Ciao a tutti sul sito flyme.cn è uscita la 4.1.1A secondo voi è installabile sulla versione I?e stata pubblicata stamattina
Inviato dal mio MX4 usando Androidiani App
Information
1. The new third-party applications allow you to set the default SMS application;
2. Optimize code bomb box;
3. Once selected, a message appears top right corner of the complex casting mark;
Phone
1. increase popups remind save not add new contact name;
2. Optimize Contact Search Rules;
3. Add the function date when optimizing new contact;
Read
1. New Left slide right slide switch operation of the article;
2. Optimize the comments show the way, you can see all the comments in the article below;
3. Optimize the logic of the comment box. When the article declined to comment zone automatically appear when the comment box;
4. Subscribe to interface to join the "Finish" button to complete after the subscription directly back to the "My Subscriptions";
+ Game Center application center
1. Increase the game packs entrance;
2. New Applications tab, you can show the "official", "quality", "security", "no advertising" tab in the application of such details page;
3. Push the new message, you can push application centers operating activities, quality and other topics;
4. New features like points for comment, was the opportunity to praise the most commented top display;
5. Add in the "installed" batch uninstall application functionality;
6. The new merger notification bar batch download, installation was successful;
7. optimization downloads display;
8. optimize the download manager, you can download the show and download tasks;
9. Built-in applications can not update prompt repair downgrade to fail;
10. Fixing part plug-in application errors cause problems Application Center inaccessible;
11. Repair oversized fonts interface display error problem;
12. Repair Download Manager interface displays error problem;
13. Other known error repair problems;
Gallery
1. The new notification bar shows the progress of automatic backup;
2. Automatic Backup Cloud Album logic optimization, adding a variety of conditions to trigger automatic backup, backup to enhance the overall efficiency;
3. Support the library to hang backstage continue automatic backup;
4. Cloud transparent display photo albums to be automatically backed up;
Security Center
1. Security Center code refactoring to improve stability;
2. Fix a key clean-up or garbage removal during the scan error problem;
3. Optimize application before installation and cloud killing virus killing efficiency;
4. Fix virus killing complete page types, filter locked zone file;
5. Repair monthly traffic management issue date can not be cleared;
6. repair permissions management for the first time into the application without data management issues;
7. Repair sporadic flow units duplication;
8. initiative to optimize the virus killing virus database update code;
9. virus database update logic optimization;
10. Fixing traffic management application used in the absence of flow through the list of questions is not displayed;
11. The number of trusted repair the application does not update;
12. Optimized virus killing data collection;
13. Optimized Security Center Home animation;
14. Modify Security Center Home Score update in question;
15. Picture message content reporting logic;
16. Modify page load flow data delay problems;
Send multiple issues calibration commands 17. calibrated flow after repair;
18. Repair an application access rights management permissions details screen, press the Home key to the desktop after uninstalling the application, the Security Center issues an error;
19. Add a trusted virus killing modify the application to reduce the number of malicious files in question;
20. Adjust the flow after the repair has been using the warning value becomes zero problems with the flow;
User Center
1. Add Paypal latest plug-in support six mobile payment password;
2. recharge more than 100 yuan, an increase of the use of large recharge reminder;
3. Add another account icon identified and partially hidden account information;
4. New Root rights management, will enter the permissions settings interface after Root, root privileges can be managed for a single application;
Individuation
1. New theme installer, you can open the theme format files directly within the document;
2. Add a message push system, Direct Push activity or promotional information;
3. Optimize the theme details page slide area;
Video
1. Repair suspension window playback screen displays the proportion of the wrong question;
2. Fix unlock play video will play from the beginning of the problem;
Might create problems folders 3. Repair video downloads;
4. Fix DLNA playback switch anthology invalid question;
Input Method
1. New Candidate inertial sliding bar;
2. Yen rich text expression
alla faccia del changelog...
cosa piu' importante:
Members charm Friends Hello everyone, after a month of waiting, Flyme week re-open the firmware update, MX2 / 3/4 together into Flyme 4 era.
Every Tuesday afternoon, rain or shine. Following this week's update:
quindi si ritorna all'aggiornamento costnte ogni settimana
link:
http://download.meizu.com/Firmware/Flyme...update.zip
Ultima modifica di frezeen; 25-11-14 alle 13:48
Pensi che si può installare sulla versione internazionale?
credo di si, ma io per sicurezza non ho fretta apsetto la I
Infatti io aspetto la i soprattutto xche aspetto qualche miglioramento della fotocamera
Si può installare sulla versione internazionale come un normalissimo aggiornamento, ma se passo dalla I alla A poi posso tornare alla I?
LG G5 + MicroSD SanDisk Extreme Pro 32GB
Blog Modding Smartphone: http://moddingsmartphone.altervista.org/
Canale You Tube M.S. : http://www.youtube.com/user/ModdingSmartphone
<--- CLICCA THANKS
appena arrivato il bestione .. e stupendo in tutto. Ho un problema pero.. e uscito aggiornamento ota della 4.0.4 ma scarica lentissimo anchr con wi fi e anche dal play store D: avete soluzioni?
Da quando uso la 4.0.4I ho avuto qualche problema... Alcune applicazioni tipo galleria, fotocamera e file manager si sono bloccati in più occasioni senza motivo. Un paio di volte ho dovuto proprio riavviare il cellulare. Non mi era mai accaduto né con la 4.0.2I né con la 4.0.3I.
Attendo anche la possibilità di ridurre ancora di più le dimensioni dei caratteri e di poter utilizzare font diversi...
A me va tutto liscio come l'olio.. sono felicissimo di aver acquistato questo meizu. Vorrei porre una domanda, io avendo la miui su nexus 5 per attivare il root bastava andare nell'app sicurezza e attivare. Ma qui quell'opzione nn la trovo anche se ho letto che i permessi si danno nell'app sicurezza.
