Utente del giorno: GBolduc con ben 1 Thanks ricevuti nelle ultime 24 ore
Utente del mese: megthebest con ben 20 Thanks ricevuti nell'ultimo mese
Pagina 1 di 48 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 477
porting CM10
    GABICCE MARE (PU)
    l5
    Ringraziato 22 volte in 11 Posts
    [ rom ] CM10 NUOVI UPDATE
    UN RINGRAZIAMENTO SQUISITO VA' ALLA SEGNALAZIONE DI FRANCESCODA;
    QUI DI SEGUITO E' RIPORTATO PER LINEA E SEGNO IL THREAD DELLA ROM CM10 SVILUPPATA DA CHRISTIAN TROY!
    OGNI MERITO E RINGRAZIAMENTO VA' A LUI!!!!
    TABLET SUPPORTATI
    * Mediacom 907c, Momo11 Bird, JXD S9000, Eken A90 (first revision) and clones need 907c_compatibility_1.2.x.zip.
    * Visture V3 and clones need visturev3_compatibility_1.2.x.zip compatibility zip.
    * Mediacom 910i, Teclast A10t and clones need 910i_compatibility_1.2.x.zip compatibility zip.
    * ICOO D90W and clones need d90w_compatibility_1.2.x.zip compatibility zip.
    * CEMA10N7 "unknown" device needs cema10n7_compatibility_1.2.x.zip compatibility zip.
    * Bmorn V99 needs v99_compatibility_1.2.x.zip compatibility zip
    * Mediacom 711i, Momo9 and clones need 711i_compatibility_1.2.x.zip compatibility zip
    * Protab2XXL needs protab2xxl_compatibility_1.2.x.zip compatibility zip
    * Sanei N83 needs n83_compatibility_1.2.x.zip compatibility zip (note: internal bt doesnt work and will never work)
    * Hyundai A7HD needs a7hd_compatibility_1.2.x.zip compatibility zip
    * MOMO9 needs momo9_compatibility_1.2.x.zip compatibility zip
    * Onda Vi40 V3 needs vi40_compatibility_1.2.x.zip compatibility zip
    * LY-F1 and clones need lyf1_compatibility_1.2.x.zip compatibility zip
    * Protab2XXLv2 needs protab2xxlv2_compatibility_1.2.x.zip compatibility zip
    * TNT Singularity and clones need singularity_compatibility_1.2.x.zip compatibility zip
    * Eken T01 needs t01_compatibility_1.2.x.zip compatibility zip
    * Eken T02 needs t02_compatibility_1.2.x.zip compatibility zip
    * Eken T05a V1 needs t05a-v1_compatibility_1.2.x.zip compatibility zip
    * Eken T05a V2 needs t05a-v2_compatibility_1.2.x.zip compatibility zip
    * Eken T05a V3 needs t05a-v3_compatibility_1.2.x.zip compatibility zip
    * Eken T05a (unknown version) needs t05a-unk_compatibility_1.2.x.zip compatibility zip
    * Eken T10 needs t10_compatibility_1.2.x.zip compatibility zip
    * Eken T10 with mxc622x g-sensor needs t10-2axis_compatibility_1.2.x.zip compatibility zip
    * Sanei N10 needs n10_compatibility_1.2.x.zip compatibility zip (note: internal bt doesnt work and will never work)
    * Onda Vi30 Deluxe V3 needs vi30-deluxe-v3_compatibility_1.2.x.zip
    * Onda Vi40 Ultimate needs vi40-ultimate_compatibility_1.2.x.zip
    * Onda Vi10 Elite needs vi10-elite_compatibility_1.2.x.zip
    * Ainol Novo7 Elf needs elf_compatibility_1.2.x.zip
    * Sanei N83 Deluxe needs n83-deluxe_compatibility_1.2.x.zip compatibility zip (note: internal bt doesnt work and will never work)* Ainol Novo7 Aurora v3 needs aurora_compatibility_1.2.x.zip compatibility zip (you find it in 3rd_party section)
    Tablets supported with legacy support (see FAQS section for more infos)
    * Mediacom 917i and 927i need 917i-927i_legacy-compatibility_vX.zip comp zip
    * Gemei G2 needs g2_legacy-compatibility-jb_vX.zip comp zip
    * Gemei G9 (those not working fine with "regular" 907c comp zip) needs g9_legacy-compatibility-jb_vX.zip comp zip
    * Sanei N90 needs n90_legacy-compatibility-jb_vX.zip comp zip
    * Ainol Novo7 Aurora v1 and v2 need aurora-v1-v2_legacy-compatibility-jb_vX.zip
    * MK802 PC-on-a-stick needs mk802_legacy-compatibility-jb_vX.zip
    Puoi controllare la sezione testing" section del mio AndroidFileHost per trovare qualche altro modello di tablet che avrei bisogno fossero testati per poi essere approvati
    UNA VOLTA INDIVIDUATO IL VOSTRO DEVICE IL NOME DEL FILE DELLA COMPATIBILITA' E' SEGNATO IN FONDO ALLA SUA RIGA, QUI TROVATE I FILE (per esempio quello del 910i è 1.2.x.zip compatibility zip.
