Pagina 2 di 2 primaprima 12
Visualizzazione dei risultati da 11 a 13 su 13
aggiornamento disponibile 2.2.0808
  1. #11
    Jul 2015
    Ringraziato 12 volte in 7 Posts
    Ok. Purtroppo non ho wifi. Appena posso aggiorno. Comunque si vive benissimo senza l'italiano. Avevo letto che tornava su un post
    Ringraziato 38 volte in 36 Posts
    No l'italiano non c'è
    Hai visto il changelog? Io non lo trovo...
  4. #13
    Feb 2014
    Marche
    Grandi, Grossi... Cinafonotti
    Ringraziato 8,542 volte in 6,492 Posts
    System
    Optimization of background applications to start slow or killed multi-application problem
    Optimization of automatic brightness adjustment function
    Stagefright fix vulnerabilities
    Repair standby even now the issue of resuming
    It will change the problem with the system volume after repair using micro letter
    Touch the HOME key to quickly repair even now is not the right question to jump interface
    WIFI
    Repair using Lei Branch router even now can not access problems
    Set up
    Repair Hong Kong operator display problems
    Repair Google Pinyin dictionary add interface display unusual problem
    Go to Settings failures again to repair third-party applications to set the tone after the jump
    Repair setting power display problems
    Repair Bluetooth settings screen flash back problem
    Phone
    Crash repair phone and phone unresponsive issue
    Repair special Avatar contacts related issues
    Repair call back high CPU usage
    Can not dial emergency numbers of some problems in repair no card case
    Information
    Fixed problems closing roaming MMS does not take effect automatically downloads
    Bluetooth
    Bluetooth switch failure problems repair process using Bong bracelet
    Camera
    Repair adjust the shutter speed manual transmission in the dark photographed images are too dark problem
    Repair video camera other buttons invalidity
    Notification bar
    After inserting the SD card repair the notification bar is not already inserted SD card tips
    Fix detected problems will be prompted to SD card mode when you turn visitors
    Browser
    Repair Where Hotels Member interface text overlay, click the drop-down menu page flash back problem
    Full Screen repair invalid clicks within Sohu video page issue
    Repair Ctrip unable to locate the problem
    Repair the browser input box Paste button dislocation problem
    cloud service
    Enhanced cloud service stability
    Fix network call during the calling not automatically hang up the question after the called off net
    Repair Flyme communication recognizes the SIM card are displayed unanswered questions[
  5. I seguenti 2 Utenti hanno ringraziato megthebest per il post:
    ameris (20-08-15),ghostrider1970 (20-08-15)
