lag magari ho sbagliato io qualcosa sapreste darmi una mano??
    Io l'ho messa ieri sera e da allora è andata molto bene, premettendo che per il nostro dispositivo sembra ormai un utopia un software che lasci tutti contenti, questo per ora è uno dei migliore, forse come dici tu, lagga un po nello scroll ma dipende anche come l'hai caricato :P In ogni caso mi manca solo da testare il GPS ma per il resto è piacevole!
    friuli
    lg e730 sol
    Ma tu hai la lookscreen stile ics???
    Inviato dal mio LG-E730 usando Androidiani App
  9. #8
    Ho quello che fornisce Holo Launcher, dovrebbe essere lo standard di questa ROM, non so da quale versione di Android l'hanno preso :P
  10. #9
    friuli
    lg e730 sol
    Ragazzi ma a me i giochi vanno cmq a scatti a voi vanno fluidi??
    Sto iniziando a pensare che abbia qualcosa che mm va il mio cellulare
  11. #10
    Dipende quali giochi! Io ho dama, cruciverba, jetpack joyride, cose cosi vanno lisce a me tranne in momenti strani :P nonostante il dispositivo non sia male a livello hardware credo comunque che molti giochi di quelli recenti siano un po troppo.
