Utente della settimana: elmegio con ben 8 Thanks ricevuti negli ultimi sette giorni
Utente del mese: megthebest con ben 18 Thanks ricevuti nell'ultimo mese
[Rom][CM10]Pacman (Aokp+Cm10+Paranoid)
    Mirandola
    LG Optimus sol (E730)
    Ringraziato 143 volte in 123 Posts
    Questa rom contiene "parti" delle rom: Aokp, CM10 e Paranoid
    Here some rom specs:
    - compiled with linaro 4.7.3
    - zippaligned
    - tweaked build.prop and pad.prop
    - tuned dirty radio values on boot
    - cleans cache and ram on boot
    - Fluid Project
    - zipalign on boot
    - vacuum sqlite databases on boot
    - fix permissions on boot
    - tweaked loopysmoothness script
    - governor tweaks
    - and some more...
    Some kernel specs:
    -oc up to 2016 mhz ( 2 ghz)
    -undervolted
    -smartass/interactivex ....governors
    -sio and Vr I/o sched
    -cache presure tweaked and more other stuff
    Download:
    Dev-Host - PACman_JB_4.1.2_Optimized_e730.zip - The Ultimate Free File Hosting / File Sharing Service
    How to flash ROM:
    -download ROM and put it on sdcard
    -reboot into recovery
    -Wipe cache/ wipe dalvik-cache/ wipe data/ wipe battery stats/
    -install zip from sdcard, choose the rom (with help of volume buttons)
    -flash it, then REBOOT & Enjoy!
    TIPS
    -use 0.5x animations (it feels more smooth)
    -use 1401mhz-245mhz with lionheart
    -use all memory management on, like :KSM,Purging of Assets,Zram
    -use SIO or VR for more smootheness
    RADIO fix for some user's:
    Download one of those basebands to have signal working...then you need to flash one of those basebands)
    v10a: radio_v10a.zip
    v10b: radio_v10b.zip
    v10j: Dev-Host - radio_v10j.zip - The Ultimate Free File Hosting / File Sharing Service
    How to flash baseband:
    -download one of above basebands and put it on SDcard
    -flash the proper baseband, be carrefuly to flash after ROM is flashed..
    Link al forum CyanogenMod: http://forum.cyanogenmod.org/topic/7...d/#entry381657
    Crediti:
    -Andr00ib
    -aokp team
    -cyanogenmod team
    -paranoid team
    -pacman team
    -LeoLawliet
    -shutt1e
    -fluid team
    Se la mia risposta ti è stata utile premi sul thank's
    Poco X3 NFC
    Ringraziato 10 volte in 8 Posts
    il link è offline ...
    Baby Droid L'avatar di lukarizla
    qual'è il miglior baseband da flashare??
    Quote Originariamente inviato da chak10 Visualizza il messaggio
    è online ora
    Si quoto lukarizla qual'è il miglior baseband da flashare ??
    Mirandola
    si quoto lukarizla qual'è il miglior baseband da flashare ??
    credo bisognerà provare, provate l'ultima che è la più recente
    Inviato dal mio LG-E730 con Tapatalk 2
    Poco X3 NFC
    Quote Originariamente inviato da lorevo Visualizza il messaggio
    Lorevo, tu che hai provato la CM10, mi sai dire le differenze con questa?
    Mirandola
    Quote Originariamente inviato da Fac19 Visualizza il messaggio
    Mi spiace, questa non l'ho provata, so che dovrebbe essere la più personalizzabile, ma non so altro, puoi leggere il thread sul forum cyanogenmod o chiedere qualcosa di là...
    Poco X3 NFC
