Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 18
[Rom] [Ics] Penberrom2 (Tweaked Pacman Ics)
    Mirandola
    LG Optimus sol (E730)
    Ringraziato 143 volte in 123 Posts
    [Rom] [Ics] Penberrom2 [Codename: Lightning Bolt]
    Penberrom2 [Codename: Lightning Bolt] V6.1
    Si tratta di una PACman ICS rom modificata.
    Screenshots: Screenshot_2013_09_17_03_01_18.jpg Screenshot_2013_09_17_03_01_39.jpg Screenshot_2013_09_17_02_48_11.jpg Screenshot_2013_09_17_03_02_55.jpg Screenshot_2013_09_17_02_48_47.jpg
    Cosa non funziona:
    - Weather doesn't update on Lockscreen & statusbar
    - same bugs as every other CM9 based ROM (random reboots/demigod crash/panorama preview is reversed)
    Ecco un elenco di ciò che è stato aggiunto:
    tweaked build.prop to improve performance and stability
    custom UI sounds, some from In The Groove 2 and some from Metal Gear Solid (optional, will post link)
    custom bootanimation created by djwuh (Thanks Diego)
    replaced Trebuchet with Smart Launcher
    replaced DSP Manager with ViPER4Android FX (V4A thread)
    supercharged services.jar (launcher stays in memory + better multitasking)
    boost in performance
    swap2cache terminal script creates a 64mb swapfile in /cache with swappiness set to 40
    swap2data terminal script creates a 128mb swapfile in /data with swappiness set to 40
    increased responsiveness through various GPU tweaks
    better battery life
    fast boot (reduced bootup time)
    zipalign apk's on boot
    defrag databases on boot
    entropy tweak (provides significant lag reduction)
    I/O scheduler tweaks
    sleeper tweaks
    hardware rendering tweaks (GPU > CPU)
    improved sdcard read/write speed
    disables logger (basically logcat disabled by default)
    disables journalism (provides an increase in performance)
    disables vsync (might cause graphical issues, but it helps speed things up)
    ADJ tweaks
    vm tweaks
    ram tweaks
    kernel tweaks
    disabled CPU rendering, now renders with adreno libs
    video/music streaming tweaks
    various useful terminal scripts (I'll mark those down)
    increased jpeg + video recording quality
    2D+3D performance enhancement tweaks
    call tweaks
    sysctl tweaks
    Terminal Scripts:
    avc - avcore by LENAROX
    boost - instant ram boost, drops cache
    cpuramcheck - checks CPU & RAM usage in realtime
    flush - drops cache and frees RAM, also shows true free RAM
    gm - modded version of boost, also kills media server
    hc - hyper cola v2.6, gives a boost in gaming but causes battery drain, reboot to deactivate
    lights - toggles key backlight on or off
    lightsoff - turns off key backlight
    lightson - turns on key backlight
    sclean - wipes cache & dalvik-cache & reboots all at once, I recommend running this once a week
    swap2cache - creates a 64mb swapfile in /cache/swap/ with swapiness set to 40 (virtual RAM in internal memory, could be risky)
    swap2data - creates a 128mb swapfile in /data/swap/ with swapiness set to 40 (virtual RAM in internal memory, could be risky)
    Per utilizzarli, è necessario lanciare l'emulatore terminale:
    prima di tutto digitare "su" (senza le virgolette)
    quindi premere Invio (tasto Invio)
    ora si possono eseguire i comandi
    infine basta premere Invio per eseguirli
    Changelog:
    V6.1(02/12/2013):
    bug fixed
    V6(15/11/2013)[probabilmente l'ultimo aggiornamento]:
    NEW!! KitKat themed
    Updated MGS4 UI sounds and notifications, properly converted this time.
    Removed latest fluid engine script and merged some of the new changes with my main script
    Tweaked/Updated a couple of init.d scripts, PenberEngine tweaks are now Codename LightningBolt tweaks
    Updated some system and user apps
    sysctl tweaks got a huge update, I took my time with it for a good reason (one of the better changes I made)
    V5.5(31/10/2013):
    NEW!! MGS4 UI sounds and notifications, properly converted this time.
    NEW!! Added & updated some xbin scrpits (avc/hc/sclean) I recommend running sclean every week for a quick tuneup
    EXPERIMENTAL!! Added latest fluid engine script (89fluid_engine init.d script only!) Let's see how this plays out
    Tweaked/Updated a couple of init.d scripts, the PenberEngine ones, working smoothly so far
    Removed Nitros Lag Nulifier
    V5.2[Minor update, fixed several things](10/10/2013):
    Updated gps.conf
    The init.d scripts in v5.1.1 weren't favorable, I got rid of them and replaced them with the Project PenberEngine ones
    Added avcore by LENAROX
    Tweaked build.prop slightly
    Optimized system apps
    Attempted to switch to Google Keyboard as default input method (Experimental)
    V5[Major update. New look, better feel. Dedicated to Pizza_Dox](17/9/2013):
    Different look
    Different UI sounds
    Updated adreno200 libs with ones from Hyper Glazed ICS (thank Pizza_Dox for this)
    Better init.d scripts
    Much more improved build.prop as I had taken the time to clean it up a lot more
    LMT (PIE) works as a system app by default now, it's included so we now have PIE
    Dedicated to Pizza_Dox for his awesome recommendations
    V4.6[PenberEngine Tweaks Updated, big thanks to Pizza_Dox for his pointers](8/9/2013):
    Added vm & ADJ tweaks and a few nice new build.prop tweaks, thank Pizza_Dox for those
    Removed some PenberEngine tweaks, added better ones.
