mediacom flashing sorry but i cant speak italian
    hello i have a "problem" i cant flash my mediacom tablet when i hit the - volume down (-) and the power on the shows only
    reboot system now
    factory reset
    system recover
    and update from sdcard
    i want to install another room but the system does not let me can anyone knows how to do that...
    and can i install android 3.0 or latter on my smpartpad,if yes how?
    thank you
    Senior Droid L'avatar di parazitu
    Samsung S5570
    Ringraziato 116 volte in 54 Posts
    You can't transform your tablet in a galaxy tab...you can't instal android 3.0 or 4.0.......and when you flash hit only the volume down botton ...after conect the tablet of pc.
    scusate il mio italiano
    Parazitu
    http://smartpad810c.blogspot.com/
    Ringraziato 14 volte in 11 Posts
    Which mediacom tablet do you have? This thread is only 4 the 810c
    Inviato dal mio SMARTPAD810C usando Androidiani App
    Galaxy S Advance I9070
    Ringraziato 46 volte in 44 Posts
    installation:
    1 Download the package
    2 Extract the folder and copy it to your desktop
    3 Double-click RK29update.exe
    4 when the device is turned off, connect the USB cable by pressing Volume-(for those who have not yet installed the drivers download HERE and follow the guide below)
    5 At this point you should have this on video
    If not manually select the files in \ img clicking on ... at the bottom
    6 Click on Format and wait for completion (do not skip this step is important ...)
    7 Click Update
    8 Wait until the procedure 'installation.
    9 When you restart the tablet when you see the yellow Given Formatting can disconnect 's USB
    https://www.androidiani.com/forum/me...omb-style.html
    i was I read that android 3.0 does not have any requirements hardware parameters ...thats why I asked , thank you
    thank you i did it
    Samsung S5570
    Very good
    Parazitu
  9. #8
    thank you
    i wanted to know if i can change the code and if yes how to do that?
    i can write code in C/C++ and a little in java...