    Directory listing for www.androidfilehost.com/main/Allwinner_A10_Developers/christiantroy/misc/
    ISTRUZIONI
    * !!! IMPORTANTE !!! Bisogna avere una partizione di sistema di almeno 300MB altrimenti non puoi flashare le G-APPS!!!
    SOLUZIONE USATA E SEGNALATA DA NICODOCET (CHE RINGRAZIO) PER ALLARGARE LA PARTIZIONE DI SISTEMA:
    flashare la ROM creata dall'utente SPIAGGEFREDDE
    ecco il link all'immagine stock della mediacom con partizione /system a 400 mb:Download 910i_system_400mb.rar for free on uploading.com
    PROCEDIMENTO
    1) FLASHARE LA ROM TRAMITE LIVE SUITE (NON da recovery).
    ****ATTENZIONE E' STATO APPURATO CHE SE DA TERMINALE DIGITATE DF LA PARTIZIONE VIENE RICONOSCIUTA DAL TAB DI CIRCA 250MB; NON PREOCCUPATEVI E' UN BUG, CONTINUATE CON IL FLASH DELLA CM 10 SENZA PROBLEMI*****
    2) INSTALLARE LA RECOVERY LINK DELLA RECOVERY CWM 6.0.1.2 cwm_recovery_6.0.1.2_a10.zip
    ISTRUZIONI
    scompattare il file scaricato nella sd (per esempio il percorso con root explorer è mnt; sdcard)
    da terminal emulator (apk gratuito che trovate sul market) digitate:
    su
    cd /mnt/sdcard
    sh install-recovery.sh
    sh reboot-recovery.sh
    MAPPATURA TASTI: VOL-e VOL+ per navigare su e giu' nel menu' della recovery TASTO ACCENSIONE per selezionare la voce desiderata. PER TORNARE INDIETRO DI PAGINA C'E' LA VOCE DEDICATA (back se non erro)
    (SE AVETE LA PARTIZIONE GIA' ALLARGATA A 400MB COMINCIATE DA QUI IL PROCEDIMENTO)
    ECCO INVECE IL PROCEDIMENTO PER FLASHARE LA ROM CM10 DI CHRISTIAN TROY
    1) Mettete gli zip scaricati nella memoria interna o nella memory card.(ZIP DELLA ROM (LINK IN FONDO AL POST, ZIP DELLE G-APPS (LINK AL PUNTO 4) E ZIP DELLA COMPATIBILITA' PER IL PROPRIO DEVICE (LINK IN CIMA AL POST)
    2) Accedete alla recovery mode PREMENDO IL TASTO POWER PER QUALCHE SECONDO, TAPPANDO REBOOT O RIAVVIA NEL MENU' CHE SI APRE E POI TAPPANDO RECOVERY E DATEGLI L'OK.
    DA TABLET SPENTO INVECE premendo e tenendo premuti VOL- (MENU) e POWER for 3 secs, poi rilascia POWER e dopo qualche sec. VOL-
    IN ALTERNATIVA POTETE USARE Novo7 tools (LO TROVATE QUInovo7tools.apk)
    3) Selezionte " wipe data/factory reset"
    ***per formattare per benino la memoria interna del tablet c'è lo script di CHRISTIAN TROY (lo puoi trovare qui:DepositFiles)***
    4) Selezionate "install zip from sdcard" poi "choose zip from sdcard" (o "choose zip from internal sdcard"se i file sono nella memoria interna del tablet) e flashate, in questo ordine,
    A)rom (LA TROVATE PIU' IN BASSO)
    B) gapps del 10-11-2012 (grazie a BVZM per la segnalazione(per android 4.1.2)
    UPDATE
    *tutte le apps sono aggiornate alla versione 4.1.2
    *Google Play Store aggornato alla versione 3.9.16.
