Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 16
[Rom][CyanogenMod10]Unofficial alpha
    Mirandola
    LG Optimus sol (E730)
    Ringraziato 143 volte in 123 Posts
    Ragazzi, visto che ormai lo sviluppo è a buon punto, rimangono pochissimi bug, posto la CM10:
    CyanogenMod10 Unofficial alpha
    note:
    il primo avvio è molto lungo, impiega più di un minuto
    per le google apps bisoga scaricare questa versione: gapps-jb-20121011-signed.zip da qui: Google Apps - RootzWiki
    ATTENZIONE: come in tutte le CM la connessione dati è abilitata di default, quindi se non si ha un piano piano disattivarla appena si avvia il terminale.
    Nè io nè lo sviluppatore della rom abbiamo responsabilità in caso di danni al terminale, flashare assumendosi tutte le responsabilità del caso.
    Changelog:
    Versione 24/02/2013:
    fixed sim pin issues
    Versione 04/03/2013:
    fixed unknown baseband
    compiled with 4.6 toolchain (previous releases was compiled with 4.3)
    stock jellybean camera works with minor bugs, no more need of jb+ camera
    both front and rear camera works
    video work UP TO 480p!!! don't even try 720p - both front and rear camera
    still no 3th party support (untested but i guess)
    Versione 10/03/2013:
    fixed error on copybit.msm7x30 and added a missing library
    removed unuseful cmupdater service
    removed unuseful hwaddrs
    Versione 28/06/2013:
    Experimental build based on jellybean-stable sources
    fixes the 720p recording with the included kernel, other kernels needs to be recompiled to support it
    jellybean lghome3+weather gadget (optional, you will be asked at the first start)
    lg bootlogo
    freed some kernel memory making the cifs and tun as modules rather than included in the kernel
    a total wipe is suggested before to install
    known bugs: camera panorama and 3th party app don't work properly
    Versione 15/07/2013:
    camera module now is compiled from sources, works with some 3th party app (skype for instance)
    got rid of the corrupted lg logo at boot, now it show a black screen before the bootlogo.
    everything else is same as in the previous release.
    known bugs: panorama mode don't work, many camera apps show Y inverted back camera
    Download:
    Versione 18/02/2013: DepositFiles
    Versione 24/02/2013: DepositFiles
    Versione 04/03/2013: Dev-Host - cm-10-20130304-UNOFFICIAL-e730.zip - The Ultimate Free File Hosting / File Sharing Service
    Versione 10/03/2013: Dev-Host - - The Ultimate Free File Hosting / File Sharing Service
    Versione 28/06/2013: Dev-Host - cm-10-20130627-UNOFFICIAL-e730.zip - The Ultimate Free File Hosting / File Sharing Service
    Versione 15/07/2013: Dev-Host - cm-10-20130714-UNOFFICIAL-e730.zip - The Ultimate Free File Hosting / File Sharing Service
    Link al Forum CyanogenMod:
    Unofficial Cm10 For Lge E730 **alpha Build** - LG Optimus Sol General - CyanogenMod Forum
    Tutti i ringraziamenti vanno a Shutt1e, nostro connazionale, del forum CyanogenMod per aer sviluppato questa rom.
    Ultima modifica di lorevo; 07-09-13 alle 16:15
    Se la mia risposta ti è stata utile premi sul thank's
    Poco X3 NFC
  2. I seguenti 3 Utenti hanno ringraziato lorevo per il post:
    Belgarath67 (08-03-13),calimerorosso (08-03-13),Lightwave (08-03-13)
    Jan 2011
    cosa significa "still no 3th party support (untested but i guess)"?? non posso installare app da SD??
  5. #3
    Mirandola
    Quote Originariamente inviato da mity93 Visualizza il messaggio
    no, devi leggerlo con la riga precedente, significa che la fotocamera stock funziona, ma non con le app di terze parti...
    Inviato dal mio LG-E730 con Tapatalk 2
    Poco X3 NFC
  6. #4
    Jan 2011
    a parer tuo questa cm10 è meglio della cm9? io non uso il telefono per giocare ma ascolto musica, controllo mail, facebook e magari se dio vuole uso il gps. fa al caso mio? con la cm9 non riuscivo ad usare il lettore musicale perchè ogni 3-4 volte che, mentre era in riproduzione, accendevo lo schermo per cambiare traccia si riavviava o andava in freeze
  7. #5
    Mirandola
    Onestamente per l'uso che dici di farne io resterei su rom stock :-) proprio perchè quello del riavvio col tasto power è un bug delle cm9 e non è stato del tutto corretto con le cm10; quindi il mio consiglio è:
    resta su rom stock
    passa alla rom harshginger che è basata sempre sulla rom stock
    passa alla rom jb taste che è basata su CM7.2 (cioè sempre gingerbread, come la stock)
    Nel secondo thread in rilievo ci sono elencate tutte le rom per il nostro smart, cerca quelle che ti ho consigliato e leffi i pareri da chi le ha usate...
    Poco X3 NFC
  8. #6
    Campomarino
    salve,è da un paio di giorni che sto provando questa rom (prima usavo la D-Lord) voglio capire solo una cosa ma il GPS funziona?perchè vi spiego,appena istallata ieri provo il GPS e WOW in neanche 20sec li ha trovati ed agganciato e poi è tutt'oggi che non ne vuole sapere...inizio a pensare di avere problemi di hardware...
  9. #7
    Campomarino
    Screenshot_2013-03-10-02-09-39.jpgSono riuscito a risolvere con una guida del fasterfix trovata sempre su questo forum!
  10. #8
    Baby Droid L'avatar di lukarizla
    mi consigliate il governor della CPU da impostare e le frequenze massime e minime?? =)
  11. #9
    Campomarino
    Io giro con smartassv2 e vr come scedulatore con frequenza da 245 minuti e 1200max...con il kernel di andr00ib...
    mi dura fino a 4gg...
    Ultima modifica di Adritrap; 11-03-13 alle 21:05
  12. Il seguente Utente ha ringraziato Adritrap per il post:
    lukarizla (11-03-13)
  13. #10
    Campomarino
  14. Il seguente Utente ha ringraziato Adritrap per il post:
    lorevo (11-03-13)
