[TUTORIAL] Unbrick M3 Note L681H
    RadioApp
    Quote Originariamente inviato da Fernando Morea Visualizza il messaggio
    https://drive.google.com/drive/folde...DQ1N1BaWERYY0U password "4pda"
    For L Model, don't remove It admins, this could help people
    https://drive.google.com/uc?id=0B-C-...xport=download SYSTEM DUMP M3 NOTE L681H
    1. Put device off
    2.Tieni premuto (long press) volume meno fin quando il tuo computer non legge il telefono (ovviamente installa prima i driver)
    Added link for system dump and some words for italian users
    ---------- Post added at 04:20 PM ---------- Previous post was at 04:08 PM ----------
    Quote Originariamente inviato da rudra964 Visualizza il messaggio
    RADev Team Presents:
    Hard Brick Fix Tool for Meizu m3 Note M91 (TESTED) (WORKING)
    Warning:- This tutorial is only for M3 Note (M91). Do not try it on Meizu m3 note (L91) as it has not been tested on the same. If you still want to try it, you are on your own.
    Requirements:-
    1. A mildly functioning brain
    2. Ability to follow specific instructions
    3. A Meizu m3 note
    4. Modified SP Flash tool
    5. A PC/laptop
    6. An Internet Connection
    Steps:-
    1. Download all the files from the link below.
    2. Extract and Install the VPN. Since it is a crack, follow this link to install and configure it mod edit - warez link removed
    3. After installing the VPN, select the server location as China
    4. Load SP Flash tool It is located under flash_file.7z>sp flash tool for meizu only.7z>sp flash tool.exe
    5. After opening SP flash tool, add the file MTK_AllInOne_DA.bin in the Download_Agent bar. This file is located in flash_file.7z>sp flash tool for meizu only.7z>MTK_AllInOne_DA.bin
    6. After this, in Scatter -loading fie, add MT6755_Android_scatter.txt This file is located in flash_file.7z>m3 note flash files>MT6755_Android_scatter.txt
    7. Then in authentication file, load auth_sv5.auth This file is located in flash_file.7z>sp flash tool for meizu only.7z>auth_sv5.auth
    8. With your phone TURNED OF, connect it to PC/laptop and press Download
    This should flash the official Flyme recovery on your phone and through it you can flash any flyme firmware by connecting your phone to your PC/laptop.
    Why our tool works?
    You must have seen hundreds of videos on YouTube claiming how their tutorial works. The thing is, 99.9% of them don't know what they're talking about. We aim to fix that with our tutorial. Coming back to the question, the reason why our tutorial works is that it does not try to copy anything to the phone. Since we have the authrisation file that the Meizu service centers use, we are able to flash anything Flyme firmware we want to the phone without a MRT Dongle because just like a dongle, because of the authorisation file, we can directly flash to the eMMC storage of the phone. No matter how messed up your phone is, it will definitely come back to life.
    Special thanks to @ChatDexter for trying this tutorial on his hard bricked m3 note and conforming that it works.
    This is a list of drivers that you'll need to install on your PC/Laptop in order to flash the files successfully:-
    MediaTek USB Port
    MediaTek Preloader USB VCOM (Android)
    MediaTek DA USB VCOM (Android)
    Download Links:-
    Modified SP Flash Tool:- https://drive.google.com/open?id=0Bx...l9GY3NNNHN1Zk0
    ... Crack VPN:- mod edit - warez link removed
    Some Win10 x64 Drivers:- https://drive.google.com/open?id=0Bx...nEwZGFUemdEazg
    Tips:-
    If you get BROM or VROM error then it is because you do not have the proper drivers installed.
    Turn on Windows Update to automatically download the missing drivers
    The reason for connecting to a Chinese VPN is because the authorisation file was leaked from China and it needs to verify a signature from a Chinese server to flash things on the phone. Failure to do this results in error while trying to flash recovery.
    If you face any difficulty following any of the steps mentioned here please join our Chatbox and Channel on Telegram so that our 1000+ members can help you out
    Channel:- https://t.me/RADevTeam
    ChatBox:- https://t.me/FlymeChatBox
    Other useful links:-
    Meizu m3 note Bootloader Unlock Tutorial:- https://forum.xda-developers.com/and...-note-t3682643
    We will also be posting a new TWRP and a new custom ROM for the Meizu m3 note. Please support us
    Our work is and always will be 100% free of charge. Being a developer is not easy and requires a lot of time and resources. If you like our job PLEASE CONSIDER DONATING.
    Guide wrong in the part of connection between pc and phone:
    HOW TO CONNECT PC TO PHONE LIKE THE "DOWNLOAD MODE" OF SAMSUNG
    -install drivers
    -open flashtool (as administrator)
    -now compile the 3 "box" "forms" with scatter, auth, and other that I now don't remember
    -now click download
    -Power OFF your M3 note
    -HOLD DOWN (tieni premuto) volume down and connect to pc
    -when your pc recognize the phone YOU HAS TO BE FAST TO UNPRESS (NON CLICCARE PIU') VOLUME DOWN!!!!!!!!!!!!!!!!!!!!!!!!
    -NOW WAIT AND CROSS THE FINGER (those chinese phone fanno schifo...)[COLOR="Silver"]
    Ultima modifica di RadioApp; 21-12-17 alle 18:29 - Motivo: aggiornamento
  2. Il seguente Utente ha ringraziato RadioApp per il post:
    page64 (18-10-17)
    RadioApp
    Unbrick M3 note, seppur in inglese ma molto semplice il lessico, per gli smanettoni che vogliono riparare il loro M3 note
  5. Il seguente Utente ha ringraziato RadioApp per il post:
    page64 (21-12-17)
  6. #3
    Nov 2013
    I file non si scaricano, googledrive dice che sono infetti da virus.
    qualcuno ha altri link o magari può passarli in privato?