    *dovrebbe essere compatibile con android 4.1.1.
    LINK: Goo.im Downloads - Downloading gapps-jb-20121011-signed.zip
    C) compatibility zip (trovate il link e la lista dei device ad inizio topic
    5) ora tornate o al primo menu, e selezionate Reboot system now"
    6)Goditevi la CM10 di CHRISTIAN TROY
    NOTATE BENE: quando flashate un'update della stessa rom non c'è bisogno di fare il wipe data/factory reset a o la formattazione della memoria interna ma basta fare wipe cache and dalvik cache
    SHAUN2029 in un altro sito si è messo in moto per aggiornare la build della rom a lui ogni merito non faro' altro che postare qui i suoi aggiornamenti;ogni suggerimento o critica è ben accetta
    PS NON MI ASSUMO NESSUNA RESPONSABILITA' IN CASO DI BRICK O STORIE VARIE DEI VOSTRI TABLET MA PRIMA DI POSTARE VI ASSICURO CHE TESTO OGNI COSA NEL MIO 910i
    ATTENZIONE
    MD5 Hash
    Quando si scarica una rom, sarebbe una buona norma vedere il codice hash del file che scarichi per poi compararlo con l' hash md5 postato sotto il link di download. Per generare il l'hash md5 del file che stai scaricando puoi usare un programma come per esempio "md5sum". Se gli hash corrispondono il file che stai scaricando non è un file corrotto.
    Un file corrotto puo' essere responsabile di strani errori nel tablet.
    COMUNICAZIONE DI SERVIZIO (ringraziate FRANCESCODA per la segnalazione)
    L'utente dadaloi ha svelato su un altro topic come avviare da recovery il 910i
    PROCEDIMENTO:
    da tablet spento
    premere contemporaneamente i pulsanti volume+ e power.
    Quando compare l'immagine del robottino rilasciare il pulsante power, tenendo premuto volume+ fino a quando non vi entra in recovery mode.
    Testing Download (PER AVERE DELLE PRESTAZIONI MIGLIORI E' NECESSARIO UN FACTORY RESET)
    Download Build 2013-03-28 LINK:http://www.mediafire.com/?uxz7e0zki4x4q0d
    MD5: cdfd72ddb9729fe3e40cad8eb1da1168
    * Patched framework to prevent sleep of death. Thank you Aquous.
    * Included Aquous's patch to the theme chooser that works around the theme incompatibility issue.
    * Updated kernel to hopefully prevent sleep of death.
    * Updated CM10 sources
    Testing Download
    Download Build 2012-12-08
    MD5: 38f0fb0a33734d71af3e8d25990ee6ea
    * settato l'intervallo wifi supplicant scan a 90
    * amalgamata la falla della memoria quando si manipolano le data string dentro jelly bean
    * framework: fissata la falla nel rimando nelle attività del manager
    * aggiunta la sincronizzazione del blocco per evitare che la condizione di imballarsi
    http://www.mediafire.com/?48md1i543yalwjd
    Download Build 30-11-2012
    LINK http://www.mediafire.com/?b65uj3c5uurq2tc
    MD5: eeeae5a5d774eb7c31234ad77a36862e
    * fiXsato pulsante del phablet mode (Thanks to spook_man and Christian Troy)
    *fiXsato lo sleep mode , incluso il wi-fi
    * fiXsato l'eccessivo consumo della batteria
    * fiXsata l'uscita hdmi (Solo sul tablet ui?)
    Ultima modifica di bagonghina; 30-05-13 alle 14:57 - Motivo: titolo non appropriato
  2. I seguenti 10 Utenti hanno ringraziato bagonghina per il post:
    BAFAN (05-10-12),cf222111 (19-10-12),francescoda (05-10-12),gpegasus77 (04-12-12),kakashi86 (06-12-12),PietroTC (05-10-12),SkiLL (07-09-13),spiaggefredde (10-10-12),TheShrike (04-08-13),verrazzano78 (20-10-12)
    GABICCE MARE (PU)
    l5
    I tried the gapps-jb-picasa-20121011-signed.zip and it made all my error messages go away and the gallery seems to work a lot more smoothly. There is a description of the GAPPS versions on RootzWiki here: http://wiki.rootzwiki.com/Google_Apps It says that the picasa version disables special features in the camera app, but it didn't seem to change anything in my Aurora camera, so I really like this version.*
    più tardi traduco.
    se usate picasa ed avete riscontrato degli errori con le nuove g-apps dovete scaricarvi ed installarvi questo zip
    http://goo.im/gapps/gapps-jb-picasa-20121011-signed.zip
    che praticamente sincronizza le g-apps con picasa.