    Updated init.d scripts, some removed and some added.
    In general this update feels smoother than the last.
    DOWNLOADS:(le gapps non sono necessarie, il Play Store è incluso di default. Tutto il resto può essere scaricato dal Play Store)
    IRS Starter Pack: For ViPER4Android FX, Get the latest files [V4A][IRS] Impulse Response Sample Index - xda-developers (optional)
    Add-ons: AROMA Installer Dev-Host - PenberRom2 Add-ons Aroma Installer.zip - The Ultimate Free File Hosting / File Sharing Service
    V4.6: Dev-Host - E739_PA+AOKP+CM9_PenberRom2_v4.6_LeoLawliet.zip - The Ultimate Free File Hosting / File Sharing Service
    V5: Dev-Host - E739_PA+AOKP+CM9_PenberRom2_v5_LeoLawliet.zip - The Ultimate Free File Hosting / File Sharing Service
    V5.2: https://app.box.com/s/38rn5mwftdkrgpyfmpfk
    V5.5: Dev-Host - E730_PA+AOKP+CM9_PenberRom2_v5.5_LeoLawliet.zip - The Ultimate Free File Hosting / File Sharing Service
    V6: Dev-Host - E730_PA+AOKP+CM9_PenberRom2_v6_LeoLawliet.zip - The Ultimate Free File Hosting / File Sharing Service
    V6.1: http://d-h.st/DdA
    Non sono responsabile per eventuali danni causati al vostro device utilizzando questa rom.
    Effettuare sempre un nandroid backup prima di flashare una nuova rom.
    Vi consiglio un full wipe prima di flashare questa rom.
    Link al forum CyanogenMod:[Rom] [Ics] Penberrom2 (Tweaked Pacman Ics) - Page 2 - LG Optimus Sol General - CyanogenMod Forum - Page 2
    Credits:
    LeoLawliet(il creatore della rom)
    maucat (for the base ROM I used and for porting PACman in the first place and fixing GPS and optimizations)
    beastmode (thank you for Paranoid Android and AOKP, you made this possible)
    andr00ib (for his excellent kernel, also the biggest supporter of this project)
    ViPER520 and zhuhang (for ViPER4Android FX)
    GinLemon for SmartLauncher
    djwuh/wuh for testing and the coolest boot animation
    kdog1202 for testing
    yochananmarqos for testing
    zepplinrox (for supercharged services.jar and preinstalled v6 scripts)
    Pizza_Dox (for a great number of tweaks and suggestions, even the JB style look is thanks to him
    Spex (for many of the build.prop tweaks, probably one of the most amazing set of tweaks)
    LENAROX (for various build.prop & init.d tweaks)
    Spizzy (for adrenobooster script, it's modded for ICS but I'm not sure it's even doing anything for ICS)
    Paranoid Android
    AOKP
    CyanogenMod
    Ultima modifica di lorevo; 04-12-13 alle 11:06
    Mirandola
    Aggiornamento della rom...
    Se la mia risposta ti è stata utile premi sul thank's
    Poco X3 NFC
    Ringraziato 41 volte in 35 Posts
    Quote Originariamente inviato da lorevo Visualizza il messaggio
    potrebbe esser la migliore tra le cm9 (almeno da quanto si legge in giro) ...un mio amico si lamenta del fatto che è solo in inglese (cosa per me trascuarabile)..per caso hai visto se c'è modo di impostare l'italiano?
    Mirandola
    Quote Originariamente inviato da miserable Visualizza il messaggio
    Non l'ho provata, dì al tuo amico di provare scaricare dal play store l'app gratuita "more locale", con le rom ginger funziona, con le ics non l'ho mai provata; se funziona faccelo sapere, può tornare utile agli altri...
    Poco X3 NFC
    ok , faccio sapere qui! Cmq intanto provava l'ultima nightly cm9...ha uno strano problema con tutte le cm9, praticamente gli capitano FC in continuazione, con kernel base e kernel modificato :\
    Mirandola
    Si, le cm9 non conviene metterle se si vuole stabilità, meglio una cm9 modificata (come appunto la penberrom)o una cm10...
    Poco X3 NFC
    Il mio amico ha flashato la rom qualche ora fa...per adesso ha avuto solo 2 FC (dopo aver installato le prime applicazioni) e non ha ancora provato il gps. Per quanto riguarda la lingua, con morelocale2 ( o con le altre applicazioni simili), si riesce ad impostare la lingua italiana ma il menu delle impostazioni della rom resta in inglese.
  9. #8
    Mirandola
    Nuovo aggiornamento (v3)
    Edit:
    Aggiornamento (3.2)
    Ultima modifica di lorevo; 30-05-13 alle 11:13
    Poco X3 NFC
  10. #9
    Mirandola
    Altro agiornamento: Penberrom2 V3.7
    Poco X3 NFC
  11. #10
    Mirandola
    Aggiornata alla V4
    Poco X3 NFC
