Naturalmente la stringa dovrebbe root=/dev/mtdblock2 rootfstype=ext3 console=ttyS0,115200 mem=256M ....la memoria non son sicuro..
Secondo voi si tira qualcosa fuori da questo log del nostro tablet per sapere che drivers monta relativamente allo schermo e quindi il touch?
********rk29_sensor_ioctrl..nt99250..PowerDownPin= 191 ..PinLevel = 1
<4>[ 3.486711]
<6>[ 3.525688] android_usb <NULL>: high speed config #1: android
<4>[ 3.528629] set_msc_connect_flag status = 1 20101216
<4>[ 3.606314] rk29xx_camera: rk29_camera_remove_device exit
<4>[ 3.608868] rk29xx_camera: rk29_camera_probe..drivers/media/video/rk29_camera_oneframe.c..1587
<4>[ 3.617720] ipp irq 46
<7>[ 3.620046] rk29-ipp: Driver loaded succesfully
<7>[ 3.620079] rk29-ipp: Module initialized.
<6>[ 3.620088] ThumbEE CPU extension supported.
<6>[ 3.624213] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
<6>[ 3.635942] rtc_hym8563 0-0051: setting system clock to 2011-11-12 23:07:44 UTC (1321139264)
<6>[ 3.641777] Freeing init memory: 1120K
<4>[ 3.645414] rk29_serial_set_termios:fcr=0xa1,irq=67
<4>[ 3.692954] rk29_serial_set_termios:fcr=0xa1,irq=67
<4>[ 3.699425] >>>>>> win1fb_check_var fail 2!!!
<4>[ 3.699435] >>>>>> (0+800)>800 || (1+600)>600 || (0+800)>800 || (0+600)>600
<4>[ 3.712422] rk29xxnand_ko: module license '' taints kernel.
<4>[ 3.715135] Disabling lock debugging due to kernel taint
<4>[ 3.725209] gp_rknand_info = : 0xd29b7a80
<4>[ 3.726457] ATime: 50 ns AHB: 210 timming: 10e3
<4>[ 3.730868] Flash 0 ID: ad d7 94 9a 74
<4>[ 3.735071] ATime: 42 ns AHB: 144 timming: 1082
<4>[ 3.779949] GetRemapTbl...done
<4>[ 5.036255] FTL INFO:Version = 428,Date = 20110708
<4>[ 5.038764] totalLogicBlkRaw = 1900
<5>[ 5.042439] 10 cmdlinepart partitions found on MTD device rk29xxnand
<5>[ 5.048590] Creating 10 MTD partitions on "rk29xxnand":
<5>[ 5.053744] 0x000000400000-0x000000800000 : "misc"
<5>[ 5.059431] 0x000000800000-0x000001000000 : "kernel"
<5>[ 5.064047] 0x000001000000-0x000002000000 : "boot"
<5>[ 5.068874] 0x000002000000-0x000003000000 : "recovery"
<5>[ 5.073948] 0x000003000000-0x000012000000 : "backup"
<5>[ 5.079443] 0x000012000000-0x000019400000 : "cache"
<5>[ 5.083981] 0x000019400000-0x000045000000 : "userdata"
<5>[ 5.090530] 0x000045000000-0x000045400000 : "kpanic"
<6>[ 5.094088] apanic: Bound to mtd partition 'kpanic'
<6>[ 5.098043] apanic: No panic data available
<5>[ 5.102184] 0x000045400000-0x000055400000 : "system"
<5>[ 5.108383] 0x000055400000-0x0000ed800000 : "user"
<4>[ 5.118342] startBlk = 164
<4>[ 5.118364] sysProtAddr = 163
<3>[ 5.121580] init: cannot find '/system/bin/resize2fs'
<3>[ 5.126170] init: ext_check(/dev/block/mtdblock8):
<3>[ 5.131156] init: ext_check(/dev/block/mtdblock8): /system/bin/e2fsck not found (skipping checks)
<6>[ 5.141453] EXT3-fs: mounted filesystem with ordered data mode.
<3>[ 5.145879] init: ext_check(/dev/block/mtdblock6):
<6>[ 5.150640] kjournald starting. Commit interval 5 seconds
<3>[ 5.226400] init: e2fsck 1.41.14 (22-Dec-2010)
<3>[ 5.227993] init: superblock offset = 0
<3>[ 5.258455] init: /dev/block/mtdblock6: clean, 316/45056 files, 61467/716800 blocks
<3>[ 5.263297] init: /system/bin/e2fsck terminated by exit(0)
<3>[ 5.268760] init: filesystem '/dev/block/mtdblock6' had no errors
<6>[ 5.276573] EXT3 FS on mtdblock6, internal journal
<6>[ 5.279548] EXT3-fs: mounted filesystem with ordered data mode.
