Vocoderism ti spiego cosa ho fatto e vediamo se sono sulla buona strada o no...
allora dentro al kernel della versione 4.4 c'è la cartella driver , dentro ci sono tutti i driver per le varie architetture , nel makefile ho notato che ci sono delle voci che vanno a richiamare il famoso file defconfig , cosa mi consigli di lasciare in questo file?ora di default compila le cartelle :
# Makefile for the Linux kernel device drivers.
# 15 Sep 2000, Christoph Hellwig <hch@infradead.org>
# Rewritten to use lists instead of if-statements.
# GPIO must come after pinctrl as gpios may need to mux pins etc
obj-y += pinctrl/
obj-y += gpio/
obj-$(CONFIG_PCI) += pci/
obj-$(CONFIG_PARISC) += parisc/
obj-$(CONFIG_RAPIDIO) += rapidio/
obj-y += video/
obj-y += idle/
obj-$(CONFIG_ACPI) += acpi/
obj-$(CONFIG_SFI) += sfi/
# PnP must come after ACPI since it will eventually need to check if acpi
# was used and do nothing if so
obj-$(CONFIG_PNP) += pnp/
obj-$(CONFIG_ARM_AMBA) += amba/
# Many drivers will want to use DMA so this has to be made available
# really early.
obj-$(CONFIG_DMA_ENGINE) += dma/
obj-$(CONFIG_VIRTIO) += virtio/
obj-$(CONFIG_XEN) += xen/
# regulators early, since some subsystems rely on them to initialize
obj-$(CONFIG_REGULATOR) += regulator/
# tty/ comes before char/ so that the VT console is the boot-time
# default.
obj-y += tty/
obj-y += char/
# gpu/ comes after char for AGP vs DRM startup
obj-y += gpu/
obj-$(CONFIG_CONNECTOR) += connector/
# i810fb and intelfb depend on char/agp/
obj-$(CONFIG_FB_I810) += video/i810/
obj-$(CONFIG_FB_INTEL) += video/intelfb/
obj-$(CONFIG_PARPORT) += parport/
obj-y += base/ block/ misc/ mfd/ nfc/
obj-$(CONFIG_NUBUS) += nubus/
obj-y += macintosh/
obj-$(CONFIG_IDE) += ide/
obj-$(CONFIG_SCSI) += scsi/
obj-$(CONFIG_ATA) += ata/
obj-$(CONFIG_TARGET_CORE) += target/
obj-$(CONFIG_MTD) += mtd/
obj-$(CONFIG_SPI) += spi/
obj-y += hsi/
obj-y += net/
obj-$(CONFIG_ATM) += atm/
obj-$(CONFIG_FUSION) += message/
obj-y += firewire/
obj-$(CONFIG_UIO) += uio/
obj-y += cdrom/
obj-y += auxdisplay/
obj-$(CONFIG_PCCARD) += pcmcia/
obj-$(CONFIG_DIO) += dio/
obj-$(CONFIG_SBUS) += sbus/
obj-$(CONFIG_ZORRO) += zorro/
obj-$(CONFIG_MAC) += macintosh/
obj-$(CONFIG_ATA_OVER_ETH) += block/aoe/
obj-$(CONFIG_PARIDE) += block/paride/
obj-$(CONFIG_TC) += tc/
obj-$(CONFIG_UWB) += uwb/
obj-$(CONFIG_USB_OTG_UTILS) += usb/
obj-$(CONFIG_USB) += usb/
obj-$(CONFIG_PCI) += usb/
obj-$(CONFIG_USB_GADGET) += usb/
obj-$(CONFIG_SERIO) += input/serio/
obj-$(CONFIG_GAMEPORT) += input/gameport/
obj-$(CONFIG_INPUT) += input/
obj-$(CONFIG_I2O) += message/
obj-$(CONFIG_RTC_LIB) += rtc/
obj-y += i2c/ media/
obj-$(CONFIG_PPS) += pps/
obj-$(CONFIG_PTP_1588_CLOCK) += ptp/