    Ultima modifica di bagonghina; 20-10-12 alle 12:18
  5. #3
    Perfetto ! inizierò ingrandendo la partizione di sistema col metodo semplificato indicato sopra, dato che può tornare sempre utile averla grande, e procederò al test della rom....
  6. #4
    GABICCE MARE (PU)
    l5
    Quote Originariamente inviato da francescoda Visualizza il messaggio
    Perfetto ! inizierò ingrandendo la partizione di sistema col metodo semplificato indicato sopra, dato che può tornare sempre utile averla grande, e procederò al test della rom.....
    ok facci sapere! ti consiglio dopo l'avvio del flash di fare il reboot di nuovo; a me appena flashato dava problemi, poi spariti al riavvio successivo.
    il tablet ora non mi da' piu' problemi col launcher (soprattutto dopo aver aggiornato apex).
    Ultima modifica di bagonghina; 06-10-12 alle 14:43
  7. #5
    ok messo stanotte sul 907c, dopo avere fatto wipe normali non il full, a parte il fatto, che all'inizio mi dava un ora indietro (forse non ha riconosciuto il fuso orario della rete, dato che era impostato su automatico, ho risolto mettendolo manualmente). Ho usato il tablet per diverse ore, sia stanotte che stamane, ho usate sia opera che skype che indoona e letto qualche fumetto e giocato a War Pinball HD. La rom, nel complesso, mi è sembrata abbastanza stabile, anche se ho avuto 2 blocchi totali (tanto che o dovuto forzare lo spegnimento tenendo premuto il tasto di accensione), uno mentre stavo usando indoona, dopo 30 minuti più o meno di conversazione, l'altro blocco mentre stavo usando War Pinball HD. Anche il consumo di batteria, mi sembra in linea con le precedenti versioni, un 10% all'ora per un uso misto tra internet,skype e leggere fumetti ecc. Vediamo come si comporterà alla lunga.
    Andando un po OT, c'è da qualche parte una guida, su come smontare il 907C, ho notato che il monitor o touch, si muove o meglio sembra un po scorrere, l'ungo l'asse verticale (asse più lungo), in particolare quando gioco e delle volte mentre lo giro e fa un po di rumore, come se non fosse fissato o incastrato bene, vorrei capire come stabilizzarlo, non vorrei che a lungo andare si staccasse del tutto o peggio. Grazie sin da ora per info e risposte.
  8. #6
    GABICCE MARE (PU)
    l5
    Quote Originariamente inviato da BVZM
    Blocchi totali non me ne sono mai capitati, mi capitava qualche soft boot ogni tanto ma dopo aver flashato l'aggiornamento non mi e' piu' successo.
    Inviato dal mio Nexus 7 usando Androidiani App
  9. #7
    GABICCE MARE (PU)
    l5
    Io ho smontato la scocca del mio 910i con l'uso di un plettro per chitarra,infilando lo tra la scocca di metallo ed il corpo in plastica del tablet. Facendolo scorrere lungo i bordi si aprono gli incastri. Bisogna prestare molta cura ed attenzione ai due angoli vino al lato dei tasti, gli incastri da me erano piu' duri e sforzando molto si rischia di incrinare lo schermo. Io l'ho aperto per risolvere il problema del WI-fi
  10. #8
    Quote Originariamente inviato da bagonghina Visualizza il messaggio
    bagonghina da quello che so come struttura il 910i è un po diverso dal 907C per quanto riguarda lo smontaggio, invece per quanto concerne i blocchi totali il mio 907c me li ha sempre fatti, non spesso ma ogni tanto, cmq nel complesso la cosa è sopportabile.
  11. #9
    GABICCE MARE (PU)
    l5
    aggiornamento in up!!!!
  12. #10
    Baby Droid L'avatar di Nobi
    Mediacom 910i
    E cosa hai fatto al Wi-Fi ? Io gli ho aperto una fessura di 10mm x 70mm in corrispondenza dell'antenna ,ma non è cambiato granché.
    Ultima modifica di Nobi; 07-10-12 alle 18:40
