Utente della settimana: megthebest con ben 17 Thanks ricevuti negli ultimi sette giorni
Utente del mese: megthebest con ben 47 Thanks ricevuti nell'ultimo mese
Pagina 1 di 2 12 ultimoultimo
[Kernel][Cm9]Andr00ib-Linaro V2
    Mirandola
    LG Optimus sol (E730)
    Ringraziato 143 volte in 123 Posts
    [Kernel][Cm9]Andr00ib-Linaro V8.0.1
    Questo è un altro kernel per rom basate su CM9; a differenza del kernel di Poogie questo presenta altri nuovi governors..
    Discussione ufficiale sul forum CyanogenMod:
    [Kernel] Cm9 Kernel-Linaro | Sio,vr And More To Come | Brazilianwax,smartassv2,smoothass - LG Optimus Sol General - CyanogenMod Forum
    e sul forum Xda:
    [KERNEL][ICS]Optimus Sol(e730) & Optimus MyTouch4G (e739) - xda-developers
    Changelog:
    V8.0.1
    -compiled with latest linaro 4.7 toolchain
    -changed to -03 optimization flags
    V7
    -fixed 1804 mhz cpu frequency sowing up
    -undervolted with -50 mv for 1.8 gzh, 1.7ghz ,1.6ghz ,1.5ghz ,1.4ghz ,1.2ghz ,1 ghz ,806mhz
    -undervolted with -25mv for 768 mhz, 368mhz, 122 mhz..
    V6
    -added zen ioschelduler
    -added ondemandx governor
    -added intellimand governor
    -added wheatley governor
    -added lionheart
    -undervolted a little more
    -fixed 1520 mhz cpu frequency
    V5
    -added aggressive governor
    -added gallimaufry governor
    -undervolted with 25mv for (1.8 ghz,1.7,ghz,1.6 ghz,1.5 ghz, 1.4 ghz,1.2 ghz, 806 mhz)
    -fixed "unkown" under settings problem
    V4
    -enabled Zram compresion (under Settings/Performance/Memory Management)
    -re-enabled KSM (under Settings/Performance/Memory Management)
    V3
    -added cpu OC up to 1.8 Ghz ( 1806 Mhz)
    -enabled AVS (adaptive voltage scaling)
    V2
    -added sio schelduler
    -added vr schelduler
    -fixed mass storage
    -fixed a bug related to keyboard
    V1
    -compiled with linaro-4.6
    -added smartassV2 guvernor
    -added smoothass guvernor
    -added interactiveX guvernor
    -added SavagedZen guvernor
    -added brazillianwax guvernor
    ~~~DOWNLOAD~~~
    V8.0.1: Dev-Host - andr00ib-linaro-e730-ICS-V8.0.1.zip - The Ultimate Free File Hosting / File Sharing Service
    V7 Dev-Host - andr00ib-linaro-e730-ICS-V7.zip - The Ultimate Free File Hosting / File Sharing Service
    V6: Dev-Host - andr00ib-linaro-e730-ICS-V6.zip - The Ultimate Free File Hosting / File Sharing Service
    V5: Dev-Host - andr00ib-linaro-e730-ICS-V5.zip - The Ultimate Free File Hosting / File Sharing Service
    V4: Dev-Host - andr00ib-linaro-e730_V4.zip - The Ultimate Free File Hosting / File Sharing Service
    V3: Dev-Host - andr00ib_linaro_e730_v3_oc_1.8.zip - The Ultimate Free File Hosting / File Sharing Service
    V2: Dev-Host - andr00ib_linaro_e730_v2.zip - The Ultimate Free File Hosting / File Sharing Service
    V1: Dev-Host - andr00ib_linaro_e730_v1.zip - The Ultimate Free File Hosting / File Sharing Service
    -Andr00ib
    -xpaum
    -MysteryEmotionz
    Ultima modifica di lorevo; 22-12-12 alle 11:35
    Se la mia risposta ti è stata utile premi sul thank's
    Poco X3 NFC
    Mirandola
    Aggiornato alla V3
    Poco X3 NFC
    Jan 2011
    per cm9 è meglio del kernel di poogie o è più o meno sulla stessa strada secondo te?
    Mirandola
    Quote Originariamente inviato da mity93 Visualizza il messaggio
    fino al v2 doveva essere molto simile, con qualche governor in più, la v3 dà la possibilità di overclock fino a 1800 mhz, chi l'ha provato è rimasto entusiasta dalle prestazioni, bisogna capire la batteria cone va... ripeto che mettere il device a 1800 è un overclock, con tutti i pregi e i difetti del caso... molti l'hanno usato a 1700 mhz e sono rimasti più che soddisfatti, ma bisogna testare la durata della batteria...
    Inviato dal mio LG-E730 con Tapatalk 2
    Poco X3 NFC
    Androidiano VIP L'avatar di -DM-
    Ringraziato 91 volte in 82 Posts
    incredibile però
    1800mhz...
    io ho avuto recentemente 4 device
    uno basato su omap 3630, due su tegra 2 e il quarto (il mio attuale i9250) su omap 4460
    se considerate che il mio omap4460 è nativo a 1500 e arriva massimo sui 1800...
    Device :
    LG Nexus 5X bianco
    Nexus 5 16 gb
    Mirandola
    Quote Originariamente inviato da -DM- Visualizza il messaggio
    incredibile però
    1800mhz...
    Già, 1800 mhz sono tantissimi, io ancora non l'ho provato, aspetto che siano un bel pò a testarlo , ma se non ci sono problemi andrà a bomba...
    Poco X3 NFC
    Senior Droid L'avatar di Loller7
    Sardegna
    LG Optimus G, LG G3
    Ringraziato 351 volte in 213 Posts
    Lo sto usando anche io questi giorni e devo dire che come prestazioni è eccellente e la batteria se la cava fino a fine giornata, come governor sto usando smartassv2 e l'ho overclockato a 1200 MHz.
  9. #8
    ma in quanto a riavvii?
    Device :
    LG Nexus 5X bianco
    Nexus 5 16 gb
  10. #9
    Sardegna
    LG Optimus G, LG G3
    Si riavvia solo qualche volta quando comincia a smadonnare la lock screen
  11. #10
    Mirandola
    Aggiornato alla V8.0.1
    Ultima modifica di lorevo; 21-12-12 alle 21:26
    Poco X3 NFC