<3>[ 5.285486] init: ext_check(/dev/block/mtdblock5):
<6>[ 5.290231] kjournald starting. Commit interval 5 seconds
<3>[ 5.306392] init: e2fsck 1.41.14 (22-Dec-2010)
<3>[ 5.307981] init: superblock offset = 0
<3>[ 5.387989] init: /dev/block/mtdblock5: clean, 11/29760 files, 9426/118784 blocks
<3>[ 5.392659] init: /system/bin/e2fsck terminated by exit(0)
<3>[ 5.398106] init: filesystem '/dev/block/mtdblock5' had no errors
<6>[ 5.497287] EXT3 FS on mtdblock5, internal journal
<6>[ 5.499220] EXT3-fs: mounted filesystem with ordered data mode.
<6>[ 5.505637] kjournald starting. Commit interval 5 seconds
<3>[ 5.524829] init: cannot find '/system/bin/flash_image', disabling 'flash_recovery'
<4>[ 5.534954] rk29_serial_set_termios:fcr=0xa1,irq=67
<6>[ 5.745449] enabling adb
<6>[ 5.760757] adb_open
<6>[ 5.762344] DWC_OTG: USB SUSPEND
<6>[ 5.939648] DWC_OTG: USB RESET
<6>[ 6.101170] DWC_OTG: USB RESET
<4>[ 6.197300] .324.. MMC0 receive the message No-Media from VOLD.====xbw[sd_mmc]====
<4>[ 6.304806] set_msc_connect_flag status = 0 20101216
<6>[ 6.306953] android_usb <NULL>: high speed config #1: android
<4>[ 6.312690] set_msc_connect_flag status = 1 20101216
<6>[ 6.317670] adb_release
<6>[ 6.320283] adb_open
<4>[ 8.278750] on_off_spk: 0
<4>[ 8.303628] change to spk, eq=10
<6>[ 12.729783] warning: `zygote' uses 32-bit capabilities (legacy support in use)
<4>[ 13.457143] gpu: change freq to 552, got 552
<4>[ 15.529759] rk2918_get_bat_capacity,first_flag=0,openfailflag= 0,openfailcount=19
<4>[ 16.302593] bryan---->last poweroff_spendcnt = 1321137921
<4>[ 16.302604] hj---->loadcapacity = 64, truecapacity = 61, spendcnt_intervals = 1355
<6>[ 16.679365] request_suspend_state: wakeup (3->0) at 16683061587 (2011-11-12 23:07:57.543407604 UTC)
<6>[ 18.551173] vpu_mem: request for physical address of vpu_mem region from process 123.
<4>[ 19.309015] NEW_HW_AUDIO
<4>[ 19.313197] NEW_HW_AUDIO
<4>[ 22.930543] gpu: change freq to 300, got 276
<6>[ 25.296443] vpu_mem: request for physical address of vpu_mem region from process 166.
<4>[ 48.637102] ================================================== =====
<4>[ 48.640527] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
<4>[ 48.659661] ================================================== =====
<4>[ 48.663100] RTL8192/RTL8188 USB WiFi driver (Powered by Rockchip,Ver 3.22) init.
<6>[ 49.126353] usb 1-1: new full speed USB device using usb11_host and address 2
<6>[ 49.130661] DWC_OTG: dwc_otg_hcd_qh_init tt->hub null!
<6>[ 49.326357] DWC_OTG: dwc_otg_hcd_qh_init tt->hub null!
<6>[ 49.329951] usb 1-1: not running at top speed; connect to a high speed hub
<6>[ 49.341050] usb 1-1: New USB device found, idVendor=0bda, idProduct=8176
<6>[ 49.344907] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
<6>[ 49.352055] usb 1-1: Product: 802.11n WLAN Adapter
<6>[ 49.356799] usb 1-1: Manufacturer: Realtek
<6>[ 49.360853] usb 1-1: SerialNumber: 00e04c000001
<6>[ 49.370214] usb 1-1: configuration #1 chosen from 1 choice
<6>[ 50.880579] usbcore: registered new interface driver rtl8192cu
<4>[ 51.129260] +871x_drv - dev_open
<4>[ 53.243911] MAC Address = 00:14:13:00:6f:d7
<6>[ 53.281918] DWC_OTG: dwc_otg_hcd_qh_init tt->hub null!
<6>[ 54.451976] DWC_OTG: dwc_otg_hcd_qh_init tt->hub null!
<6>[ 78.856474] DWC_OTG: dwc_otg_hcd_qh_init tt->hub null!
<4>[ 136.786447] rk2918_get_bat_capacity_ext.. lastlost=3870..exit game
<4>[ 146.207466] gpu: change freq to 552, got 552
<4>[ 149.419279] gpu: change freq to 300, got 276
<6>[ 164.036531] vpu_mem: request for physical address of vpu_mem region from process 450.
Purtroppo niente di niente...
a cosa potrebbero riferirsi queste stringhe?
forse ad un auto setting della risoluzione....
