[Rom][CM7.2]Jellybred v1.0
    Mirandola
    LG Optimus sol (E730)
    Ringraziato 143 volte in 123 Posts
    [Rom][CM7.2]Jellybred v-1.1
    Jellybred v-1.1
    Rom basata su gingerbread con grafica ICS/JB
    Caratteristiche:
    V-1.1:
    - Added new boot animation
    - Increased performance (this will hopefully fix gaming experience, and the small lag present in previous version)
    - Cleaned up build.prop for e730 version
    - Updated Theme
    - Fixed DeskClock.apk
    - Thank you leolawliet for testing
    V1.0:
    - Initial Release
    - Jelly Bean Transition Animations
    - Centered Clock
    - Added tweaks for great speed
    - Tweaks for better browsing experience
    - Added Beats Audio (yes, there is a difference in the audio)
    - ICS/JB like Settings UI
    - JB Lockscreen
    - CM10 Theme
    - Custom Kernel for GB
    - EGL Patch
    And much more
    Grazie a medicjunKie del forum Cyanogenmod
    Link al download:
    V-1.1: Dev-Host - JellyBred-v1.1_E730.zip - The Ultimate Free File Hosting / File Sharing Service
    V1.0: Dev-Host - JellyBred-v1.0_e730.zip - The Ultimate Free File Hosting / File Sharing Service
    Link alla discussione sul forum cyanogenmod:
    [Rom][Gb] Jellybred-V1.0 [2.3.7] - LG Optimus Sol General - CyanogenMod Forum
    Tips:
    You might want to go to Settings/Cyanogen Settings/Interface/StatusBar tweaks
    And change the carrier name, for it won't show "T-Mobile" all crowded
    Flash this, in case you want to remover Beats Audio and restore DSPManager: Dev-Host - DSPManager.zip - The Ultimate Free File Hosting / File Sharing Service
    Ultima modifica di lorevo; 05-12-12 alle 18:35
    Se la mia risposta ti è stata utile premi sul thank's
    Poco X3 NFC
  2. Il seguente Utente ha ringraziato lorevo per il post:
    filecc (16-12-12)
    Mirandola
    Aggiornamento alla versione v-1.1
    Poco X3 NFC
  5. Il seguente Utente ha ringraziato lorevo per il post:
    filecc (16-12-12)