obj-$(CONFIG_W1) += w1/
obj-$(CONFIG_POWER_SUPPLY) += power/
obj-$(CONFIG_HWMON) += hwmon/
obj-$(CONFIG_THERMAL) += thermal/
obj-$(CONFIG_WATCHDOG) += watchdog/
obj-$(CONFIG_MD) += md/
obj-$(CONFIG_BT) += bluetooth/
obj-$(CONFIG_ACCESSIBILITY) += accessibility/
obj-$(CONFIG_ISDN) += isdn/
obj-$(CONFIG_EDAC) += edac/
obj-$(CONFIG_MCA) += mca/
obj-$(CONFIG_EISA) += eisa/
obj-y += lguest/
obj-$(CONFIG_CPU_FREQ) += cpufreq/
obj-$(CONFIG_CPU_IDLE) += cpuidle/
obj-y += mmc/
obj-$(CONFIG_MEMSTICK) += memstick/
obj-y += leds/
obj-$(CONFIG_SWITCH) += switch/
obj-$(CONFIG_INFINIBAND) += infiniband/
obj-$(CONFIG_SGI_SN) += sn/
obj-y += firmware/
obj-$(CONFIG_CRYPTO) += crypto/
obj-$(CONFIG_SUPERH) += sh/
obj-$(CONFIG_ARCH_SHMOBILE) += sh/
ifndef CONFIG_ARCH_USES_GETTIMEOFFSET
obj-y += clocksource/
endif
obj-$(CONFIG_DCA) += dca/
obj-$(CONFIG_HID) += hid/
obj-$(CONFIG_PPC_PS3) += ps3/
obj-$(CONFIG_OF) += of/
obj-$(CONFIG_SSB) += ssb/
obj-$(CONFIG_BCMA) += bcma/
obj-$(CONFIG_VHOST_NET) += vhost/
obj-$(CONFIG_VLYNQ) += vlynq/
obj-$(CONFIG_STAGING) += staging/
obj-y += platform/
obj-y += ieee802154/
#common clk code
obj-y += clk/
obj-$(CONFIG_HWSPINLOCK) += hwspinlock/
obj-$(CONFIG_NFC) += nfc/
obj-$(CONFIG_IOMMU_SUPPORT) += iommu/
obj-$(CONFIG_REMOTEPROC) += remoteproc/
obj-$(CONFIG_RPMSG) += rpmsg/
# Virtualization drivers
obj-$(CONFIG_VIRT_DRIVERS) += virt/
obj-$(CONFIG_HYPERV) += hv/
obj-$(CONFIG_PM_DEVFREQ) += devfreq/
Posso brasare un po di roba?
in teoria non andrebbero compilati i driver necessari per il dispositivo? o qui c'è qualche dipendenza?
Perchè pensavo i driver mediatek di un'altro dispositivo ce li ho , "ricavati da CINK_FIVE_JB_Opensource_9841285" quindi potrei fare un file brutale con dentro solo questo?
include ../common.mk
#$(call all-subdir-src-or-makefile)
obj-y += mediatek/aee/
obj-y += mediatek/ccci/
obj-y += mediatek/dual_ccci/
obj-y += mediatek/fmradio/
obj-y += mediatek/gps/
obj-y += mediatek/hwmon/
obj-y += mediatek/m4u/
obj-y += mediatek/mhl/
obj-y += mediatek/mtprof/
obj-y += mediatek/sched/
obj-y += mediatek/usb11/
obj-y += mediatek/almk/
obj-y += mediatek/video/
obj-y += mediatek/bthid/
obj-y += mediatek/ccmni/
obj-y += mediatek/emd_ctl/
obj-y += mediatek/hdmitx/
obj-y += mediatek/leds/
obj-y += mediatek/mmp/
obj-y += mediatek/ram_console/
obj-y += mediatek/net/
obj-y += mediatek/thermal/
obj-y += mediatek/videocodec/
obj-y += mediatek/xlog/
obj-y += mediatek/wdk/
obj-y += mediatek/usb20/
obj-y += mediatek/combo/
Grazie mille della pazienza e disponibilità.
un saluto a tuttiiiii
LinkBack URL
About LinkBacks
Rispondi quotando
Ultima modifica di devilmaycry3351; 09-01-14 alle
un consiglio se posso... Perché non abilitate l'OTG??
